Question about Dryers
Put dryer belt back on, correctly
Not sure how to rehook the dryer belt. It was making a squeaking noise, I tried to fix it and now it is making a worse sound. Please, send some suggestions. Thank you. Thanks, Rick McCoy
  • 744 Answers
Rick,
It sounds like you are having a problem with the tensioner for the dryer belt - when this device starts to fail, it can sometimes be lubricated with oil and last a little while longer, but will usually need to be replaced. The squealing you hear is a dry bearing for the tensioner pulley. While you're in there, also look aroud and listen if you hear any strange noises coming from the other spots. There could also be issues with the dryer support rollers or support guides.
I am asuming the belt is ok and the drive motor is working properly.
Posted on Apr 20, 2009
SAMSUNG steam moisture sensor front load dryer has noises coming from it. Need help to pinpoint possible problems and how to fix.
You may have a roller out of alignment or off track with the drum now if you took the front panel off. Check to make sure the rollers are on track and the front slides may need t o be replaced if your dryer is a 2 roller model.
Feb 08, 2017 | Samsung Dryers
Dryer squeaks like crazy.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer2_bing.gif Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Asker's Testimonial " This should give me an ida of what to look for once I open er up " -
May 27, 2010 | Maytag Neptune MDG5500AW Gas Dryer
My dryer makes a squeaking noise as it dries. It started doing this for a few minutes, but it now does it all the time. What's up?
Sounds like a roller bearing is going bad. Oling it would only be ashort term fix. The bearing needs t be replaced
Sep 12, 2009 | Dryers
My LG DLE2514W electric dryer starting making a squeaking noise at the end of a drying cycle last night. After letting it sit for over an hour, started the dryer back up and the squeaking noise came back...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
vciku
Jun 29, 2009 | LG DLE2514 Electric Dryer
Noisy dryer......when engaged...making squeaking/squealing noise.
If the noise is like a shaking of rattling , like coins being shaked , then it is an object trapped inside the drum.
If instead the noise is a loud grinding , that may get louder on high speed, then it is usually a bad drum bearing.
If dryer is not cooling, check that the noise is not coming from the ventilation fan.
Rollers and belt tensioner can also make noise.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Apr 09, 2009 | GE Spacemaker Washer and Dryer Electric...
Real bad squeaking noise in dryer
Yes check the brake. Just open the back panel and look under the machine. Check the brake latch and make sure that when the unit starts to spin that the brake backs itself off and also make sure that the bad is not worn down. If it is then replace it. A few screws and off it comes. To check the pulley and the belt there is really no wrong way to do it. First look at the belt and make sure that it is not cracked or really smooth. If that checks out ok then make sure that it is attached to the pulley fully and that the pulley is not bent
Feb 13, 2009 | Maytag Performa PAV2200
Dryer makes loud squeaking noise when spinning
there are two possibilities for this question. 1) there is an idler roller that give the belt the correct tension . unplug dryer and remove idler roller see if it spins freely if not replace it @0 there are two drum rollers in back of machine thatdrum rides on remove drum it's self explanitory how to remove drum and very easy also. you can roll these wheels and check for free movement visually check them ,one or both should be worn out or the bearing in the wheel has failed before putting old or new wheels back sand the wheel shafts to get any gunk off them and that's about the only thing that can make a dryer squeek
Jan 25, 2009 | GE 5.8 Cu. Ft. Extra-Large Capacity...
Dryer belt snaped
Hi!!! Make sure you install the belt correctly maybe this can help you..2447c24.gif
Jan 04, 2009 | GE DBXR463EBWW Electric Dryer
GE Spacemaker washer/dryer
If you can get it apart, you should be able to fix it yourself. This is a tricky task though (I've seen customers spend hours just trying to change a belt, which you'll have to remove), so you may want to pay the money and have someone come out.
It is hard to say without hearing the noise for myself, but my best educated guess would be that the dryer drum bearing needs to be lubricated. You should lubricate it with white lithium grease, about 1.5 ounces of it.
In order to do this, you will have to take the dryer front off, remove the belt from underneath the drum and then remove the drum. You will see a bearing on the backside of the drum (looks like a post with a ball on it). You will see where that inserts on the back wall of the dryer. You should put the grease in the insertion point, then put the dryer back together again.
Mar 29, 2008 | GE WSM2480DWW Unitized Spacemaker Washer...
Loud Squeaking Noise kenmore gas dryer 80 series
You need to change your drum rollers. To get to them you take the dryer apart from the front not the back. There are 2 screws where the filter goes in on top. Then pull the top toward you and up. Then remove the 2 - 5/16 inch screws on each side of the front panel about 2 to 3 inches down. Then pull the front up and out. Then you will see everything. Replace the belt, drum rollers, and idler making sure to oil each as you re-install them. Then put back together and your on your way.
Dec 07, 2007 | Kenmore 63942 Dryer
Dryers Logo
75 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
