Question about Hotpoint Dryers
Bad squeak, could not get to stop. . oiled the belt(
I know bad idea, now the drum won't even move. What do I do to get the drum to move again. Hotpoint Large Capacity
  • dhughes0815 Apr 20, 2009
    Thank you very much for your help!
  • 744 Answers
If you oiled the belt, it may be slipping and can no longer grab the drum to make it rotate. It should be replaced. Also check the belt tensioner and other rollers as well as the main drive motor. The drive belt pulleys, drum, and other supports should be de-greased before you replace the belt so they don't accidentally get contaminated from any residual oil.
Posted on Apr 20, 2009
My kenmore 84052 is making a squeaking noise
DRYER MAKES NOISES.
The pulleys or rollers. Check for cracks, dryness, or damage and not engaging drum properly. Sometimes u can use high density gear grease to re oil/grease them.
The bearings by moving drum by hand u may be able to feel loose or rough movement. And listen to sounds when turning it.
The belt loose or worn can make funny noises
The glides on drum worn and making metal to metal contact.
CHECK FOR LOOSE BELLOES inside the drum
Aug 14, 2014 | Kenmore 84052 Dryer
Squeaking while driving
jack up each wheel and turn them see if noise is comeing from wheel moveing or could be in drive train or worn out brakes squelers going off
Dec 12, 2011 | 2004 Kia Sedona
Dryer squeaks
the rollers or belt idler may be corroded, use mineral oil or special bearing lubricant. DO NOT USE WD-40 OR 3 IN ONE OILS. you may find that they may need replacement.
Feb 09, 2011 | Frigidaire FEX831CS Top Load Stacked...
My dryer squeaks
First you should try to determine what the squeak is related to, does it happen every time the drum rotates or more frequently. This will give you some idea of where to look. You should disconnect it , take off the top and get someone to rotate the drum by hand while you listen. Moving parts are dangerous don't put fingers in. Commonly the outer drum bearing or belt idler need lubrication. Don't lubricate the belt. More details if you provide more clues.
Jan 13, 2011 | Frigidaire Dryers
My dryer was squeaking really bad, so I sprayed WD 40 on the pulley & belt, squeaking stopped but the dryer also stopped turning. The pulley still turns but the dryer drum doesn't
The belt is slipping now. Need to clean the WD40 off, use methylated spirits, isopropyl or rubbing alcohol on a cloth.
Jan 02, 2011 | Dryers
Very loud squeaking noise - like a noisy loose fan belt on a car.
The dryer needs to be rebuilt, new drum belt and drum rollers to cure this problem.
Mar 24, 2017 | Frigidaire FDE336RE Dryer
When we start our dryer it makes a loud noise as if it struggles to get the drum moving. Once the dryer is moving it has no trouble moving, but every time we start it, the noise happens again even if i was...
Is this noise like a loud buzz or hum? If it is it may be the motor draging
and can't quite get going. bearing getting worn.
Also check drum rollers or glides and the idler pully one of them may
be dragging if they are you might put a little high temp oil on it.
Hope this helps..
Jan 25, 2010 | LG DLE2532W Electric Dryer
Frigidaire dryer model # FDEB34RGS2 Squeaking
There is a tension pulley that holds pressure on the belt, as well as wheels that the drum sits on. A drop of oil on the bearing of each one should solve the problem, unless the wear has gotten too far, and need replacing.
Jan 01, 2010 | Frigidaire GLER642A Electric Dryer
Dimming lights and slowing wipers ????
The squeak noise is probably a belt. Most likely it has moisture underneath it that evaporates once the engine gets warm. Its a good idea to change your belts every couple of years, just make sure you use a Gates brand belt. Mazda engines are particular about their belts. May be a good idea to change the timing belt too, about every 60,000 miles.
Feb 24, 2009 | 2003 Mazda Protege
Dryers Logo
62 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
