Question about Dell Dimension 4600 PC Desktop
Missing or corrupt ntoskrnl.exe
I have an acer Aspire One ZG5 with a solid state drive and there is no CD drive... the Win XP home was preloaded. I'm not sure how to repair the ntoskrnl.exe file since I don't have and cannot use a restore/recovery CD or the original XP disk.
I can't get any advanced startup options to work... safe mode, last known good config, etc.
any suggestons?
Can I create a starup/recovery application on a USB drive?
Thx.
  • 447 Answers
This is a must watch before doing an Aspire One recovery.
You'll need an XP Home system disc (or an Aspire One recovery disc) and, well, hopefully the video is more explanatory...
Post your progress or any questions under this thread so that I can follow up with you...
Posted on Apr 20, 2009
  • John Elliott
    John Elliott Apr 20, 2009
    BTW This link is a good reference site for the Aspire One. I own one and have had to restore it from USB before (not because it needed it, just to test the process). I had to create an XP Home USB boot disk with BartPE which would allow me to do a USB boot and then followed most of the same process that a normal XP install would entail. Here's another tutorial about building the USB.
"aspire one d255 notebook error message: windows (xp home) could not start....missing/corrupt file: <Windows root>\system32\ntoskrnl.exe."
http://www.tomshardware.com/answers/id-1685452/bsod-caused-ntoskrnl-exe.html#.
-Insert the Microsoft Windows XP CD. Note: If you have a recovery CD or a restore CD and not a Microsoft Windows XP CD it is likely the below steps will not resolve your issue.
Reboot the computer, as the computer is starting you should see a message to press any key to boot from the CD.
- When you see this message press any key.
-In the Microsoft Windows XP setup menu press the R key to enter the recovery console.
-Select the operating system you wish to fix, and then enter the administrator password.
-Type expand d:\i386\ntoskrnl.ex_ c:\windows\system32
-You will then be prompted if you wish to overwrite the file type Y and press enter to overwrite the file.
-Type exit to reboot the computer.
Dec 10, 2013 | Acer Aspire One D255-2301
Tip
NTOSKRNL.EXE is missing or corrupt.
Issue: NTOSKRNL.EXE is missing or corrupt.
Related errors:
Below is a listing of the full error message that may be related to this error.
Windows NT could not start because the below file is missing or corrupt:
C:\Winnt\System32\Ntoskrnl.exe
Cause:
  1. Keyboard issue
  2. Miscellaneous corruption
  3. Corrupt boot.ini file.
  4. Missing boot.ini file.
  5. Missing or corrupt ntoskrnl.exe file.
  6. Windows NT installed on a partition bigger then 7.8GB
  7. Corrupted hard disk drive or severely corrupted Windows.
Solution: Keyboard issue
This issue has also been known to be caused by a short in the ground wire in the keyboard cable. Make sure this is not the cause of your error by replacing the keyboard with a different keyboard or simply just disconnecting the keyboard from the computer.
Before trying any of the below recommendations it's recommend that you attempt to load the last known good configuration. Additional information about doing this can be found on document CH000626.
This issue is often caused when the boot.ini is missing or improperly configured. This issue often arises after a user has recently added or removed an operating system on the computer or added or removed hard disk drives in the computer.
Make sure the line pointing to the operating system and its drive and partition is properly configured in the [boot loader] and [operating systems] section. Additional information about boot.ini can be found on document CH000492.
Microsoft Windows XP users:
If the boot.ini is severely corrupted or missing a user running Microsoft Windows XP can rebuild the boot.ini to resolve this issue. Additional information about rebuilding the boot.ini can be found on document CH000648.
Microsoft Windows NT and Windows 2000 users:
To restore the original boot.ini file in Microsoft Windows NT or Windows 2000 you will need an ERD and follow the below steps. If you do not have an ERD you will be unable to follow these steps.
  1. Boot the computer with your Windows NT three setup diskettes or the Windows 2000 setup disc.
  2. In the setup menu, type R to start the repair.
  3. When prompted for the ERD diskette insert the diskette and inspect the startup environment.
If the ntoskrnl.exe file is corrupt or missing this can also generate the error. To restore this file follow the below steps.
  1. Insert the Microsoft Windows XP CD. Note: If you have a recovery CD or a restore CD and not a Microsoft Windows XP CD it is likely the below steps will not resolve your issue.
  2. Reboot the computer, as the computer is starting you should see a message to press any key to boot from the CD. When you see this message press any key.
  3. In the Microsoft Windows XP setup menu press the R key to enter the recovery console.
  4. Select the operating system you wish to fix, and then enter the administrator password.
  5. Type expand d:\i386\ntoskrnl.ex_ c:\windows\system32
  6. You will then be prompted if you wish to overwrite the file type Y and press enter to overwrite the file.
  7. Type exit to reboot the computer.
If you are running Microsoft windows NT 4.0 on a partition larger than 7.8GB this issue can occur if the boot files are located outside this limitation. When this error occurs your computer will have the error message as shown below.
OS Loader v4.01
Disk I/O error status=00000001
Windows NT could not start because the below file is missing or corrupt: winnt\system32\Ntoskrnl.exe
Please reinstall a copy of the above file.
If your system partition is larger than 7.8GB you will need to delete the partition and recreate the partition to 7.8GB or less. Additional information about this issue can be found on Microsoft KB Q224526.
Attempt to check the hard disk drive for any errors by running the chkdsk program. To do this follow the below steps.
  5. Once at the recovery console type chkdsk /r
  6. Once completed type exit and see if issue is resolved.
If after trying all of the above steps you are still encountering the same issue it's likely that Windows is severely corrupted and it is recommended you attempt to reinstall Windows. Additional information about erasing the computer and starting over can be found on document CH000186.
Finally, if during the Windows installation you encounter errors it's likely that your hard disk drive is bad.
on Dec 27, 2009 | Computers & Internet
How can i reinstall the ntoskrnl.exe when it is corrupt
Assuming a couple of things:
1. Your OS is Windows XP
2. This is the error message you are getting -
"Windows NT could not start because the following file is missing or corrupt:
Winnt_root\System32\Ntoskrnl.exe
Please re-install a copy of the above file."
To reinstall notskrnl.exe, do this:
  • Start the computer by using your Windows XP CD-ROM. Press any key to boot from the CD.
  • After the setup files are finished loading press R to repair using Recovery Console.
  • When you are in the recovery console, select the installation to log on to (usually number 1), and then press ENTER.
  • Login to the Administrator account by typing the password for this account, and then press ENTER.
  • At the recovery console command prompt, type the following command, and then press ENTER:
    For Uni-Processor systems: expand <cd-drive>:\i386\ntoskrnl.ex_ <hd-drive>:\Windows\system32\ntoskrnl.exe
    For Multi-Processor systems:expand <cd-drive>:\i386\ntkrnlmp.ex_ <hd-drive>:\Windows\system32\ntoskrnl.exe
    Note In these two commands, the <cd-drive> placeholder represents the drive letter of your CD drive, and the <hd-drive> placeholder represents the drive letter of the hard disk on which windows is installed.
  • If you receive a prompt to overwrite the file, press Y.
  • Type exit, and press ENTER at the command prompt.
  • You should now be able to boot up properly.
  • Oct 14, 2013 | Dell LATITUDE Computers & Internet
    I HAVE A GATEWAY DESKTOP COMPUTER WITH AN ERROR MESSAGE SYSTEM32\NTOSKRNL.EXE. HOW DO I FIX THIS PROBLEM?
    NTOSKRNL.EXE is missing or corrupt. Issue NTOSKRNL.EXE is missing or corrupt.
    Related errors
    Cause
    1. Keyboard issue
    Solution
    Keyboard issue
    This issue has also been known to be caused by a short in the ground wire in the keyboard cable. Make sure this is not the cause of your error by replacing the keyboard with a different keyboard or just disconnecting the keyboard from the computer.
    Before trying any of the below recommendations it's recommend that you load the last known good configuration.
    OS Loader v4.01
    Check the hard disk drive for any errors by running the chkdsk program. To do this follow the below steps.
    If after trying all of the above steps you are still encountering the same issue it's likely that Windows is severely corrupted and it is recommended you reinstall Windows.
    http://www.computerhope.com/issues/ch000646.htm
    Mar 02, 2012 | Gateway GT5026E PC Desktop
    Ntoskrnl.exe is missing or corrupt solution
    Issue:NTOSKRNL.EXE is missing or corrupt.
    Related errors:
    Cause:
    1. Keyboard issue
    Solution:Keyboard issue
    OS Loader v4.01
    Oct 01, 2009 | Microsoft Windows XP Professional
    Error: windows root>\system32\ntoskrnl.exe
    Related errors:
    Cause:
    1. Keyboard issue
    Solution: Keyboard issue This issue has also been known to be caused by a short in the ground wire in the keyboard cable. Make sure this is not the cause of your error by replacing the keyboard with a different keyboard or simply just disconnecting the keyboard from the computer.
    Miscellaneous corruption Before trying any of the below recommendations it's recommend that you attempt to load the last known good configuration. Additional information about doing this can be found on document CH000626.
    Corrupt boot.ini file This issue is often caused when the boot.ini is missing or improperly configured. This issue often arises after a user has recently added or removed an operating system on the computer or added or removed hard disk drives in the computer. Make sure the line pointing to the operating system and it's drive and partition is properly configured in the [boot loader] and [operating systems] section. Additional information about boot.ini can be found on document CH000492.
    Missing boot.ini file Microsoft Windows XP users: If the boot.ini is severely corrupted or missing a user running Microsoft Windows XP can rebuild the boot.ini to resolve this issue. Additional information about rebuilding the boot.ini can be found on document CH000648. Microsoft Windows NT and Windows 2000 users: To restore the original boot.ini file in Microsoft Windows NT or Windows 2000 you will need an ERD and follow the below steps. If you do not have an ERD you will be unable to follow these steps.
    Missing or corrupt ntoskrnl.exe file If the ntoskrnl.exe file is corrupt or missing this can also generate the error. To restore this file follow the below steps.
    Windows NT installed on a partition bigger then 7.8GB If you are running Microsoft windows NT 4.0 on a partition larger than 7.8GB this issue can occur if the boot files are located outside this limitation. When this error occurs your computer will have the error message as shown below. OS Loader v4.01
    Please reinstall a copy of the above file. If your system partition is larger than 7.8GB you will need to delete the partition and recreate the partition to 7.8GB or less. Additional information about this issue can be found on Microsoft KB Q224526.
    Corrupted hard disk drive or severely corrupted Windows Attempt to check the hard disk drive for any errors by running the chkdsk error. To do this follow the below steps.
    If after trying all of the above steps you are still encountering the same issue it's likely that Windows is severely corrupted and it is recommended you attempt to reinstall Windows. Additional information about erasing the computer and starting over can be found on document CH000186. Finally, if during the Windows installation you encounter errors it's likely that your hard disk drive is bad.
    Oct 18, 2008 | Computers & Internet
    How do I...
    Related errors:
    Cause:
    Keyboard issue
    Solution:
    Keyboard issue
    OS Loader v4.01
    Oct 09, 2008 | Dell OptiPlex GX110 PC Desktop
    ACER DESKTOP COMPUTER
    Related errors:
    Cause:
    1. Keyboard issue
    best regards wish u give me a good rate ^^
    Aug 15, 2008 | Acer Computers & Internet
    Startup problem
    From: http://www.computerhope.com/issues/ch000646.htm If the ntoskrnl.exe file is corrupt or missing this can also generate the error. To restore this file follow the below steps. 1. Insert the Microsoft Windows XP CD. Note: If you have a recovery CD or a restore CD and not a Microsoft Windows XP CD it is likely the below steps will not resolve your issue. 2. Reboot the computer, as the computer is starting you should see a message to press any key to boot from the CD. When you see this message press any key. 3. In the Microsoft Windows XP setup menu press the R key to enter the recovery console. 4. Select the operating system you wish to fix, and then enter the administrator password. 5. Type expand d:\i386\ntoskrnl.ex_ c:\windows\system32 6. You will then be prompted if you wish to overwrite the file type Y and press enter to overwrite the file. 7. Type exit to reboot the computer. If you only have a restore CD, this probably won't work. You should just start the restore all over again, if this is the case.
    Jun 05, 2007 | Acer Aspire 5003WLMi Notebook
    Dell Dimension 4600 PC Desktop Logo
    414 people viewed this question
    mukhtar21 shaikh
    mukhtar21 shaikh
