Question about Whirlpool LER5636P Electric Dryer
Elkectric dryer won't start
Just got a Whirlpool model LER4634PQ0 electric dryer which has a four prong plug. My house has 3 prong receptacle for 220 v dryer. Changed receptacle to a 4 prong, but left white terminal blank since only three wirtes in the box. Dryer now won't start. Sgould a remove the 4 wire plug and replace with a three wire plug and the original receptacle? ... or what?
    Scholar:
  • 126 Answers
To put it kindly depending on way you connected wires unit could be damaged,replace pigtail with three wire and outlet to original.outlet wires should be black,red and white. turn breaker off attach white to middle and red,black to sides,"either side is fine".Attach dryer pigtail in same manner with white on white and if plug in and turn breaker on.If there is no operation at this point dryer possibly damaged from previous wiring.Just remember be safe when working with electrical and ask before trying to change things that aren't the same.
Posted on Apr 20, 2009
Frigadare Dryer
Basic Dryer Electrical
Electric dryers in the US operate on two 110 volt A/C circuits. The two 110 volt circuits combine to deliver 220 volts A/C to the dryer heater. 2-dryer-plugs.gifSee the basic dryer heat circuit. The dryer motor operates on 110volts A/C. Dryer receptacles have an L-shaped neutral post. You can check the voltage to your dryer by slightly sliding the cord out of the receptacle and using the leads from a multi meter to check for voltage on the blades of the cord that slide into the receptacle. Between the left and the right blades you should read 220 volts. Between the left or right blade to the center blade (the L-shaped blade) you should read 110 volts AC. The 4-post receptacle above has the L-shaped neutral and a seperate ground. It requires a 4 wire cord and the ground wire is isolated from the neutral on the dryer.
Technicians check for voltage when the dryer is attempting to start or not heating for a very specific reason. Checking for voltage without the dryer plugged in does not tell the full story. A dryer heater uses 220 Volts and draws about 20 amps when it is heating. Checking for voltage from L1 to L 2 on a defective circuit may show 220 volts but when the heater kicks in and starts to draw 20 amps the voltage may drop off to 0 volts. Imagine the wiring to your dryer was stranded wire. Stranded wire is composed of a number of small-gauge wires bundled together to make a larger wire. What if all but one of those stands were cut and only one small wire was completing the circuit? Reading voltage at the receptacle without the dryer plugged in you would read 220 volts from L 1 to L 2. However with the dryer plugged in and the heater attempting to draw a heavy current, the electrons (current flow) would be dammed up behind the cut and only a small amount of current would pass through the wire. Certainly not enough to make the heater heat. There are a lot of things that can cause a partial circuit but the result is the same as the stranded wire example. Many a heater or dryer motor has been changed needlessly because of a loose connection in the fuse box / circuit panel or some other dryer electrical circuit problem.
Aug 20, 2008 | Frigidaire GLTF2940ES Front Load Washer
How do you change a 4 prong dryer plug down to a 3 prong power plug
Today's newer electric dryers now use a 4 prong plug. If you try to relegate your new dryer to the old 3 prong hook-up that you currently have in your house, you will have issues with your dryer. Instead, I recommend you update your house's wall receptacle to the newer 4 prong terminal and keep that new dryer warranty intact. Douglas
Sep 05, 2010 | Whirlpool LER5636P Electric Dryer
Got a used dryer had a 4 prong my house is 3 prong, changed the 4 prong to 3 prong plugged in and wont turn on, what do i do?
There is a difference between how a 3 prong and a 4 prong power cord is installed. Please read the following link:
http://www.fixya.com/support/r3575913-installing_a_220_vac_appliance_cord
If you have the power cord installed correctly and still do not have power, please check for 220-240 VAC at the wall receptacle. If you require additional assistance, please post back with your MODEL NUMBER and let me know. I hope this helps you.
Aug 05, 2010 | Kenmore 64902 Electric Dryer
My dryer has the wrong 3 prongs plug on it that are curved and the outlet in my wall is straight how do i change the cord
Don't change the cord, you need the correct twist-and-lock wall receptacle installed.
It is 220 volts dryer.
Dec 06, 2009 | Whirlpool GEW9250 Electric Dryer
Replacing eletrical cord to a four prong cord. there are only three connections. there are no color codes to make it easier. How do I replace the cord
Dryers are 220 Volts AC and the outer connections inside the dryer are "hot" or live legs (black or black and red wires) of the circuit, while the center one is typically the neutral (white) wire.
The difference between a 3 prong plug and receptacle and a 4 pronged one is simply that the 4 prong plug and receptacle has a dedicated ground integrated into it, whereas the 3 prong plug is what's commonly referred to as an ungrounded circuit. There is no dedicated ground in a 3 prong plug and receptacle that makes a separate, grounded connection from the dryer to the receptacle to the electrical panel of the house.
Also, please look at either the back of the dryer for a basic wiring diagram, or look inside the access panel where the dryer cord is connected. There should be indications as to what each terminal is for, as I stated, typically the outer connections are the "hot" while the center one is typically the neutral. If you notice a strap running from one of the dryer's connection terminals to the cabinet/frame of the dryer, that is the neutral. The others are the hot terminals, which are the outside ones.
Look for a green grounding screw inside the dryer's electrical connection section. That is where the green wire on the cordset would be connected/terminated.
If you wish, you can get a free Installation Guide for your dryer at the following link to download and/or print out at:
http://www.managemyhome.com/mmh/lis_pdf/INSTL/L0520950.pdf
It will show you the connections for both a 3 and 4 wire cordset.
Hope you find this Very Helpful and best regards!
Nov 29, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Installing a four prong plug
best bet would to be to buy a plug that matches your receptical.....this is somthing you do not want to monkey with as if not wired right could turn your dryer into a fire hazzard. white to white green to green black to black and the other wire goes to earth ground for like trailer houses and modular homes.
Nov 23, 2009 | Whirlpool Dryers
My 220 plug is a three prong and the used dryer I bought has four prongs. Is there some type of adaptor I can buy to connect the two plugs such as what used for adapting a 110 line that has two different...
Hello Doris, You really don't want to get an adpater for this, (even if you could find one - they're not at all common) since the thickness of adding in an adapter would make the dryer stick out further from the wall, etc.
What you need to do is to get a new "pigtail" for the dryer that has the three (3) prong plug that matches your 220 Volt-AC wall outlet. These are available at most Home Depot, Lowes, Sears, or at any appliance or Hardware store. They don't cost all that much and will provide you with the correct plug and cord set for your house's electric dryer outlet.
The four (4) prong cord & plug has a separate ground wire in them, while the standard thre (3) prong plug uses the netural as the ground, or has a separate green wire running from the dryer cabinet to either a grounding screw on the wal plate, or to a ground ******** a water pipe (typically found in older homes)
Just be sure to unplug the dryer before changing the cordset out for the 3 prong one. Make sure the power is also off at the breaker panel too. Now at the rear of the dryer there is a small access panel where the cordset goes into the dryer. Remove that panle and you'll see three (3) connections on the panel along with a Green Grounding connection.
The connectors that get the power are the outside connectors, these are "HOT" and get 120 V-AC each (120 x 2 = 240 Volts AC) while the connector in the middle is the NEUTRAL connection point.
The wiring is straightforward and there should be a simple wiring diagram either on the access panel or the connection points should be labeled for each of the wiring fasteners (screws or nuts)
Just be sure to get the fasteners tight, and the new 3 prong cordset you buy should be long enough to reach from the dryer (when it's pulled away from the wall) to the house outlet. Typically they come in either a 3-4 foot length or the longer ones are 5-6 feet long. If in doubt, get the longer cordset. You can also check the wrapper of the new cordset, as they provide a simple wiring diagram also, to help you install it correctly.
http://z.about.com/d/electrical/1/0/r/0/-/-/DryerElectricalConnection.jpg
Just be sure to add the included strain relief, as instructed, onto the cordset and put the access panel back on when you're done and you'll be all set to use that "new" used dryer!
I hope you find this Very Helpful and best regards!
Nov 16, 2009 | Maytag PYE2300AY Electric Dryer
Four prong plug to three prong plug
Is the receptacle in the wall a four prong or three prong. You will have to match the cord on the dryer to the wall recepticle. If the wall is four prong the dryer cord has to be a four prong. The green wire with the yellow line, that is on the end of the dryer cord, is a cabinet ground and should be attached to the cabinet of the dryer and making good contact. The other three wires on the end of the dyrer cord attach to the terminal block.
Jul 08, 2008 | Whirlpool GEW9200L Electric Dryer
Dryer electric cord
The national electrical code requires the installation of a four wire system for ALL 240 volt equipment. He will be putting in a four wire dryer receptacle. The pigtail you'll need will be a standard four wire pigtail. The way it is connected is: the red and black go to the two outermost terminals, the white goes to the center terminal and the green goes to a good chassis ground point. If there is a jumper strap from the center terminal to the chassis ground point it must be removed.
Oct 01, 2007 | Dryers
Whirlpool LER5636P Electric Dryer Logo
227 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
