Question about GPS
Our Garmin is incorrect on several locations. Makes me wonder if I can trust it to find where I want to go. It has us living on the wrong side of the road in a field. Our address is 15336 263rd St Fort Ripley Mn 56449. The Garmin puts us on the West side of highway 371 on the right when it should be on the East side of 371 .9 mile on the left or north side of 263rd St.(or old Cty 49)
    President:
  • 1,263 Answers
Can you tell me the model and how old the unit is, when was the last time your waypoints were stored and have any updates been downloaded into it since you got it
Posted on Apr 20, 2009
I just picked up a Garmin StreetPilot 2610/2650 at a yard sale and was wondering if I need to change the previous address on the disc(does it even have an address?) that is provided in the unit for it to...
You don't say what problem you are having, and I don't know what you mean by the disc.
The Garmin knows where you are, and for navigation, you don't need to tell it where you live.
You may want to reset the location for "Home" in your favorites.
Some Garmins have a security feature that requires you to enter a password, or be at a specific location, before they can be used. If this feature is enabled, and you don't have the required information, there is no easy way to override it except by sending it back to Garmin.
Oct 26, 2010 | Garmin StreetPilot 2610 GPS Receiver
I have a garmin gps 12--s/n 35854358. No auto-locate?
If you haven't used the gps for a while they can try to operate with the incorrect catalog or time. Unless these are both correct it gets lost. Usually you can correct this with a forced reset. There is also a update for this unit which also forces the update.
http://www8.garmin.com/products/gps12/download.html
The data cable sort of screws on and makes contact with 4 pins. This is the little round connector. It does both power and data. The cable is a wee bit pricey from Garmin but you can make them or just get one from ebay.
The reset usually wipes out any saved routes poi's etc so using the data cable will save all of those. To reset the 12 I believe you hold the lower right corner of the screen and then power it on to reset. Then you need to let it rub until it gets the new data which can take 5-50 minutes. Makes sure your batteries are good.
I'd recommend the data cable route (use a 'gasp' non garmin cheap cable) and upload the update at the same time and you should be good to go try and get lost again.
Jun 28, 2010 | Garmin GPS 12 GPS Receiver
Why doesn't it say the NAME OF THE STREET that you are to turn on? It will tell you how far ahead the turn is and then tell you to turn R or L but it doesn't give the name. Also, there have been several...
I have a tomtom 920, it will say the street name to turn on if set to do so & only then if using computer voices, not human voices. Tuning the wrong direction could be its wrong or its trying to take the fast route via a highway, longer route but get there faster
Jun 22, 2010 | Garmin nuvi 255W GPS Receiver
The date that my Nuvi operates on is incorrect
Nuvi 200 - trying to reset the date using the method suggested by Kevin A (and in a cellar) and after two hours the Nuvi was still "locating satellites". Am I doing something wrong?!
My main problem, however, is that having loaded a copy of the latest European maps onto the card used in the device, when going through the "where to" routine I am asked to enter State/Province. Living in the UK this is a little difficult as there is no answer I can give that the unit will recognise! Any ideas?
May 01, 2010 | Garmin nuvi 750 GPS Receiver
We were driving north from South Padre Island and took I 35 W. The Garmin got stuck on Waco, Texas, and no matter how many times I shut it off and reprogramed it, it would not move from that point. I shut...
I called the Garmin 800 toll free number and they helped me to download a fix. The man said there was a glitch. It worked perfectly last night. I also didn't have a voice and the Garmin said none was available.
Feb 10, 2010 | Garmin nuvi 750 GPS Receiver
Text to speech incorrect info
Yes, this is basically normal. This is not a shortcoming of the GPS per se, but of the maps that it's using and where on the map it has recorded that certain addresses are located.
The maps that the GPS systems don't (typically, to my knowledge) have every building on them, instead they just have numbers recorded every so often on the street and then the machine interpolates where a particular address ought to be based on known intersections. E.g., 150 Foo Street ought to somewhere around the middle of the 100 block of Foo St. on the "even" side of the street. So this is probably why it thinks your apartment is slightly further up the street than it is; when people build things, we often don't allocate exactly the same amount of frontage to each street number, hence the offsets.
I'm still pretty impressed with my Garmin and doubt I could find my way home without it. Good luck!
Nov 30, 2008 | Garmin nuvi 255W GPS Receiver
Garmin nuvi
I finally fiigured out what I was doing wrong. I wasn't putting a space between the Avenue and the J. Thanks for your time.
Apr 22, 2008 | Garmin GPS
Garmin etrex legend cx (the grey one)
Do you run the software with administrative rights? If you do, I have no suggestion...
Aug 07, 2007 | Garmin eTrex GPS Receiver
GPS Logo
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
