Question about Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker
Kenmore bottom freezer icing up all the time
Kenmore bottom freezer keeps icing up fins in the back of freezer. It keeps food cold but is set at lowest cold setting. It has a 8 hr defrost timer. It will take ice off fins if I put it in defrost mode manually. But will not take ice off by itself when it is all froze up in the back. I took the cover off the inside back of the freezer so I can keep an eye on it. So when it starts icing up, out comes my wifes hair dryer and I go to work on it. I am so tired of doing this for a month now. Any suggestions would be appreciated. Thanks
  • Anonymous Apr 20, 2009
    This is clearly one of the defrost components. I have the same problem, I'm working to diagnose if it's the timer, thermostat or heater.
  • theFilter Apr 23, 2009
    ditto that on this problem....just started a couple months ago
3 Suggested Answers
  • 308 Answers
SOURCE: bad defrost timer/ thermostat???
It definitely sounds like you have a bad defrost timer, that is the reason the coils are icing up on you. The next issue, which may or may not be related is the freezing of items in the refrigerator. Usually the cold air is transferred, through a vent with a damper, from the freezer and into the refrigerated section. The "thermostat" for this section is actually usually just a lever to adjust the position of the damper. That being said, usually when you have a problem such as you are having, it is either a stuck or broken damper (or damper component). Hope this helps
Posted on Nov 16, 2009
Testimonial: "EXCELLENT!!!!!!!!!!!!!!"
  • 351 Answers
SOURCE: Hello,I have a Kenmore side by side Mod
either a bad defrost element or timer
Posted on Sep 29, 2010
HELLO I HAVE A KENMORE TOP FREEZER BOTTOM FRIDGE AND NEITHER IS COLD OR FREEZING. MY MEATS AND ICECREAM HAVE DEFROSTED AND BOUT SPOILED. IN THE BACK OF FREEZER WHITE ICE IS FORMING IN WHAT LOOKS LIKE
defrost and clean the entire fridge/freezer and clean out the grill and all the back and bottom under the fridge...with a vacuum..alot of times the fins in the back become coated in dust and cannot effectively cool the appliance..worth a try
Jan 08, 2014 | Kenmore Top Freezer Refrigerator
Kenmore classic bottom freezer refrigeration warm but freezer is cold
I would guess you have just caused a build up of ice to block the air way, which normally takes cold air into the fridge. manually defrost (unplug and wait until the ice goes away) then restart and it should be fine
Nov 11, 2013 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Upright freezer not freezing food and ice forming on back wall
is the top of the freezer full where it can breathe remove something to help it breathe
Sep 10, 2012 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Refrigerator won't cool
seal on door must be letting moisture into compartment, need new door seal
Aug 20, 2012 | Kenmore Top Freezer Refrigerator
Hi- I have a Kenmore top mount refrigerator. The freezer keeps ice frozen, but not food. I turned up the setting and all that did was cause ice to form in the bottom air vents and frost on the back wall.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jun 02, 2011 | Kenmore Refrigerators
Fridge & Freezer won't get cold, but air is blowing
Is the compressor in the lower back working. You may short of gas . have it regassed
Sep 07, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Freezer Not Freezing Food
there is a circulation fan and also a vent. Either the fan is blowing, or there is a cloged vent.
Feb 11, 2009 | Kenmore 14.1 cu. ft. / 399 liter Upright...
Kenmore elite refrigerator. both compartments (bottom freezer and top refrigerator)are not keeping with the temperature setting. the food is cool but not cold as it should be. how can I test to see if...
Really most folks have to keep their setting on their fridge on about a 6-7 or-8 setting with the amount of food that is kept in the fridge now.
YOU CAN KEEP AN EYE ON THE RELATIVE temp if you like by placing a fridge thermometer in the appliance. Optimal fresh food should be around 40-43 degrees F on average to keep things on the cooler side without freezing.
Hope this helps
Nov 27, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerator not cooling
This could be that it is out of balance. Set the temperature settings to midway. This control can easily get the fridge temp out out of balance if over adjusted. If you already have the tmp control at midway then you need to make sure there are no obstructions to the duct that carries the cold air from the freezer to the fresh food section to cool it. Check for ice buildup or any kind of blockage. Let me know what you find.
Nov 16, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore 73503 not cold enough
Is the fan in the freezer working?? Is there Ice on the rear panel in the freezer?
Dec 04, 2007 | Kenmore 73503 Stainless Steel Bottom...
Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker Logo
369 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
