Question about Namsung Car Audio & Video
Need wireing overview namsung db1200
Not color code actual ports ie pwr ill grnd rf lf rr lr
3 Suggested Answers
SOURCE: User, Installation, and Troubleshooting Manuals
I found this manual in another quorom and then saw your inquery.
http://dbproducts.net/i/product/manual/DB1200_OM.pdf
Posted on Jan 19, 2008
  • 4102 Answers
SOURCE: re sent wire diagram gat all messed up
Hi
have we spoke before in previous post?
the red can go to any 12v live peramanent such as wire to clock or other item that has power with ignition off and the same with the yellow if your putting these to the same permanent live say from clock you can join these to together red/yellow to red on clock
the black can go to any metal or neg wire.
This should then have your device working the only problem im looking at for you now is the pink wire as this stops you using the device whilst driving as it goes to handbrake but i need to find out if its live or negative.
You could just wire the red/yellow to live and black to earth then see if it switches on and works if not then let me know and ill see about the pink wire ok
Makes sure you use inline fuses on the live wires so as not to short the device out.
Make sure you know what is permanent live to put the yellow/red wire to.
It doesnt need to be ignition it only says this so you cant use it with ignition off but you can wire it into any live feed from clock or switches so its up to you what to wire it to its just the pink wire im concerned about.
PINK: does it tell you to put it to live or earth on handbrake switch?
let me know ok
Posted on Apr 21, 2008
I have a 2001 chevy silverado 4.3 v6 ext cab 1500 truck! I want to install a amp and speakers to the stock radio! I bought a high/low tap to run the RCA from stereo to the amp, what wires do I need to tap...
The speaker (high) level outputs are:
LF- GRY
LF + TAN
RF - DK GRN
RF + LT GRN
RR - LT BLU
RR + DK BLU
LR - YEL
LR + BRN
The wire color code in the "tap" (level converter) may not correspond to the above.
Jun 26, 2014 | Cars & Trucks
How to hook up without connectors
car colors
yellow 12v switched
orange 12v con
green rf-
lite green rf+
grey lf- paired with tan
tan lf+
blue rr+
lite blue rr-
yellow lr- Paired with brown
brown lr+
pink pwr antenna
brown alone illumination
grey alone illumination dimmer
black ground
radio wires
purples rr
green lr
grey rf
white lf
red switched
yellow 12 con
bluewhite stripe ..amp turn on
blue power ant
black ground
hope it helps
Jun 07, 2010 | JVC AM FM CD DET FACE CAR STEREO
I need radio color wiring diagram for 2001 hyundai accent what wire goes where
Battery RED (+) RADIO HARNESS
Accesory WHITE/GREEN (+) RADIO HARNESS
Ground BLACK (-) RADIO HARNESS
LF Speaker (+) BROWN/WHITE
LF Speaker (-) BLACK/WHITE
RF Speaker (+) BROWN/YELLOW
RF Speaker (-) BLACK/YELLOW
LR Speaker (+) BROWN/RED
LR Speaker (-) BLACK/RED
RR Speaker (+) BROWN/WHITE
RR Speaker (-) BLACK/WHITE
Apr 06, 2010 | Car Audio & Video
Need colour codes for stereo wiring for 2000 hyundai accent
ANT org/wht, LR spkr brn/blk, LF spk blu/blk, RF spk blk/wht, RR spk grn/blk, ILL blk/wht, ACC gry/wht, GRND blk, LF spk brn/wht, RF spk brn, RR spk grn/wht, ILL grn/wht, MEM power org/blk.
Dec 26, 2009 | 2000 Hyundai Accent
Color code radio wireing 2001 malibu
Battery Orange +
Accessory Yellow + Note this vehicle does not have a dedicated accessory turn on wire . use a lead from the ignition switch or fuse panel to supply accessory voltage .
Ground black -
Illumination Gray +
Dimmer Brown +
Lf Speaker Tan +
Lf Speaker - gray
Rf Speaker + Light Green
Rf Speaker - Dark Green
Lr Speaker + Brown
LR Speaker - Yellow
rr speaker + Dark Blue
rr speaker - light blue
Aug 28, 2009 | Car Audio & Video
95 olds aurora radio wiring
Battery ORANGE (+) RADIO HARNESS
Accesory YELLOW (+) RADIO HARNESS
Ground BLACK/WHITE (-) RADIO HARNESS
Illumination GRAY/BLACK (+) RADIO HARNESS
Dimmer BROWN/WHITE (+) RADIO HARNESS
Power Antenna DARK GREEN (+) RADIO HARNESS
LF Speaker (+) TAN
LF Speaker (-) GRAY
RF Speaker (+) LIGHT GREEN
RF Speaker (-) DARK GREEN
LR Speaker (-) YELLOW
RR Speaker (+) DARK BLUE
RR Speaker (-) LIGHT BLUE
Amp Location TRUNK,ON BACK SEAT
Steering Cntrls NO
Speed Cntrl NO
Radio Security YES
Apr 12, 2009 | Sony Car Audio & Video
Need wire color codes for 2000 cavalier stock radio
Accesory need to go to the ign switch cause radio does not provide a switch source.
Illumination GRAY (+) RADIO HARNESS
Amp Turn On PINK (+) RADIO HARNESS
LF Speaker (+) TAN
LF Speaker (-) GRAY
Feb 25, 2009 | Car Audio & Video
Color code radio wires 1990 ford truck F350 4 w/d
Battery GREEN/YELLOW (+) RADIO HARNESS
Accesory YELLOW/BLACK (+) RADIO HARNESS
Ground RED OR BLACK (-) RADIO HARNESS
Illumination BLUE/RED (+) RADIO HARNESS
LF Speaker (+) ORANGE/GREEN
RF Speaker (+) WHITE/GREEN
RF Speaker (-) BLACK/WHITE
LR Speaker (+) PINK/GREEN
LR Speaker (-) PINK/BLUE
RR Speaker (+) PINK/BLUE
RR Speaker (-) GREEN/ORANGE
radio Security YES
Feb 20, 2009 | JVC Car Audio & Video
Clarion VRX928RVD NEED WIRING
MEM
ORANGE
PWR
YELLOW
GND
BLACK
ILL
GRAY
DIM
BROWN
ANT
PINK
RF
LT GRN
RF
DK GRN
LF
TAN
LF
GRAY
RR
DK BLUE
RR
LT BLUE
LR
BROWN
LR
YELLOW
Nov 14, 2008 | Clarion VRX935VD Car DVD Player
Radio codes
Battery WHITE/YELLOW (+) RADIO HARNESS
Accesory WHITE/RED (+) RADIO HARNESS
Illumination RED/BLACK (+) RADIO HARNESS
Dimmer RED (-) RADIO HARNESS
Power Antenna YELLOW/WHITE (+) RADIO HARNESS
Amp Turn On YELLOW/WHITE (+) RADIO HARNESS
LF Speaker (+) WHITE
LF Speaker (-) ORANGE
RF Speaker (+) YELLOW
RF Speaker (-) BROWN
LR Speaker (+) RED
LR Speaker (-) GREEN
RR Speaker (+) BLUE
Oct 18, 2008 | 2003 Chevrolet Silverado 1500
Car Audio & Video Logo
309 people viewed this question
Top Namsung Car Audio & Video Experts
xxxxxx xxx
Are you a Namsung Car Audio and Video Expert? Answer questions, earn points and help others
