Question about Emerson EWL3706 37 in. LCD Television
I have an emerson tv and it will not power on at all. The little light wont even come on.
  • 55 Answers
Solution 1 was just step 1. If the outlet gets power and the fuse or circuit breaker is ok, then U have a bad tv. That seems to be the most common problems with lcd's when they go bad. They either give the blinking light and not coming on, or they go completely dead. Most common causes are a bad power supply or a bad board/PCB/Circuit board.
Posted on May 04, 2009
  • 10,865 Answers
Check the outlet where you have the TV plugged in. It sounds like that outlet has no power which would mean that the circuit breaker needs to be reset or the fuse needs to be replaced.
Posted on Apr 20, 2009
My Emerson TV wont turn on
Could be an open internal fuse or power supply failure
Aug 03, 2017 | Emerson Televison & Video
My Emerson LE320EM3 tv wont turn on, it has not flashing lights and only makes a high pitched frequency when plugged in.
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Mar 30, 2016 | Emerson 32" Le320em3 720p 60hz Led Lcd...
Why wont my emerson tv turn on?
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Nov 30, 2015 | Emerson Lc320em1f TV
TV WONT POWER ON
Hi does the TV have any standby light etc, if so power off at the wall and leave for 1 minute the power back on and watch the standby LED it may or may not blink try to power on if the light blinks this may be a fault code and you can search this up with the model number.
Apr 08, 2015 | Emerson LF320EM4 32" 720p 60Hz Class LED...
My Emerson TV Wont turn on... No sensor lights working either.
Check and replace damaged component/s at it main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis.
Apr 28, 2014 | Emerson LC401EM2F 40" Inch LCD Full HD TV
Tv wont come on,sensor light flashing red and blue, emerson
hi, this fault could be down to capacitors on the power board
regards
shaun
Nov 10, 2013 | Emerson Televison & Video
My Emerson LC320EMX tv wont power on. Can you please tell me if there is a way to fix this?
Check ur power out source?If tv have no power LED light indication on the tv bazel frame at all.Tv power LED light indication on the tv bazel are flashing.Tries tv unplug,replug it back like about an hour later for tv to do a resetting itself back to the factory setting.Tv should be working again.If still have the same result.The tv power supply board is the causes and the problems.That the board where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Apr 21, 2011 | Emerson LC320EM9 32 in. LCD HDTV
My emerson tv standby light is on the power light flashes twice
Mine stayed in stanby mode and all I had to do was to switch the plug to a different outlet. The power strip it was on wasn't providing enough power. It worked fine for a month before I had a problem.
Dec 04, 2008 | Emerson EWL3706 37 in. LCD Television
I have an Emerson TV 32
i turned on my tv and it blinks green continuesly. it wont turn off to red light. i unpluged it for 30 min. repluged it and green light comes on and wont stop blinking
Sep 07, 2008 | Emerson EWL3706 37 in. LCD Television
Emerson EWL3706 37 in. LCD Television Logo
594 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
