Question about Fisher and Paykel GWL11 Top Load Washer
Fisher Paykel washing machine model # GWL15 drips
Fisher Paykel washing machine model # GWL15 drips water into tub. Cloths become soaking wet if not removed imeadiatly after spin cycle.
  • 1 more comment
  • Anonymous Apr 29, 2009
    Fisher Paykel washing machine model #GWL15.
    1. How do you get to pump? I am checking for leaks. Washer leaves water on floor after each load.
  • Anonymous Mar 13, 2014
    I have a fabric belt caught under the pulsator in my Fisher & Pykel aquasmart WL80T65C machine. Can the pulsator be removed? or is there another way to remove the fabric?
  • Anonymous Mar 28, 2014
    Error 74 flashing & door can't be opened - there is no water in machine
  • 145 Answers
Hi Dale..
It sounds like you have a leaky inlet valve assembly. The part number is 421029P and is easy to replace. You can get one here:
http://www.fisherpaykelparts.net/ecart/item.php?item_id=266&category_id=56
Posted on Apr 20, 2009
I have a fisher & Paskel washer and its not rinsing. Water wont drain. i already unplugged the washer and plug-ed it back in and still wont work what can i do?
Posted on Apr 16, 2010
Fisher paykel GWL15 , i have leaking water dripping from the bottom of pump. do I change the pump or is there a seal that needs to be replaced.
Was the pump easy to turn and lock into place.
If it was easy to turn the seal is not seating tight on the bucket.
You need to tighten the four bolts on the gal plate to make pump seal sit tight against the bucket.
Aug 14, 2013 | Fisher Paykel EcoSmart GWL15
Washing machine drips water from top of tub.
THE WATER INLET FILTER IS MISSING , SO IT ALLOWS SOME FRAGMENTOF DIRTS INTO THE SYSTEM......U HAVE 2 LOSSE WATER INLET VALVE AND CLEAN
Feb 24, 2012 | Fisher and Paykel Washing Machines
Fisher paykel gwl15 won't pump out water
My F & P Model GWL15 did the same thing. I purchased a new pump but that was not the problem. Tip the machine back and look under. There is a valve diverter that I removed and checked. There was a dime and lots of lint stuck in the valve so it wouldn't move back and forth anymore. I downloaded a parts manual, page 10 and item # 23 is the valve diverter. Once I unclogged it and put it back together, it worked great. I noticed it works better than it has for a long time. I'm a 60 yr old woman so anyone can do this. Good luck.
Oct 19, 2011 | Fisher Paykel EcoSmart GWL15
My five yr old Fisher Paykel EcoSmart washer is dripping water into the tub when it is off. Is this hard to fix on this machine?
Hi just read your posting.The problem with your machine is a faulty water valve.Now there is 2 ways you can rectify this .The first and cheapest is to turn off the taps to the machine after use or the 2nd is to replace the faulty valve or valves.Hope this helps and please reply on how you got on and if you would like to change the faulty valve or valves.Looking forward to your reply.
Jul 31, 2010 | Fisher Paykel EcoSmart GWL15
Wont adavace after wash cycle like its stuck replying back
Hi just read your posting. The problem appears to be your drain pump is either blocked or faulty.If you would like I can guide you throe the removal of the pump. The reason it does not reach full spin speed is there is still water under the bowl slowing it down.It is impossible to drain the machine by hand completely.Please reply If you require extra help on the pump removal.
Jun 07, 2010 | Fisher Paykel EcoSmart GWL15
Fisher Paykel washer dripping after wash is complete
replace your water inlet valve can order from Repairclinic.com
Mar 01, 2010 | Fisher and Paykel IWL12 Top Load Washer
Fisher and Paykel washer dripping water into tub.
Dear FixYa Customer,
First and Always go to the Manufacturer for Parts Compatibility and/or Service!
For a GREAT APPLIANCE PARTS WEB SITE click on the highlighted http:// link that follows...
Same-Day Shipping, Return Any Part
Save When You Do Repairs Yourself! @
http://www.partselect.com/Entry.aspx?
jackiaria
Mar 21, 2009 | Fisher Paykel EcoSmart GWL15
Black marks on clothes
I had a similar problem. We has placed the waste water hose into an old tub next the machine. The plug hole int he sink has become blocked with lint. When the washing maching was pumping water into the tub, the tub would fill with water, which would rise a level higher than the washing machine waste hose. What this appeared to do was cause the machine not to be able to properly pump out water, leaving this horrible back stuff in the wash which would end up all over the wash. Ensuring the plub hole in the tub was clear solved the problem immediately!
Mar 01, 2009 | Fisher Paykel EcoSmart GWL15
Musty odor in laundry
I would say that you are getting a build up of soap and oil from our bodies, on the inside of your wash bowl.
The Tubs pull out of the washing machine really easy and then you can water blast the two tubs.Solves this problem?
Once you learn how to pull the tub out you can also clear a blocked pump.
I have a after market lint filter fitted to my F&P washing machine,works wonders .
ask your local whiteware Man for some hints on a Bowl removal.
A five minute job???
Jul 27, 2008 | Fisher Paykel EcoSmart GWL15
Fisher and Paykel Washer Leaking
For those with water on floor after wash, check my post on "eco smart won't drain, smells hot". It could be something clogging drainage area at very bottom of the tub. I couldn't see the sock that was stuck in my FP's drain when I looked from the top between the white outer tub and the wash tub--everything looked fine. Then I removed the black motor/white plastic housing piece--Tip back washer and you should see this black electric motor/white housing on bottom. see my post for how to remove and check for plugged drain. it's really pretty easy.
don't know about outer tub holes, but glad i don't have that problem.
i hate my fisher paykel washer/dryer. i can't wait to sell this house--i will leave them here and get a new front load Duette for my next house!
May 31, 2008 | Fisher Paykel EcoSmart GWL15
Fisher and Paykel GWL11 Top Load Washer Logo
1,581 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
