Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Frequent bsod problem
Bsod problem
Please Post information about the BSOD for help, codes, messages, anything is helpful.
Posted on Sep 20, 2007
When I work on my laptop it suddenly shut down, blue screen, many written things, and
This sounds like a BSOD (Blue Screen of Death). Check for that in Google. Image at www.bsod.org.
Did that happen once or is it more frequent?
It could be heat, blow out the dust bunnies with compressed air.
If it is infrequent, it is a part of the price of using Windows.
If it is more frequent, try to see what the failures have in common. If you are always using the same program when it happens, see if there is an upgrade for the program.
More information will be necessary to solve this.
Aug 22, 2012 | Genuine DELL 250w SFF Power Supply For the...
Tip
Blue Screen of Death (BSOD) and Computer Restarting Constantly
A very common issue, especially with old computers, is that of crashing and frequent restarting of the machine.
A common accompniment to this issue is the dreaded Blue Screen of Death (BSOD).
The BSOD will tend to occur randomly and will not even let you reinstall the Operating System on the computer.
There are a few things suggertions I would like to share to help overcome this issue.
I suggest that you keep the machine shut down for some time (30 min) and allow it to cool.
Also, open the case and use a Vaccuum Cleaner to blow off the dust on the Motherboard, Power Supply, CPU Fan and other internal components of the CPU.
Try to keep the machine is an Airconditioned Room with the temp set to a relatively cool temperature.
In case airconditioning is not available, you might want to use a table-fan for blowing air into the unit.
These issues are mostly due to blown capacitors on the Motherboard.
The steps mentioned above will allow you to restore your operating system on the machine.
The BSOD and rebooting indicates a hardware error i.e faulty capacitors or perhaps issue with the RAM.
The permanent solution, however, is to replace the faulty capacitors with new ones.
I suggest that you visually inspect the Capacitors on the motherboard.
The blown ones will have a curved, arched top and perhaps a black, powdery, burnt look.
on Oct 09, 2010 | Computers & Internet
I am having frequent BSOD and also flash/shockwave player problems.. what to do ???
I can only assume that you have added some new hardware to your system recently. BSOD is usually an indication of a hardware conflict, caused by new hardware, Remove any new hardware and try again, BSOD can have other causes although hardware is the most common. Hope this helps.
Jan 12, 2012 | Computers & Internet
Blue screen frequently appears, and it reboot by itself? pavillion g7-1070us
A blue screen often called Blue Screen Of Death, BSOD, indicates that something is wrong with the computer. Usually it is a driver that is not correct or corrupt.
You need to specifically identify that the BSOD message is. If the system reboots before you can read it, boot the system while hitting F8 many times per second until you see a black and white screen with a number of options. Towards the bottom will be one regarding automatic restart on error. Uncheck that option. Now the BSOD will stay on the screen and you can post the stop code here to get help.
I hope this helps. I do this for fun & feedback not $$$
Jim
Oct 05, 2011 | HP Pavilion dv9000z Notebook
System BSODs when trying to boot from USB
fbeondo
To be able to properly address your BSOD I will need some info from the BSOD. The link below will show you the info that I need.
http://www.fixya.com/support/r4443711-blue_screen_death_bsod_important_info
Thanks
Issken
Jan 29, 2010 | CMS BounceBack Professional (096122800758)...
Plugged in the 1TB WD My Book Essential into my Dell Dimension 3100 running windows xp and the screen goes blue and I get a error stating "Bad_Pool_Header"
here's a solution I found on google:
BSOD the Solution:
Did you install Service Pack 2? Are you now suffering from the Blue Screen of Death (BSOD)?. Here is the solution. I have spent 4 days hunting down the cause of my machine crashing and have finally cracked it. Maybe other people have a different cause than mine so my solution may not work for everyone.
After installing SP2 I suffered many crashes. In particular the Screen would turn blue and display a message starting "Bad_Pool_Header". And ending with STOP: 0X000000019....
Then my four day hunt for the cause started.
BSOD Solution
Basically I found two causes of the BSOD.
Cause 1: Corrupted file or folder.
Cause 2: Microsoft Indexing Service
Possibly these two causes are linked.
Solution for Cause 1
Onen up Explore (right click the start button), and expand your directory tree, starting from the C: drive. Click on each folder in turn and see if any cause the BSOD to appear. If so, reboot, and simply attempt to copy the folder, and then delete it.
Solution for Cause No 2
Switch off Microsoft's indexing service. You can do this by clicking the start button, select "Run", then type "msconfig", then select the "Services" TAB, scroll down to the Indexing Service and Switch it off. Reboot your computer, and good luck - maybe it will work, It solved the problem for me.
At first I thought I must have a third party software or hardware conflicting with SP2, but even after I had disconnected the internet, switched off all items in the startup TAB of msconfig, was still getting the BSOD. I tried surface scans, chkdsk, scan disk etc all to no avail. I tried defragmenting the disk, but the frequent crashes may have made things worse.
I discovered the computer was now crashing after about 7.5 minutes of being switched on. It did not matter whether anyone logged in or not.
Finally I went to msconfig (Start Run, MSCONFIG) and switched off "process System.ini files, Load System files, Load Startup Items. And the comuter stopped crashing. So then I added the item back one by one until I discovered the Microsoft Corporation Indexing Service which was causing the crash. I switched it off and switched everything else back on and AT LAST... No more BSOD
Jan 01, 2010 | Western Digital My Book Essential 1TB...
Frequent BSOD
tehnicki_crt
Thanks
Issken
Nov 24, 2009 | ASUS A7V600-X Barebone Kit / ATX Mid-Tower...
Bsod on Startup
streylem
Thanks
Issken
Sep 26, 2009 | EA - Electronic Arts Need For Speed:...
A8N32 BSOD PROBLEM
I had a similar problem with this board after putting in a new sata drive I got Bsod as windows xp started loading.
There is some kind of conflict with SP3, Sata and usb.
The solution for me was to boot while having a 4GB usb drive pugged in. It starts up fine now. If I remove the usb drive it bsod´s again.
Dec 14, 2008 | ASUS A8N32-SLI Deluxe Motherboard
Hellooo.....
Well it's kinda hard to tell exactly what when wrong, but this is my suggestion you could try.
Uninstall your video driver, restart and reinstall the driver. If possible try to get the latest driver possible.
Mar 25, 2008 | ASUS P4S533-MX Motherboard
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
97 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
