Question about Acer Aspire 3690 Notebook
Battery stopped charging
Averatec 3280
Ran System Recovery 2x last year
Attempted battery calibration 3x this week, without luck
Battery is not charging at all
Is there another way I can attempt to get my battery recharge, or is it simply time to purchase a new one?
Thanks so much!
batterie light blinks but does not charge battery, if unplugged from wall computer will go off until plugged back in
  • 64 Answers
Yeah It Sounds like the battery is just had its last charge they only last for about 300 charges a piece i would get a new one go for at least a six cell they will last longer...Let me know if this works for you.
Posted on Apr 20, 2009
Hi,I used to be able to use my laptop (acer aspire 5733) for more than 3 hours, but now it barely lasts an hour! any idea how I can calibrate it without damage???
If your laptop is a little old even only a year or 2 old, then the battery is just wearing out and you will have to get a new one. Unfortunately laptop batteries only last a few years before they really lose their charge even with good care. To try and make it last longer use the battery managment if you havent already.
Jun 11, 2013 | Computers & Internet
S2046 low battery tried to start. Replaced battery now no sound, no start. Yes did hook up correct cables. Where can I find images of safety switches?
When trying to start with a low battery the engine Sometimes will stop on the top of the firing stroke putting it under extreme compression..almost like being stuck..you must turn tne engine backward a little just enough to get it off the compresdion stroke then try and start..This very same no click no nothing even when jump start happened to my cub cadet this summer after trying to start with a low battery...i used a pipe wrench and turned the dry shaft back and it started..then and all summer...give it a try good luck..
Nov 14, 2012 | Briggs & Stratton Starter Scott's Equip...
Averatec 3120V - AC adapter light blinking, no charging
get another ac adapter or check if the power dc jack is loose.
Apr 01, 2010 | Averatec 3120V Notebook
Armada E500 notebook Power button not responding.
Unless you took the batteries to a service center, I am dubious about your ability to confirm the main battery is holding a charge. The average lifespan of these kinds of batteries range between 3-5 years and is likely at the end of its lifespan. This would explain the diminishing performance over the last year if there were significant power or power circuit issues, they would likely be observed on AC power as well. This model of laptop requires the battery calibration utility be run in order for the laptop use the battery. In fact, the battery can show a full charge and still not function if the utility and battery have not been properly configured.. . . instructions on HOW TO do this below. If this doesn't FixYa then the battery will need to be replaced (links to replacement sources) www.BatteriesOvernight.com/HP-Batteries,----- OR --- www.new-laptop-battery.com/Compaq/?Compaq-Armada-E500-battery.htm. You will still have to run the configuration utility when you receive your new battery.
Link to Armada e500 manuals:http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c01124216/c01124216.pdf
How to run config utility: Standby and hibernation must be disabled for the battery to discharge completely and shut off. To use the Battery Calibration utility, first identify whether the battery requires calibration by launching the Power Management applet as described above. On the Battery Calibration tab, all installed batteries will be displayed in the primary list box. Next to each battery name will be an indication of whether calibration is required for that battery. If calibration is necessary, the phrase “Needs Calibration” will be displayed. Select the battery to be calibrated, and click the Start Calibration button. During calibration, the utility will display an icon on the Windows System Tray to indicate that calibration is in progress. Each phase of calibration (charging or discharging) will also be displayed. Calibration is complete when the icon is no longer displayed in the System Tray. Battery calibration requires several hours for completion. If you choose to continue using the computer during the calibration process, it must be connected to AC power. The calibration process must be allowed to finish without interruption. Performing any of the following actions will prematurely terminate calibration:  Clicking the Stop Calibrating button in the Compaq Power tab.  Unplugging AC power from the computer.  Unplugging the calibrating battery. (This action may result in data loss if a second battery is not installed.)  Undocking the computer.  Pressing the power or standby button.  Powering down or suspending the machine by using the Windows menu. IMPORTANT: If the calibration process is interrupted, it cannot be resumed. You must restart the computer and start the process again.
CALIBRATING WITHOUT THE UTILITY To calibrate a battery on computers without the battery calibration utility, complete the following steps: 1. Remove the second battery, if present, so that only the battery needing calibration remains in the computer. 2. Dock the computer or connect the computer to AC power. 3. Turn on the computer. 4. Check the current battery capacity level by positioning the cursor over the battery icon in the system tray. 5. Allow the battery to charge to 100%. You may use the computer, but the recharging process will require more time. 6. Set the system to “drain” mode on the battery conservation settings by pressing Fn+F7, or select Start > Settings > Control Panel > Power (or Compaq Power in Windows NT). 7. Undock the computer or disconnect the computer from AC power. 8. Restart the computer in MS-DOS mode by clicking Start > Shut Down > Restart the Computer in MS-DOS Mode > OK. 9. Allow the computer to discharge until it shuts off. 10. Dock the computer or reconnect AC power. 11. Allow the computer to charge again to 100% as in Step 5.
Feb 19, 2010 | Compaq Armada E500 Notebook
1050 EB-1 not charging batteries.
Give Fremontek a call (I have no affiliation with them)
They know Averatec's better than anyone else I know, and can frequently diagnose via phone.
My bet is that youmight be able to "reset" or may need a power management board.
[url=http://www.fremontek.com/]FREMONTEK[/url]
Dec 21, 2009 | Averatec 1000 Notebook
Does the Citizen Calibre 2100 have a battery that i can change, its been in my top draw for over a year and has stopped working, i have left it in the daylight to charge but the eco drive needle is still...
Citizen EcoDrive does not have calibre 2100. This is ordinary quartz calibre and uses battery SR-626W. This battery will last for 2 - 3 years and is not rechargeable.
You can check for yourself using this link:
http://www.citizenwatch.com/CUK/English/home.asp
Rate me, please.
Jul 28, 2009 | Citizen Calibre 2100 AV0031-59A Wrist...
Dell Inspiron 1000 starts up, loads OS and shuts down.
You will have to press F2 for setup, and make the optical drive (or the cd drive) the first boot item.
Mar 17, 2009 | Dell Inspiron 1000 Notebook
Averatec 3280 unmountable boot volume
You can install Windows XP from your CD drive, you may have to change the boot order so you can boot up from the CD first.
Nov 22, 2008 | Averatec 3200 Notebook
New battery needed!
The Everex SA2052T uses the same battery as a Averatec 2260 (2200 series) laptop. I purchase one from provantage.com this week. The battery is made by BTI and the model number is AV2200. It works perfectly.
Nov 17, 2008 | Everex StepNote SA2050T Notebook
New battery runs down fast
bad battery.. RMA that back to where you bought it from. probably wasnt a new battery they sold you. id charge it from completely dead to completely full one more time and if you dont get at least an hour out of the batt then i would return it..
Jan 18, 2008 | Averatec 3200 Notebook
Acer Aspire 3690 Notebook Logo
153 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
