My dell LCD does not work. computer work fine with external monitor. Some light came on briefly and it went dark again. I can see the deskdop with the flashlight in the background. I spend many hours talk to dell suppport and they seem not to have a clue what is going on, one said it was a bad memory and the other guy said it is monitor problem. I want fix it myself. my computer is dell inspiron 1520. The problem all start when the window finish update the system.
  • 1 more comment
  • samuelnong Apr 20, 2009
    how do I check to see if it is ccfl lamp or whole LCD is bad?
  • ERIC BAKER May 11, 2010
    Have you tried starting up in safe mode to troubleshoot the problem?
  • iroargyropou
    iroargyropou Nov 27, 2012
    have you fixed the problem? i have the same!!! :(((((
  • 32,281 Answers
You could have a defective screen - a defective inverter or a CCFL lamp, follow this to determine the fault.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Posted on Apr 20, 2009
Dell Inspiron 1525 laptop screen goes dark
Hey Lea,
Try the steps below to see if they will resolve this issue that you are having with your computer. If this does resolve the issue you can email me. My email address is listed below in my sigfile.
1) UNPLUG THE LAPTOP
2) REMOVE THE BATTERY
3) HOLD DOWN THE POWER BUTTON FOR ABOUT 30 SECONDS TO 2 MINUTES
4) THEN PUT THE BATTERY BACK IN
5) START IT UP..
Thank You,
Dell-Jesse L
Dell Social Media and Communities
email jesse_leonard@dell.com
Apr 13, 2013 | Dell Inspiron 1525 Laptop
Problem with Dell 2100FP LCD monitor
Unplug monitor form AC outlet, wait for few minutes and plug again.
Check cable attache to PC.
Hope this trick will work.
Sep 30, 2008 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Charging and monitor issues
If your AC Adapter and Power Cord is working fine, then your new battery has a problem if it will not charge. Just because it is new does not mean it will work.
As for your Monitor, try the steps below. Because it works with an external monitor, we know your Video Card is working fine, so the problem is either the LCD Inverter or the Lcd Screen itself is bad.
Shine a flashlight on the dark screen to see if you barely see the icons on the desktop. If so, then the LCD Inverter is bad.
If you see no icons by shinning a flash light and the external monitor works, then your screen is bad. If you see no icons by shinning the flash light and nothing shows on the external monitor, then most likely your video card is bad.
May 16, 2012 | Dell XPS 1530-146P (X1530-146P) PC...
A line appeared in the middle of the screen and has expanded and now the botttom half of the screen has two horizontal bars of vertical lines instead of the bottom half ot the display. Recently had new...
Try to plugged in external monitor to your computer. If you did not experienced this problem using the external monitor then this is not a mainboard issue. This could be an LCD issue. You need to call the manufacturers tech support department and have your computer repaired. Same goes also if you experienced same problem using external monitor. You still need to call dell tech support department for mainboard replacement.
Jun 13, 2010 | Dell Inspiron 1525 Notebook
Dark screen on me laptop
the LCD backlight has failed, you will need to replace the LCD assy (about $200)
Jan 18, 2009 | Dell Inspiron 5150 Notebook
Display after rain went black
If your video output works fine when connected to an external monitor, then the issue is with the LCD display panel. I’m afraid the only way to fix this is to have the LCD panel replaced.
Your responses are intended to improve the level of service provided. Please rate your experience.
Thank You.
Oct 19, 2008 | Dell Inspiron 6400 Notebook
Monitor is Blank and Power Light Blinks
JH77,
Hi...Ya! It's seems your LCD monitor backlight inverter just run out of lucks... it's burnt out. Need to replaced a new inverter. Have a nice day!
Sep 25, 2008 | Dell E173FP 17" LCD Monitor
Dell LCD E207WFP (Switches on Briefly then goes Off)
two case trouble reason and need to do:
1) back light driver (inverter) works not stable and DC power protect. it near some component damage, should repair inverter by egineer.
2) back light (lamp) over life cycle so protect by the inverter, should change new lamp (regular parts)
3) DC power supply not stable or component over life( wave filter capacitor), should be replaced
Aug 03, 2008 | Dell E207WFP LCD Monitor
Laptop Screen dark yet computer works with external monitor
does the fan work ok? and do you have a laptop holder for it or you just have it on a desk ....get a laptop holder for it if you do not have one and as for the rest goto the power mangment area on the computer and see if the monitor might be on stand by after a few min ...
Jul 14, 2008 | Compaq Presario R3000 Notebook
Computers & Internet Logo
811 people viewed this question
David Payne
David Payne
