Question about Lexmark Z53 Color InkJet Printer
Z53 light flashes but will not print..reset ink cart twice
Will not print cart slam to left side
  • Lexmark Expert
  • 228 Answers
Please follow the instructions given below:
1. Disconnect the USB cable and the printer power cable.
2. Please disconnect the power supply from the back of the printer.
3. Then remove the cartridges from the printer.
4. Please reconnect the power supply back and turn on the printer.
5. If lights are blinking then printer encoder strip is most likely the problem. Unplug the power from the printer. Open the front cover and move the cartridge carrier to the center. You should see a white ribbon cable, a thin plastic strip and a black belt with teeth.
6. The thin plastic strip is the encoder strip. It rides in a sensor on the back of the cartridge carrier that you will not be able to see. Reach in with the first finger of either hand and carefully strum the strip as if playing a guitar.
7. The strip will need to be lowered slightly and brought towards you slightly. Please be careful not to break the strip or your printer will not function. Once you believe the strip is set correctly, plug the power back and let us know if the lights are still blinking.
8. If you cannot repair the strip, please let us know so that we can assist you further.
Please Note: Fixing the encoder strip is a delicate procedure. During the troubleshooting, if the strip breaks, you will not be able to use the printer. We will replace the printer, only if it is under warranty.
9. However, if lights are not blinking then try inserting one cartridge at a time and check if you can see any lights blinking. If light blinks with one cartridge then that cartridge is defective.
Posted on Apr 21, 2009
Power light (or Alarm and Power lights) alternate(s) between orange and green After long green flash, there are 2 or more alternating orange and green flashes. There may also be a Service Error message on...
Try resetting the printer by unplugging the printer from the power source for 5 mins. and they make sure ink is full and paper is loaded and not jammed. If not resolved carefully remove all ink cart from machine without touching and ink cart metal contacts, reseat the ink cart and reset and the printer.
Feb 21, 2010 | Canon i850 InkJet Photo Printer
Printing
Check on your color (not mono) ink levels. If they are low, this could cause this.
Technical info: On this printer, envelope text is printed in "composite black" which means we mix the colored inks to make black. This is done for envelopes and not letters because of the ink properties which resist water and smear. If one of the colors is low, you'll get something other than black.
Mar 24, 2009 | Lexmark Z53 Color InkJet Printer
Cx5500 all in one and use T0731-4 ink cartridges
If you are using a compatible cart and the printer has twice reported the cart as empty when they are new, chances are there is a problem with the printer. You can buy a chip reseter off ebay for a couple of bucks and try resetting the cart. If the machine still reports the cart is empty you either have dodgy chips on your carts or the printer is having problems reading the chip, This could be caused by a bent pin/contact in the print head cartridge receiver.
Feb 09, 2008 | Epson CX4200 All-In-One PSC Printer
C3180
The issue is with the hardware malfunction of the All-in-One. Please contact HP customer support and get it replaced.
Thanks
Dec 23, 2007 | HP Photosmart C3180 All-In-One InkJet...
Printing problems
I've seen the head banging problem before. If the printer is out of warranty the only solution is replacement.
Nov 11, 2007 | Lexmark Z53 Color InkJet Printer
Ink Cartidge reset
I ahve the same problem can anyone help it keeps slamming !!!!!
Nov 07, 2007 | Lexmark X83 All-In-One InkJet Printer
Edweard
Take all carts out. Close cover. Unplug machine from power. Wait a minute. Plug in machine to power. Machine demands carts. Insert new (!) cart as demanded from machine. In case when asked push 1 for YES: cart changed.
BTW:
Always print until machine stopps printing. Display says NO INK XY. After replacing the cart machine will print the rest data out of its memory.
NEVER change cart when machine says low ink (This is only a hint to buy a new cart!). At this point the cart has about one third of ink left!
Nov 01, 2007 | Brother MFC 420CN All-In-One InkJet...
ERROR CODE FOR FLASHING LIGHTS
Hi, Kindly remove your carts then replace then again. try this 2 to 3 times repeatedly. Hope This helps ======================= If you are having trouble with Newly bought items then return them and demand a replacement or a refund! You may have purchased a reconditioned\repaired\factory defect product.
Sep 20, 2007 | HP Deskjet 460c InkJet Printer
Lexmark Z53 Color InkJet Printer Logo
308 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
