I have a Kenmore Elite Catalyst. It has worked fine for the last 9 years. Then today I put a small load in, and when I went down to get the load out I found the letters LD flashing at me. What does LD mean? How do I get that fixed?
  • artedesco Apr 20, 2009
    Thank you for sending me this solution so quickly!
  • 234 Answers
This problem is most likely caused by a drain error. You probably have a kinked drain hose or it is partially plugged. "LD stands for Long Drain or the machine is not draining fast enough.
You can also call Sears customer support.
Here are some numbers that you can try:
National Customer Relations 1-800-549-4505
Sears.com order and product inquires 1800-349-4358
Home Services and Repairs 1-800-4-MY-HOME
(1-800-469-4663)
Parts orders and inquires 1-800-366-PART
(1-800-366-7278)
You could try to unblock the hose yourself. Make sure that the machine is unplugged for safety.
You may also want to unplug the machine and plug it back in and see if this resets the error.
Posted on Apr 20, 2009
  • Tim Phipps Apr 20, 2009
    It is also possible that something is blocking or stuck in the pump
KENMORE ELITE WITH CATALYST FILLED WITH WATER AND WILL NOT DRAIN AND SPIN
REPLACE THE DOOR SWITCH . IF THAT DOES NOT WORK REPLACE OR CLEAN THE DRAIN PUMP..
Apr 25, 2017 | Kenmore Washing Machines
Have Kenmore Elite Catalyst Washer showing F3.
I have a top load Kenmore Gold Catalyst Cleaning Action washer that is stuck on permanent press mode. The digital display reads 8 min. and will not turn off or clear.When it is turned on the, the timer goes to 37 minutes and beeps repeatedly through all cycles. It will not clear even when I unplug it. How do I fix this annoying thing!!? Thoughts please.
Bill
May 22, 2010 | Kenmore Washing Machines
Kenmore Elite Catalyst Washer Keeps beeping and displays 10
I'm not sure if you've solved this already but our Kenmore Elite washer had a similar problem that got worse. It ended up being the whole touch panel had to be replaced. I was able to diagnose and replaced it myself with help from the Tech sheet that is underneath the touch panel. Our Kenmore Elite dryer also had to have this paenl replaced several years ago when it was fairly new. Hope this helps.
Sep 08, 2009 | Kenmore 3.2 cu. ft. Top Load Washer
Kenmore Elite Catalyst washing machine getting error F4
See if this helps.
http://www.askmehelpdesk.com/appliances/washer-kenmore-elite-catalyst-110-20092993-f3-f4-error-codes-191730.html
Aug 01, 2009 | Kenmore Washing Machines
I did an online Chat with Sears today. (no
Honestly, on that machine, I don't have a clue where your clothes could go. It couldn't get under the aggitator plate unless it was so loose it was about to fly out. It doesn't do a flood rinse to send them over the top. And the pump in those units would stop up on anything. So they are not going down the drain. Besides the check balls would stop them.
jim
Jul 27, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore elite top loader washer won't start. Power is ok at the outlet Unit is 9 years old, model #110-20096993. Unit worked yesterday. It is a sensor smart three speed automatic washer with catalyst
Actually I didn't need a solution. The unit would not start. It was like no power was coming in. The outlet was good and usually if there is a power failute the unit flashes PF. Well I walked by in a couple hours later and and touched the start button and it worked. Got two loads of wash in. It must
have a loose connection or a dirty connector, but I'll wait until it happens again
Thanks
Jun 23, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE3 front load dryer no power
Yes. Remove the kickplate and check the continuity of the thermal fuse located on the blower housing.
Feb 23, 2009 | Kenmore Dryers
Kenmore Elite HE4t Washer Control lock lit, door locked
121 MINUTES USUALLY DRAIN CYCLE PLZ REMOVE 3 BOTTOM PANEL SCREWS 7 MM SCREWS, TO OPEN DOOR SLIDE RIGHT HAND TOWARDS DOOR LOCK ,THERE WILL BE A SMALL LEVER TOO PULL DOWN ,NOW ITS OPEN,,, SINCE U HAVE BOTTOM PANEL OFF PUMP IS RIGHT IN FRONT REMOVE PLASTIC HOUSING CLOCKWISE ,,,REMEMEBER HOLD 3 GALLONS OF WATER STILL ,HAVE BUCKET READY ,NOW CLEAN OUT PUMP AND DEBRIS ,, CLOSE IT UP SHOULD BE FINE NO MORE PROBLEMS ,,,,,
Jan 01, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite Calypso won't drain
CL or CA is an over amp draw most likely caused by the motor thermal protector or motor controller It can be caused by too large of a load try to press "STOP/CANCEL" to clear if the problem returns you will need to get inside the unit
Jul 09, 2008 | Washing Machines
Kenmore front loading HE3 makes knocking sounds during spin cycle
Ours started knocking several months ago and then progressed to a high pitched sound when in the spin cycle. I manually turned the drum and heard and felt a bearing roughness. I lifted the drum assembly and felt a fair amount of play, which I think the initial knocking noise came from. On the sears web site a new rear drum mount cost 293.00. Today we went and bought a LG model wm2455hw at Home depot, on sale until 2/20/08. I couldn't see paying to repair a machine that only lasted four years.
Feb 17, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
47 people viewed this question
Top Washing Machines Experts
