Question about SimpleTech SimpleDrive Pininfarina 320GB External USB 2.0 Hard Drive - Blue
Computer does not recognize simpletech
I used a different simpletech external drive, renamed it R drive and downloaded some material on my computer. Now I have reconnected the newer simpletech external drive and my computer does not recognize it as a device that needs to be recognized. I have tried rebooting several times.
  • gmcneel Apr 29, 2009
    I HAVE A 160 GB SIMPLE TECH DRIVE THAT HAD SONGS DOWNLOADED ON IT. MY COMPUTER RECOGNIZED IT AT FIRST. NOW IT DOES NOT RECOGNIZED. ALTHOUGH THE LIGHT COMES ON, MY COMPUTER DOESN,T SEE IT. GLENN
I have a simpletech external drive that was working, but after i disconnect it unproperlly, i was getting the message <usb not recongnize>. I called simpletech, but customer service is ****, and anyway the drive inside is a hitahi, i have another simpletech and the drive inside is a western digital, whatever...
They told be to go to best buy to make a recover, so i called and they told me it s 250$, and if they cant do it, they will send it to a labotory witch cost 1700$, crazy ******* hein?
I red about getting drivers, putting the hdd in a fridge and much more stupid thing, BUT THE SOLUTION IS SIMPLE, OPEN THE CASE, UNDER THE ALLUMINIUM STICKER THERE IS 2 SCREWS, REMOVE THEM, OPEN THE CASE, TAKE THE HDD INSIDE OUT AND REMOVE THE ADAPTER CONNECTED TO THE HDD(WHERE YOU CONNECT THE USB CABLE) CAUSE THIS IS THE PART CAUSING THE PROBLEM, THE HARD DRIVE IS OK AND YOU DIDN T LOOSE NOTHING. So now what you can do is just buy a new case for laptop hard drive (with a new usb adapter included), or buy another simpleshit hdd and switch the adapter part or just buy an adapter to make your hdd an usb hdd and Voila, and after that i suggest you buy yourself a better hdd than simpleShit and make a new backup.
Posted on Jul 25, 2009
I had a similar problem with a SimpleTech Ext HD (1TB) and Vista. Try disconnecting the power source from the back of the drive and reconnecting it. Give it 15 or 20 seconds. This works for me. Unfortunately I have to do it each time my laptop goes to sleep, but that's not a hard problem to get around.
Posted on May 11, 2009
  • 702 Answers
Assuming Windows, try the Device Manager and see if the (old) disk is listed there in the disk drives section.
If so, right-click it and select Uninstall. (do this while the new driver is disconnected)
That should force Windows to recognize and reinstall the new drive when you plug it again.
For other causes check out the external hard disk problems.
Posted on Apr 20, 2009
I used the first solution, after having the issue of the linux and windows computer not recognising it. I removed the power whilst it was still 'connected' to the computer, and then replaced the power a few seconds later, and walla!- magic, b"h, it worked!
Posted on May 15, 2009
My computer will not recognize the drive. Does it have to be connect to a power supply? I have it connected to a usb port
Windows 7 does not recognize SimpleTech 250GB external USB drive ...
answers.microsoft.com/...does-not-recognize-simpletech-250gb/f7ceccd0...
Just bought a new computer, running Win 7. Drive worked fine on Win XP. ... Windows 7 does not recognize SimpleTech 250GB external USB drive ... I find it hard to believe that a external USB 2.0 drive can't work with Win 7. There must be ...
SimpleTech dvi hdmi pc Hard Drives Questions & Answers ...
www.fixya.com > Forum > Tags > dvi hdmi pc > Hard Drives
Question about SimpleDrive 160 GB External USB 2.0 Hard Drive ... Question about250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive ... my PC does not recognize the external drive 96300-40001-001 Driver Problem: Check whether ..
Dec 18, 2015 | SimpleTech SimpleDrive 250 GB External USB...
How do I ID and # photos on already onmy SimpleTech
select the ones in the same folder and highlight them with your mouse Hold down your cntrl key and right click the first image. If all the images are the same category then rename the right clicked image, what ever you want it to be. Once you have renamed the one, all the highlighted ones will be renamed the same with the difference being, all the other images will have a number added to it in sequence.
Jul 26, 2014 | SimpleTech SimpleDrive Pininfarina 320GB...
My computer will not recognize the external harddrive so I can't access it
Connect it to a different computer. If it is not recognized, then it has a problem.
If it is recognized, then your computer has a problem recognizing it.
Apr 10, 2011 | SimpleTech SimpleDrive Pininfarina 500GB...
Changed internal harddrive and now, computer cannot recognize the simpletech pininfarina external hard drive
If you loaded a driver for the Ext HDD with the old HDD, simply reload it or download off the net.
Dec 23, 2009 | SimpleTech SimpleDrive Pininfarina 320GB...
Simpletech 160gb
I would guess you are useing USB.
If correct, try a differant USB port.
The USB port you are useing may not be configured for USB2 speeds.
Sep 21, 2009 | SimpleTech SimpleDrive 160 GB External USB...
The computer does not recognize the Simpletech external hard drive. I plugged in a different external hard drive into the same USB port and the computer recognized it right away. What is wrong with the...
not all usb devices work on all machines
You need to find a driver or ask simple tech what the issue is i had the same issue with My WDC drive Western Digital gave me a driver after emailing them
Aug 13, 2009 | SimpleTech 750 GB USB Hard Drive
Not being recognized by computer
Is that external???If yess just buy new external...
Dec 10, 2008 | SimpleTech SimpleDrive 250GB, 7200RPM,...
SimpleTech PininFarina external hard drive - site to download drivers
the hard drive you have is plug n play.
if windows does not recognize it, you may have to uninstall the hard drive.
right click your computer. click properties.
click on the "Hardware" tab. Click on "Device Manager".
open the category of "Disk Drives".
If you see your drive with a yellow exclamation point or a red "X", continue. If it does not, either it was dropped or its a faulty drive.
Right click your drive and click "Unistall". Click OK.
Now, unplug the drive and plug it in again.
it will install by itself.
Go to my computer and check that its there. If its not, you may have a bad drive. either send it for a new one (if still in warranty) or replace it.
Aug 12, 2008 | SimpleTech SimpleDrive Pininfarina 320GB...
Transfering data
If you are having issues accessing the drive i've encountered that situation before
I tried a different cord and it started working again. Additionally i've had this work for me (see below)
Try This:
  1. Unplug all USB devices
  2. Turn off Ext Hard drive
  3. Shut down computer
  4. Power on ext hard drive (then wait like 1 min)
  5. Turn on computer
  6. Wait for windows to finish loading
  7. Plug in the USB cord from the ext hard drive to your computer (may take up to a minute for computer to recognize it)
  8. If it doesn't recognize it then keep trying it in different USB ports
If it still won't recognize get all the latest windows update and reboot. If that doesn't solve your issue try your external hard drive on some other computers, check to see if drive needs special drivers installed (which most don't).
From SimpleTech's website: "1) I have the drive plugged in but I cannot find the drive in "My Computer", why?
The most likely cause would be not enough power provided by a single USB port on your computer. Unplug the portable drive from the cable and unplug the cable from the computer. Now, plug the cable into 2 USB ports directly on your computer. (If you have a desktop, you should plug the USB cable directly into the USB ports on the back of the computer. If this is a laptop, you should plug directly into a USB ports on the computer. Do not plug into a USB hub or docking station). Then plug the drive into the cable. In a few seconds you should see the drive listed in the "My Computer" window as a SimpleDrivePS."
If all that fails you need to RMA (Return to Manufacturer) your external hard drive. Most hard drives have a pretty decent warranty on them. Your simpletech 250GB has a 3 year warranty on it. Info on the warranty can be found at http://www.simpletech.com/support/warranty/. If you want to RMA it, click the "Technical Support / RMA Request" on the left hand side of that page.
Mar 12, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
SimpleTech 250GB External Hard Drive Installation problem
I suspect it's not getting enough power from the USB cable. Might need external power.
Dec 06, 2007 | SimpleTech SimpleDrive 250GB, 7200RPM,...
SimpleTech SimpleDrive Pininfarina 320GB External USB 2.0 Hard Drive - Blue Logo
1,184 people viewed this question
Top SimpleTech Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Lyle Siemens
Lyle Siemens
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
