Question about Refrigerators
Can't get old filter out and where and what kind of filter do i get?
How do i change the filter in my maytag side by side refrigerator msd2242veb00? i know where the filter is i just can't get it out! also, what kind of filter and where do i get it?
  • 744 Answers
Give the filter a counterclockwise twist (about 1/2 turn) and pull. Turn the water off to the fridge first to be safe. You can use a pair of pliers to turn it if you can't get it out with just you hand....but be careful and don't get too rough.
Posted on Apr 20, 2009
How do I reset the filter light on my Maytag side-by-side refrigerator freezer after changing the filter?
you should be able to press and hold the water filter light button for 3 or more seconds and it should reset
Mar 23, 2011 | Maytag MSD2655HE Side by Side Refrigerator
I changed the water filter and I can't change the red indicator light to green on the outside of the refrig. Help!!! Maytag side by side
AFTER CHANGING THE FILTER . YOU THEN HAVE TO HOLD DOWN THE LIGHT BUTTON AND THE LOCK BUTTON AT SAME TIME FOR APPROX 3 SECONDS AND THE FILTER LIGHT WILL FLASH THEN GO OUT
Dec 05, 2010 | Maytag MSD2756G Side by Side Refrigerator
I have a Maytag side by side with water/ice dispenser in door and filter for water. I changed the filter upon moving into house in June. The change filter light came on a few weeks ago and I can't get it...
I have a Maytag side by side with water/ice dispenser in door and filter for water. I changed the filter upon moving into house the change filter light came on and I can't get it to go off. How do I reset the change filter light (it's not time to change the filter)? The model # is MSD2732GRW and I don't have a manual for this refrigerator. Thanks!!
Sep 07, 2010 | Maytag Refrigerators
Occasional water running out the side from under refrigerator
the ukf7003 filter is the correct one for your mod. the leak may be inside the freezer . the drain in back may be iced over and the defrost water is flowing out the door and not the drain/ but do ck the pan under neath and make sure it's nt cracked and is in place . .. place some towles around the base to locate where the water is commong from .. mm
Apr 15, 2010 | Maytag 25.6 cu. ft. Wide-By-Side...
Maytag msd2454gr refrigerator how turn filter light off after replacing filter?
For some refrigerator models featuring
water filters, the Water Filter Change
Reminder function monitors the life of the
filter and provides a reminder when it is time
for the filter to be changed.
When the system detects either 12 months
of usage, or the filtering of 416 gallons of
water (whichever comes first), the CHANGE
FILTER
indicator light will illuminate. This
indicates that the water filter should be
changed and the light reset.
To reset CHANGE FILTER light: Press and
hold the LIGHT and LOCK pads until the
CHANGE FILTER light blinks (approx. 3
seconds). The control is now reset for 12
months or another 416 gallons.
Note: The Water Filter Reminder will
operate if the filter bypass is in place.
Nov 23, 2009 | Maytag MSD2454G Side by Side Refrigerator
Turn off the change filter light on maytag refrigerator
For my Maytag Refrigerator Model # MSD 2756 GE, I had to hold the "Light" & "Lock/Unlock" buttons simultaneously until the "Change Filter" light went off instead of the "Water" & "Lock/Unlock" buttons.
Oct 09, 2009 | Maytag MSD2651 HE Side by Side...
Our Maytag icemaker stopped making ice suddenly after we changed the filter. It dispenses water only.
Does the water have a good flow ? Did you try putting the old filter back in ? Never change the filter just because a little red light comes on . Only replace when the ice cubes get small or the water dispensor flow gets slow . I have found new filters that were bad . Distributors make a lot of money for filters just because of that little red lite . Not just maytag , but all other brands also . Try pouring about 1/2 cup of water into icemaker . If it dumps the cubes but doesn't fill , replace the water valve . If it doesn't dump , and holds the cubes for a long period of time , replace the icemaker . Also , you may need to clean the coils of dust , lint , etc....
Aug 20, 2009 | Maytag MSD2732GR Side by Side Refrigerator
How do I turn off the "change water filter light" on the door? I just changed the filter
Hold the lock and light buttons in together for 3 secs. or so and the light will go out! You don't even need to change the filter to do this.
May 02, 2009 | Maytag MSD2732GR Side by Side Refrigerator
Trying to repair water dispensor
Check/clean/replace dual water inlet valve/solenoid.
Nov 30, 2008 | Maytag MZD2766GES Side by Side...
Refrigerators Logo
60 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
