Question about Garmin StreetPilot C330 GPS Receiver
Freezes up while in use
Aquires and calculates and runs fine for about 10 minutes then screen freezes ans seems locked out. only unplugging and plugging starts up again and the the frozen screen again after about 10 minutes over and over again
  • Anonymous Sep 21, 2007
    Thanks for the reply but I tried that and it did not work,However the problem was solved by doing a full factory reset but it wipes out your previouse information. this is done by First turning the unit off. Then press and hold the bottom Right corner of screen and then while still holding bottom right corner down press and hold the power button until yoy see the screen go white with a black dot. then follow the onscreen instructions until re-calibration is complete. I imagine this can solve many problems and cannot hurt regardless of problems.
Coincidentally I had exactly the same problem yesterday. Use the reset button behind the silver faceplate. Instructions in the manual. Mine now works fine and I didn't even lose my preset destinations.
Posted on Sep 21, 2007
SOURCE:
IBM R52 Seemingly Random Shutoff and gaming lag.
If you can increase the drams to maximum in your computer?
Mar 03, 2012 | IBM ThinkPad R52 Notebook
I'm using the Casio fx-115ES model. When i try to put in 52 Degrees, 10 minutes, I dont seem to be able to do this. I key in the numbers 52 then hit the "degree, minutes seconds" button and i get the...
When entering the information it only shows the degree symbol. If you press enter or type inthe formula, then the answer will show the Degree, Minutes, and seconds. It seems to be the way it was program by Casio. It still seems to work fine for entering that information
Aug 03, 2010 | Casio FX-115ES Scientific Calculator
Aquiring Signal displays for 5-10 minutes before hearing audio
It's a bad Sirius tuner. You can find them on ebay for 50 or so rebuilt and they are better than new. It's cold solder joints on the antenna input plug. Hope this helps
Jun 17, 2010 | JVC KT-SR2000 SIRIUS Radio Receiver with...
My computer won't connect to the internet - it says limited or no connectivity. The router and cords do work with a different computer. I have already checked for the IP address. What's next?
unplug your modem for abotu 10 seconds, wait a minute and see if it connects.
Still a problem - unplug the router (assuming you have one), and wait a minute while it reboots and aquires/assigns IP's.
Feb 20, 2010 | Dell Dimension E310 PC Desktop
Loses signal every 10 minutes or so. Screen says aquiring signal for a few seconds then it comes back on. Has never done this before
I hope this doesn't seem like a dumb question, but are you driving a different route and do you lose your signal when going under bridges, heavy tree cover etc.?
Feb 04, 2010 | Sirius STILETTO 100 MP3 Player
I get an error 8001002B
This is the code for disk error. Make sure the disc is clean and try again. If that doesn't work, try a different copy of the disk and see if that helps.
Jul 13, 2009 | Sony Playstation 3 (PS3) Console
Screen freezing - Not loading
HI, this will occur when there is a serious hard disk error. you can confirm by unplugging the unit for 5 minutes. this will reset the error reporting. once the five minutes are up, simply plug the unit back up and power the unit. you should get an error code or explanation.
Contact Sony for this repair.
Jun 19, 2009 | Sony Playstation 3 (PS3) Console
Sceen freezing after 10 min
just check ur power options .
may be turn off monitor after 10 minutes is enabled.
change it to none
Mar 26, 2009 | Toshiba Tecra 9100 Notebook
LCD screen looks like bad TV reception
if the display returns to normal when you press the bezel at on end means there is a bad connection to the inverter behind the bezel itself or the inverter is ready to give up the ghost.
you can attempt to dismantlethe laptop and remone the lid or in some cases just unscrew the bezel and remove the plastic cover, the inverter is at the bottom of the display you can't miss it
hope this helps
regards
Nov 18, 2008 | Acer Aspire 5601WLMi Notebook
2 year old Samsung 50" DLP
Sounds like a bad digital board to me. Not too hard to replace in those models but, you do have to write down a few settings before replacing it. These settings are available in the service menu. Any questions let me know [email protected]
Nov 30, 2007 | Samsung HLN617W 61" Rear Projection HDTV
Garmin StreetPilot C330 GPS Receiver Logo
271 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Sheldon Dedek
Are you a Garmin GPS Expert? Answer questions, earn points and help others
