Question about HP LaserJet 2840 All-In-One Printer
HP 2840 10.1004 SUPPLY ERROR I am getting a 10.1004 error meassage after replacing the chip on the imaging drum. Previously I was getting a "replace drum"message so I know that it was the imaging drum that was the culprit. Any ideas on this? Regards Alan
    Problem Solver:
  • 5 Answers
There is something wrong with your drum.. try to replace a new chip for the drum make sure that the chip is working.... if that did not work. see if there is any damage in your drum.. If not replace a new drum..
Posted on Apr 27, 2009
How to solve 52.0 scanner error of HP leserjetp1007 myself?
a 52 Scanner error indicates the laser/scanner which writes the image to the drum has malfunctioned. This is a hardware error and most times the actual laser/scanner assembly needs to be replaced. If under warranty contact hp for service.
Jan 02, 2018 | HP Office Equipment & Supplies
The Samsung Printer M-2876ND is showing an error replace imaging unit. It has already printed 9000 units, so i guess the life of the unit is over. Now, i want to know if the same will work in case i j
Dear Ankit
you can replace the complete drum cart. or replace the CRUM (drum chip) of the drum cart. no need to replace the drum it can goes up to another 9000 a4 pgs.
Thanks.
Jan 12, 2015 | Samsung Office Equipment & Supplies
LaserJet 2840 Error 59.99
Many drums have a chip with a lifecycle. You may need to replace the chip if you dont want to replace the drum.
Feb 05, 2014 | HP LaserJet Office Equipment & Supplies
Hi, we have the hp color laserjet 2840 series and we are getting a supply error (10.1004). The picture shows that there is a problem with our imaging drum. We bought a brand new imagind drum and it is...
Reseat the toner cartridge. Turn the printer off, and then back on again. You may want to try a new cartridge, but if that does not eliminate the error, call your HP support line. If the imaging-drum light is still blinking but the Attention light is not on, you must replace the imaging drum before the printer can continue printing. The imaging-drum light might be blinking by itself or at the same time another light is on or blinking. If another light is also on or blinking, turn the imaging-drum light off in the simulator and turn the other light on or blinking to isolate the condition. The printer has determined that it cannot read or write to the e-label on the imaging drum.Reseat the imaging drum, and then power cycle the printer. If this does not work, replace the imaging drum. If the imaging drum light is still blinking but the Attention light is not on, turn the printer off, and then back on. If the problem persists, replace the imaging drum E-label reader. The imaging-drum light might be blinking by itself or at the same time another light is on or blinking. If another light is also on or blinking, turn the imaging-drum light off in the simulator and turn the other light on or blinking to isolate the condition.
If Hope that this helps,, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Thanks,Joe
Feb 04, 2011 | Office Equipment & Supplies
10.1004 SUPPLY MEMORY ERROR ON IMAGING DRUM Unable to read the supply data. Re-install the supply. If the error reappears, contact support.
Memory Supply Error 10.00.00 The printer is unable to read or write to the print
cartridge e-label, or the e-label is not on the cartridge.
Basically what is happening is the printer cannot read the small chip on the toner cartridge. The chip is located on toner cartridge as it is inserted into the printer. 1 - Make sure the toner is firmly seated into the printer. 2 - Power cycle the printer with the toner out of the printer. Install the toner back into the printer. 3 - Install another toner cartridge. 3 - Verify that the e-label connector is firmly seated in connector
Contact a local HP Authorized Service Center for further assistance.
Jul 03, 2010 | HP LaserJet 2840 All-In-One Printer
Supply error 10.1004 on HP laserjet 2820 printer
this error comes when the printer not reco the cairtages & drum if u replaced the print cairtages then replace the drum & calibrate the printer & restore the factory default.
May 12, 2010 | HP LaserJet 2820 Printer
Error message replace drum for printer hp laserjet
pristonero, there is no "main" button. what are you talking about?
Oct 20, 2009 | HP LaserJet 2840 All-In-One Printer
Orange light is flashing and printer is not printing. It is not the crescent , not the triangle, but the one abve the triangle and below the colored catridge rotation button.
Imaging drum is empty or missing (Error 40204) Light pattern c00187081.jpg Description The imaging drum is empty or missing. The imaging drum light is blinking, and then printer stops printing. An error 40204 is written to the event log. The printer cannot detect the imaging drum correctly. Action
  1. Reinsert or replace the imaging drum.
  2. If the imaging drum light is still blinking but the Attention light is not on, turn the printer off, and then back on.
  3. Repeat Steps 1 and 2 with a new imaging drum.
  4. If the problem continues, contact HP Customer Care at http://www.hp.com/support/clj2550 or see the flyer that came in the printer box for other contact information.
Imaging drum e-label reader is faulty (Error 10004) Light pattern c00187081.jpg Description The imaging drum light is blinking, and then printer stops printing. An error 10004 is written to the event log. The imaging drum e-label reader is faulty and the printer cannot detect the imaging drum correctly. Action
Apr 27, 2009 | HP Color Laser 2550N Printer
We have replaced new imaging drum for HP Colour Laser jet 2840 but it is still saying we need to replace it? How do we get round this problem or what are we doing wrong?
Hi Katherine,
This has to do with a chip on the Imaging Drum Unit. The chip has been "spent" or faulty. Whether it is a brand new HP Drum unit or a refurbished one, you should bring it back to your supplier.
Note that just replacing the chip on a used Drum Unit would have problems later as there is a waste bin which could be nearly fully.
Rgds
S88
Dec 04, 2008 | HP Hewlett Packard LaserJet 3000dn Printer
HP COLOR LASER JET 2550 SERIES
You will need to replace the image drum. This is either due to the face that you have exceeded the number of pages/cycles that the drum supports or the drum has damage. If this is the drum that came with the printer, it is likely they shipped it with "starter" supplies which last a fraction of the time as the regular "full retail" replacement supplies. A URL for HP's instructions on how to replace tn image drum on the HPCLJ 2550 series follows:
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=125&prodSeriesId=388394&prodTypeId=18972&prodSeriesId=388394&objectID=bpl12241
Nov 08, 2007 | HP LaserJet 2550Ln Printer
HP LaserJet 2840 All-In-One Printer Logo
3,095 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
