Question about Sony Ericsson K300i Cellular Phone
Joystick my joystick doesn work properly it hangs a lot i need 2 press it hard in some particular angel if i wanna make it work
  • 1 more comment
  • realyn Nov 23, 2007
    my joystick is not working properly.
  • waheed77 Dec 08, 2007
    my joystick doesn't work when i press it downwards for names directory, it takes to the menu asif i have pushed it, replacing it would result in same problem later, i guess it needs cleaning, how to open or clean it ??
  • Anonymous Jan 09, 2008
    show me the procedure to open and clean the joystick
Yea were do we get one from Daa!
Posted on Dec 13, 2007
Replace it
Posted on Oct 02, 2007
My joystick doesn't works in god of war 2 in pc game
Check the settings of joystick in game controller and god of war 2 setting (in game). check them this solution is for joystick not working on in a particular game.
Aug 20, 2012 | Electric Toys
Joystick problem
The joystick tends to be a bit of a problem on the K series. It's not so much the build quality - it is extremely strong and durable.
The main weakness of the joystick is the poor shielding from dead skin etc that falls into the gap, floats around, and gathers in the base of the joystick. This gums up the joystick, meaning it needs to be pressed HARD to push through the **** and operate the micro switch.
It is impossible to clean with brushes, cotton buds, cmopressed air etc. The crud needs to be broken down and washed away. The simplest way to do this is with electronic contact cleaner. This stuff comes in a spray can, with a long thin tube that fits into the trigger head.
This is what you do:
Go here to learn how to dismantle your cell (that link suits K750/W800).
Once you have the cell in pieces, grab the mainboard and contact cleaner and come back here.
Fit the tube to the triggerhead and spray the contact cleaner deep into the base of the joystick. Blast it in there for a few seconds then let it drain a bit, then repeat several times. Then repeat. And again. Get rid of all that crud messing up your beautiful cell icon_smile.gif
You'll feel a bit freaked out using contact cleaner. It runs off the circuitboard like water or very fine oil and you can't help but wonder if it's going to cause damage. But the beauty of contact cleaner is it evaporates without leaving any residue, and so it won't damage the mainboard at all. It also shouldn't set off water damage indicators.
Don't spray it on the lcd though (just incase - my k700 one went a bit funny, but then came good after a day). Keep the lcd away from the spray area.
Give the board a minute or two, then reassemble phone and test joystick. You should find a radical improvement. If still not 100%, try the whole process again, untill you can get no more improvement.
If after that it still isn't working properly, then your up for a new mainboard or to have a new joystick soldering in.
Hope that helps any game peeps out there who wanna fix their joysticks themselves.
Feb 10, 2011 | Sony Ericsson K700i Cellular Phone
It seems that the hard drive or the memory module is not seated properly and hence after pressing on the area below keyboard it gets released.
You can try following things.
Remove and reseat the Hard drive.
And remove and reseat the Memory.
Try to power on the laptop again.
If is getting hang again then you may need to do the HDD self test and memory test built into BIOS.
May 26, 2010 | HP Compaq nx6110 PC Laptop
Playstation 2 joystick do not work
your PS2 console 3.3volt chip damage you repair PS2
May 14, 2009 | Sony Video Game Consoles & Games
Touch screen problem
pls reset ur device like this if it doesnt help then u have to get ur digitizer replaced also called touch panel
hard rest factory default settings = when ur set is switched off press both buttons call and end key and then press power button on upside of pda for like 5 sec screen will appear asking to format all data take out ur card if u dont want to format that now confirm by pressing the centre action button in 4 side joystick and go
Apr 07, 2009 | HTC Touch P3450 Smartphone
HTC touch HD is completley frozen
If you have all your items saved to your computer with Active Sync, then do a master reset:
HTC Touch hard reset 14 January 2008
  • Power on.
  • Press and hold buttons marked 1.
  • Press and release 2 with stylus.
  • Release buttons marked 1 when menu comes up.
  • Press directly down on center dpad, marked 3.
You can also get tips & tricks from
It has the latest and great updates, software, even known issues if you ever come across this. HTC does recommend that you do a master/hard reset once a quarter to keep it moving smoothly. Also, ensure you don't have a lot of open running programs. Perhaps once a day, clean the cashe and history. Do a soft reset (aka battery pull) once or twice a week. All depends on how hard you play with this lovely PDA device!
Feb 02, 2009 | HTC Touch HD Smartphone
OK I had the same problem..What u have to do when u set up the controls is leave ur throttle axis (little sliding doohickey at the bottom of ur joystick) in the middle position.That should do the trick..
Cheers Kevin
Jun 07, 2008 | Logitech Attack 3 Joystick
Joystick problem
It happens if you use it carelessly better claim your warranty or you have to get it fixed with some one professional you don't need to pay a lot for this
Oct 01, 2007 | Nokia 6600
Sony Ericsson K300i Cellular Phone Logo
196 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
