Question about Gevalia CM-500 12 Cup Coffee Maker
Broken part on coffer maker
The plastic part that conducts the hot water from a male tube stem up into the cover has broken at the swivel connector point. Can this part be replaced through you? It is about 3" in length, about5/16" diameter tube on one end that goes over a tube. This piece fits into a cavity in cover. When cover opened, this pice slides in cover and pivots on stem tube. Thankyou
    Scholar:
  • 192 Answers
Replace it with the same sized tubing that you can buy at the Hardware store. just get the length you need they sell it by the foot. DFD
Posted on Apr 20, 2009
How to adjust water level in ice maker
Hello Tasker;
My name is Peter. I am a retired field service refrigeration technician.
You did not provide a model number which is located on a label on the liner side wall of your refrigerator section, so I do not know what ice maker you have.
Most ice makers do not have a water fill adjustment. If you have a square box cover on the front, then you may have adjustment. On the right hand side there may be a tiny plastic stem with a slot for knife or tiny flat head screw driver. Turn only 1/2 clockwise. Or with difficulty pop off the front cover and you will see an adjustment spring for water fill.
But, I do not think this is your problem.
1.) Your water fill tube my be iced up inside. Using a small screw driver break the ice up in the fill tube.
2.) If this does not solve your problem, then you probable have a bad ice maker solenoid, where either the coil is weak or the spool sticks and does not open all of the way for the fill cycle.
This is easily replaced. It is probably a duel valve assembly where you have to replace the whole assembly.
a.) Locate your model number.
b.) Go into the below website, put in your model number, you will get parts diagrams prices and part numbers.
c.) Go into the internet and search the part number for the valve. You may be able to find a used valve for conservable saving.
d.) Up plug the unit. Turn off the water supply valve.
e.) Remove the back bottom cover.
f.) Disconnect the valve assembly retaining screws that hold the valve assembly to the unit.
g.) Remove the electrical connectors on the valve assembly.
DO NOT GET THEM WET.
h.) Remove the main water supply line to the valve assembly. There will be water in this line.
i.) Remove the plastic tubing to each valve. Push down while holding the small retaining locking ring. When reassembling, push the plastic tubing down, not hold the retaining ring. You should hear a click meaning it is locked in.
Water Filters Lawn Garden Appliance Parts
May 20, 2016 | Sub-Zero 642
Toastmaster 583P leaks after cleaning - water seems to come from pump area around bottom
There are two soft plastic tube from the heating elements, one is intake tube which must fit the water reservor intake plastic well. another one is send the hot water to the top of the coffee maker to shower the hot water to coffee. Anyway is take it apart to find out which is the possible spot cause leaking. Not too easy.
Apr 27, 2010 | Toastmaster 583P
Compressor gone & Input water line burned in half
Sounds like your condenser is dirty, condenser fan motor is out and it over heated the compressor. Since it get so hot, the plastic tubing is melted by the copper tubing ( plastic tubing is touching the hot copper tubing). It is not worth to fix it. Compressor cost $250-$300, plus condenser fan motor, plastic tubing and labor. U-Line has 5yr parts and labor sealed system Warr. U-Line ph # 800-779-2547
Jan 18, 2010 | U-Line Icemaker
MR COFFER MODEL FTX45-1
Run some water and vinegar mixture through the machine and the light should go out.
Apr 23, 2009 | Mr. Coffee 072179228578 12 Cup Coffee...
Farberware Coffee Urn won't make coffee
Be sure that the washer at the bottom of the pump stem remains loose.
If coffee grounds lodge in this area, remove under running water or with
a wooden tooth pick. Dan
Dec 27, 2008 | Faberware 10-22 Cup Coffee Urn
Mobile connector for steam tube...
not sure if you got the part. I called Saeco USA and they sent me the little swivel joint which supposedly is a strong plastic component. check with them
May 21, 2008 | Starbucks Saeco Italia Digital Barista...
Freezer is not making ice
PULL THE FRONT COVER OFF OF THE ICE MAKER AND CHECK THE PLASTIC GEAR ON THE FRONT OF THE CONTROL. THE CENTER OF THE GEAR HAS TWO PLASTIC TABS THAT HOLD THE GEAR IN PLACE. IF ONE OF THE TABS IS BROKEN OR MISSING, THE CONTROL OR THE WHOLE ICE MAKER NEED TO BE REPLACED.
CHECK THE ICEMAKER TO SEE IF THERE IS WATER OR ICE IN THE MOULD. IF NO WATER OR ICE, THE FILL TUBE IN THE BACK WALL MAY BE FROZEN OFF. REMOVE THE FILL TUBE AND CLEAR IT OF ANY OBSTRUCTION. YOU CAN ALSO USE A HAIR DRYER TO MELT OUT ANY ICE FROM THE FILL TUBE. THE OTHER POSSIBLITY IS A BAD WATER VALVE. THE WATER VALVE HAS TWO OUTPUTS, ONE FOR THE DISPENSER AND ANOTHER FOR THE ICE MAKER.
Mar 31, 2008 | Freezers
Ice cube maker
IF NO WATER IN ICE MAKER, CHECK FOR RESTRICTION IN FILL TUBE SUCH AS FROZEN OFF WITH ICE. REMOVE FILL TUBE AND RUN HOT WATER OVER IT TO MELT ICE IN TUBE.
WATCH FOR WATER COMING SLOWLY OUT PLASTIC FILL LINE ATTACHED TO TUBE ON BACK OF REFRIGERATOR.
IF WATER SLOWLY DRIPS OUT OF FILL LINE, REPLACE FILL VALVE( LOCATED WHERE HOUSE WATER LINE ATTACHES TO REFRIGERATOR.
IF ICE MAKER HAS WATER/ICE IN IT, PULL FRONT COVER OFF ICE MAKER TO ACCESS CONTROL HEAD. INSPECT LARGE WHITE GEAR ON FRONT OF CONTROL. IF THE RETAINING TAB IN THE CENTER IS BROKEN, REPLACE MODULE OR ENTIRE ICE MAKER. THERE SHOULD BE TWO
RETAINING TABS HOLDING THE GEAR IN PLACE.
THE FREEZER TEMP NEEDS TO BE A MINIMUM OF 10 DEGREES FOR THE ICE MAKER TO CYCLE. IF THE FREEZER TEMP IS NOT COLD ENOUGH WE WILL NEED TO FIND OUT WHY.
Mar 29, 2008 | KitchenAid Superba Architect KSCS25INSS...
94 jeep cherokee manual clutch fluid tube
easist fix is to visit a car junkyard and find a 94 jeep cherokee (or close to same year). remove the tube and pay the junkyard dog on the way out. Chances are the tube in the junkyard may also be developing a hole, so carefully inspect it before settling. Many tubes on cars today are metal that are covered in plastic. To remove it, keep in mind that it was installed at the factory, so removal is just the reversal. Look for a swivel connector at one end of tube (or both ends). This swivel connector is identified by a hexagonal "nut" and a "break" immediately next to it. This is actually a compression fitting that when tightened, forces two metal surfaces against each other that are tapered inside (look for this taper once removed). Now using an open-ended wrench, turn the nut loose while holding back rotation on the tube.
Aug 17, 2007 | Jeep 10 x 20
LG REfrigerator - water line connector
Try closing the water valve slightly to reduce the water pressure to the unit.
Sgt 48
Jul 31, 2007 | LG LRSC26980 Refrigerator
Open Questions:
See all Gevalia CM-500 12 Cup Coffee Maker Questions
Coffee Makers & Espresso Machines Logo
298 people viewed this question
Top Gevalia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
ka4iup
ka4iup
Are you a Gevalia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
