Question about Pentair Mastertemp Heater
Heater cycles on and of, pool/spa does not reach desired temp
Heater cycles on and off(heater service light comes on) about every 60 to 70 seconds. Desired temp never is reached regardless of spa or pool selection for heating.
    Novelist:
  • 90 Answers
Hello, It sounds like you may not be getting circulation thru the heater. Make sure the valves are open to allow water to pass thru the heating system. Some systems use a bypass on the heater so there is not a lot of wear on the coil system in the heater. If it is not circulating it will get too hot and the safety shut down will occure. If you are getting water circulating thru the heater, then the thermocouple or auto start igniter system is not working correctly. It is trying to start and can't then recycles. If the burners are igniting on the startup and then shutting back down you may have a bad control unit or thermal sensor unit. Since the unit is gas have a professional service it for you. Good Luck, RAC
Posted on Apr 20, 2009
I have a laars jandy 250 lt gas pool heater that only heats luke warm. The heater cycles normally then heats up but stops before reaching operating temp. No service lights and thermal switches are g
I do not have a handy but mine has a temperature setting at the heater and one on the remote. it is possible that one of the settings is low. the pool or spa temp is sensed at the heater and with the water temp located in the pool lines. so both the control board and the heater are sensing the water temperature.
Oct 09, 2014 | Jandy Laars Lt 250,000 Btu Heater
Pentair mastertemp 200 cycles on and off within 1 degree of set point
try calibration that might take care of problem otherwise sounds like new board
Apr 18, 2014 | Pentair Mastertemp Heater
Gas shuts off befor pool or spa reaches desire temperture. Changed temperture senor, still does same thing
if using a aqualink go into calibrate you can move 4 degrees each way also you can calibrate in heater or move water temp sensor if on aqualink
Nov 07, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
Pentair matertemp 400,000 BTU heater cycles on & off
My pentair matertemp 400,000 BTU natural gas heater cycles on and off before reaching desired temperature. I completely cleaned the DE filter and flow should not be an issue. When running the spa the pressure is 25. When running the cleaning system (polaris pop ups) the pressure is 30. Burner fires for 80 seconds then shuts off, reignites after 53 ceconds.Any tips on what might be the issue with the heater
Apr 04, 2010 | Pentair Mastertemp Pool & Spa Heater Dual...
Heater reads spa water 15 degrees higher than it is
if a 3 wire system put pool at temp desired and spa at 104 if 2 wire to firemans switch run heater all the way up to 104 the system will control the temp
Feb 22, 2010 | Jandy AquaLink RS2/6 All Button Dual...
Pentair Heater shuts off prematurely when warming spa
check gas pressure could be running out or overheating
Mar 06, 2009 | Pentair MINIMAX NT TSI IGNITER
Service light on
I just had the same problem resolved, my mastertemp 400 would run up the temp to 82F and then cutoff, the service light flashes and then 50 seconds later the heater would restart and run for 2 minnutesbefore shutting down again and relighting in 50 seconds. Repeating until the temp setting is reached.
I had the pool guy out 3 times until he found a bad thermal regulator valve (kit #77707-0010). Once replaced the heater runs great.
He told me that it's my pool chemestry that is to blame, I had it checked (like I do weekely by me and monthly by the pool supply store) and it perfect??? I'm now questioning what caused the corroson and stop it from coming back?
I hope tis helps.
Jan 17, 2009 | Pentair Mastertemp Pool & Spa Heater Dual...
Pentair Mastertemp Heater Logo
837 people viewed this question
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
