What could be wrong with a Wurlitzer D-172 Concert digital music system, that only hums when poer is on.
  • jrb108 Apr 20, 2009
    Thanks for the info,I am not where the organ is located. My Friend says it has always had a hum when turned on,but it was moved from the house to another room and there is no music.
    Jrb
    Thanks for your quick response.
    jrb108
    Genius:
  • 1,689 Answers
Hi jrb,
a great piece of instrument i may say.
the humming is usually cause by a loose connection on the input that causes ground, which as an output causes the humming sound.
The d-172 is digital, but tone generation uses analogue.so this will provide you limited areas to check. if you have the instrument opened, you may want to carefully vacuum clean it and have the lines checked starting from the on/off circuit to the tone generators.
as far as diagram goes. this instrument was released in 1981, and the repair manual is a little expensive but if you have one, you can refer to is on what is the best way to check a loose line in the instrument.
good luck, i sure hope you get this one running. (and post some pictures of it :) )
thank you for using fixya.
regards,
voodoo
Posted on Apr 20, 2009
  • marlon john madrid
    marlon john madrid Apr 20, 2009
    thanks for replying jrb,
    we are looking forward to getting the issue resolved. please let us know of any progress when you are in the location where the organ is.
    feel free to accepts any solution posted for your question and thank you for using fixya.
    regards,
    voodoo
Wurlitzer C200 organ, volume pedal does not work, the Great keyboard is at full volume. Can't find anything online. Can you help me find information on repairing/replacing the volume pedal?
full volume ??? hum that's funny , as if pedal has broken one would suspect that it would go to lowest volume and stay there , 1st id ck to make sure the "bright" switch is not on or stuck on then id dive into taking the cover off the pedal assembly , for a look around to see if somethings obviously not right in there (hanging springs, swinging levers, etc)
Oct 13, 2016 | The Music
OXX Digital sound Bar problem.Humming noise coming from speakers across all functions
Same problem here, low humming from far left and right speakers. Crank volume up to 40 gets rid. Shame this was is a good setup. Now to find my receipt and and make the most of the Aldi 3 year warranty. I have tried it in different poer outlets, with no discernible change, change func from ipod, to radio to aux same issue, my guess is faulty units
Aug 11, 2013 | Audio Players & Recorders
Low sound an hum from turntable with cobra tone arm 1955 wurlitzer but when another source is plugged in to aux in works fine. What could be causing this? Changed all the caps in this unit.
Hi, I believe I know what's causing this-It sounds to me like you have an open ground somewhere between your cartridge and amp. A headphone cord should make an acceptable substitute for the original wire if exact replacement is unavailable. I have heard many a hum in my day. I think this helps, Good luck and thanks for asking FixYa, Prodzilla
Apr 19, 2011 | Wurlitzer Green Zenith Cobra Cartridge...
Heeelp > My 1960 wurrlitzer jukebox is dead ?
you really need a service manual you can get it at jukeboxworld go to archives then wurlitzer then choose your model
Mar 31, 2010 | Wurlitzer Jukebox Princess 120-Disc CD...
When i put in 4 digit code on my renault megane my radio does not respond after its battery was charged, the battery was disconnected for to get charged.
It is either the wrong code or you are entering it incorrectly.
To get the code checked
POST ANOTHER QUESTION
quoting the radio MAKE+MODEL plus ALL the LETTERS+NUMBERS on ANY LABELS ,BARCODES or STAMPED IN THE METAL CASING
A Renault normally has a 14 character Serial Number beginning with
RN++++++++++++  plus a Security Code in the format TOX123 or TX123 or just X123 at the end of a barcode ...so please quote EVERYTHING you can find.
The code entry instructions  for a Renault / Philips radio  are Philips Renault Code Entry
Turn on the radio and the display will show 'CODE'
Use the steering controls for code entry.
Press the [ ¬] button then rotate the thumb wheel for the correct first digit
Press the [ ¬] button then rotate the thumb wheel for the correct second digit
Press the [¬ ] button then rotate the thumb wheel for the correct third digit
Press the [ ¬] button then rotate the thumb wheel for the correct fourth digit
If the correct code is now shown on screen
Oct 20, 2009 | Vehicle Parts & Accessories
Radio code for model 22dc278/62b prod fd0201480096261 toa559rn278f10096261
Your code is 0484
Press the [ ¬] button then rotate the thumb wheel for the correct third digit
If the correct code is now shown on screen,
press and hold the [ ¬] button for up to 10 seconds to store the code
Sep 12, 2009 | Vehicle Parts & Accessories
Earth hum
You need an earthing isolation unit. I'm not sure how it works but that's what you need.
Dave F.
Jun 22, 2009 | Wurlitzer Jukebox 1015 One More Time...
Bose lifestyle fault code 802
Here's what the Bose support website suggests.  Good Luck!
Messages displayed during a Music Information Update
Messages may appear on your media center display during a Music Information Update. If you see a message with instructions to call Bose, and a three-digit code such as "Error Code 802" or "Failed 172" while performing a Music Information Update, it does not necessarily mean there's something wrong with the system. Performing a media center reset and installing the update again may address the issue.
To reset your media center, follow these steps:
  1. Turn the media center off. Wait two minutes
  2. Unplug the power cord from the media center. Wait 30 seconds
  3. Reconnect the power cord
  4. Wait until "Bose Lifestyle" disappears from the screen
Note: After a reset, you will need to wait several minutes before playing stored music (3 to 20 minutes, depending on how many CDs have been stored). All other sources will be available immediately after the system powers up.
If you have any additional questions about these messages, please contactBose® Technical Support or call 1-800-278-1281.
Dec 01, 2008 | Audio Players & Recorders
48 people viewed this question
 Grubhead
Grubhead
