Question about Canon Office Equipment & Supplies
Canon pc980 copier...changed toner cart. now the image it produc
I have a canon pc980. It ran out of toner, so i ordered a cartridge. installed the new cartridge machine prints but the whole image is covered with a black cast like there is way to much toner or a to dark setting. I have the image set to print with the lighet setting possible. all i did was change the toner cartidge...what gives? have not been able to find any way to fix it.
Cartridge is defective. I suspect it was a 'compatible' or remanufactured unit vs. an original. Replace it and it will work fine.
Posted on Apr 20, 2009
Canon pc 941 copier cartridge issues
Just to clarify, you are stating INK? The Canon PC941 uses an OEM (Original Equipment Manufacturer) Toner Cartridge. Canon toner cartridges for PC941 printer are supplies produced by the same manufacturer that makes given piece of equipment. Toner cartridges produced by Canon are called OEM. Remove the toner from the machine and then use cotton swabs and alcohol to clean around the roller wheels of all drawer areas. Be sure to unplug the equipment before attempting to clean the wheels.
Jan 25, 2012 | Canon PC-941 Copier
At times i get a message 14 no toner cart and then i am unable to make prints
No Toner then it prints again..
This could be lower toner, a generic toner cartridge will sometimes produce this, or dirty contacts where the cartridge lays in machine.
Look at the toner cartridge, where you see shiny silver or bronze, clean excess toner off, also in machine where toner cartridge lays, clean all excess toner out.
Oct 03, 2009 | HP LaserJet 4 plus Printer
Changed toner cart. do to void in middle of print
My whole day, today, was filled with dealing with bad toner carts.
Even new genuine ones from HP
6 service calls., 6 bad carts.
Aug 19, 2009 | HP LaserJet 5p Printer
Gray continuous streaks on lower half of copy using Canon IR 1600
I assume you had the issue before you changed the toner, If so the problem is either the fuser or the Laser.
Do this:
start a print job and after you hear the paper feed into the machine open the top cover to stop the machine. You want to stop the page before it gets to the fuser. May take a couple tries.
remove the toner cart.
the page should be under the cart with the image on it.
If the line is on the page the problem is image development(toner or laser).
If no lines the problem is likely the fusing assm.
May 28, 2009 | HP LaserJet 8100N Printer - Refurbished
Canon IC 6530 After installing new toner cart, machine is still saying toner is low
maybe the cartridge you are using is a refurb. and the sensor is not working or the chip is bad.
Mar 30, 2009 | Canon MF-6530RF Factory Reconditioned...
I have a canon image runner 1370 f.
Are you trying to replace the old toner or is this the first time -- new out of box? There is a pattern / order you have to follow to replace the cart. To make it easier, have the right cover open while doing this ( replacing the carts). Also make sure that you have the protective covers and tape off of the cart. Use the light colored area on the cart. to hold and DO NOT TOUCH THE DRUM !!!
Dec 30, 2008 | Canon imageRUNNER 1023N Black and White...
Konica 1400 page pro
Toner Cart is combined with Drum Cart in what's called an "Image cartridge" did you followed user manual instruction to change it?
Let me know if you have the instruction from User manual: I can send it.
Nov 24, 2008 | Konica Minolta PagePro 1400 Laser Printer
Problem with aficio 1035
The developer should probably be changed in it. the cartridge should be inspected as well. Was there any toner spills?
Jun 21, 2008 | Ricoh Aficio 1035 Copier
Canon Imagerunner C2050 changing toner
Did remove all of the packing off the cartridge before installing the cartridge. Also, is it the right type of cartridge for that you need and or the right color... It should be easy to install if you are installing the right cartridge... Good Luck
May 12, 2008 | Office Equipment & Supplies
Canon image class mf 8170 problem
its mean that change new drum cartridge
Oct 17, 2007 | Canon ImageClass D880 Copier
189 people viewed this question
old marine
old marine
