Question about Kenwood Audio Players & Recorders
Fluoresecent Display - Harmon Kardon "Festival 60" Micro Stereo
The fluoresecent display (AM/FM/RDS, CD status, etc.) is no longer uniform in its intensity or colour. Part of it is bright and other parts of the display are dull or faded out. I can still see the characters, but not as they once appeared. Can the display be 'restored' to its original state. The unit works perfectly otherwise. I can't attribute this chnage to any particular cause (ie. a power surge, or similar event). One day it was fine, the next day the problem appeared. Help please. Thanks Michael
    Top Expert:
  • Kenwood Master
  • 54,195 Answers
The display is failing.
Posted on May 22, 2017
4 Suggested Answers
SOURCE:
  • 99 Answers
SOURCE: KENWOOD MODEL D-425M (NO DISPLAY)
try inspect the main power PCB for dry joints or maybe leaky/dryed out capacitors. hope this helps?
Posted on Mar 18, 2009
robotek
  • 1512 Answers
SOURCE: I have a harmon kardon cdr 30 cd recorder. After a
Hi
First thing to do is disconnect the unit from the mains supply for 15 mins to allow for a hardware reset,and then power it up and try again. If it does not come up, then the power supply has been damaged by a power surge associated with the outage. You may have no choice but to take the unit to an authorised HK repairer. Let me know how you get on with resetting the unit. Please take the time to rate this solution. Happy to talk to you more about it. Cheers
regards robotek
Posted on Jul 15, 2009
MicrowaveSvc
  • 9174 Answers
SOURCE: The display on my Sharp R-820 BK convection
The service manual will aid you in disassembly. It is here.
This can be repaired for $39.95 in most cases. Details here.
Posted on Apr 29, 2011
Coby cd troubleshooting
Coby outta business - bankruptcy. Cannot get parts so ..............
Jul 31, 2016 | Coby CX-CD377BLK Micro CD Player Stereo...
Meter fuse lamp 11/2 in 6.3 v 250 ma can not find one
http://www.ebay.com/itm/DYNACO-FISHER-MARANTZ-SANSUI-PIONEER-KENWOOD-JVC-OTHERS-HI-END-FUSE-LAMP-/370844118805?pt=US_Light_Bulbs&var=640100726899&hash=item5658082f15
Apr 18, 2013 | Harmon Kardon Vintage 70s Harman Kardon...
The Harmon Kardon LCD display on my 2010 Harley Davidson Electra Glide Ultra Limited has flipped and now shows everything backwards. Anyone else have this problem?
defective LCD or liquid intrusion to faceplate PCD. Should be under warranty. If not, contact Iron Cross Audio for repair options
Aug 26, 2010 | Harley Davidson 426290 AM/FM Radio
2006 harmon kardon radio no display,radio works fine
most likely liquid damage. Faceplate needs to be replaced and liquid prevention mod installed. Contact Iron Cross Audio (www.ironcrossaudio.com). 201-207-7157
Aug 16, 2009 | Harley Davidson 426290 AM/FM Radio
HARMON KARDON RADIO 06 STREETGLIDE
06 units did not have the audio circuit vibration mod installed. Unit needs to go under a microscope to isolate the bad component or solder joint. www.ironcrossaudio.com can help with the repair.
Apr 05, 2009 | Harley Davidson 426290 AM/FM Radio
Changeing to newer radio in 2000 harley ultra
no, besides the harmon kardon using molex connectors. I wouldn't attempt.
Jan 29, 2009 | Harman Kardon Sony CMTNEZ3 AM/FM Radio...
Need to change the 12v supply by the Radio
The Ford Focus has a stereo problem where the display blinks on and off, with or without the ignition on. This is not a power problem.
This problem occurs when attempting to store a radio station when a blank RDS signal is being transmitted.
To restore your stereo:
  • Insert a CD, stereo will turn on in CD mode.
  • Press MENU button
  • Select DEFAULT RESET by turning the right rotary knob and press to select
  • Select YES by tuning the right rotary knob and press select
  • Press BACK button
  • Press the RDS button once, display will read RDS OFF
  • Stereo will now work properly
To prevent this problem from occurring again, be sure some text is in the top line of the display when setting a stereo station. Do not set a station when the station name is blank in display.
Nov 16, 2008 | 2006 Ford Focus
Was using the harmon kardon avr 225 receiver and the front panel went out. .... screen display of the channel number, volume, or menu item does not work. ...
Try hooking up a yellow video wire from the back of the AVR 225 Monitor out. Should be at the end of the 7 or 8 yellow video ports on the back of the stereo. Next plug the other end into a yellow video in on a t.v. Get your remote, (Harmon/Kardon) and make sure the t.v. is on the correct video input and hit the OSD(on screen display) button on your harmon remote. There should be a setting in there that says VFD under ADVANCED menu option that allows for turning the front of your stereo lights on and off and dimming them half way also. OFF/HALF/FULL are the 3 options I believe.
If this doesnt solve it your display may have crapped out on you.
Jan 22, 2008 | Harman Kardon AVR 225 Receiver
42 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
rigger094
Mike Duncan
Mike Duncan
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
