Hi Gayle, thank you for allowing me to assist you!
When the Child Lock light is on, the control is locked and
no cycles can be selected or started. To de-select the Control Lock, press and
hold the heat dry key or press down on the lock icon for approximately twenty
seconds. If
issue persists, try resetting the dishwasher by either unplugging it or
flipping the household circuit breaker off. It is important to wait
approximately ten minutes and then turn the unit on. Select a cycle and your
dishwasher should resume normal operations. I ask that you please follow
up with a comment on the post, at your convenience to advise if further
troubleshooting is needed or if the unit's status has changed successfully.
Thank you.
SOURCE: dishwasher lock key
To prevent a child from accidently starting the dishwasher there is a child lockout feature. Press and hold the Rinse and Hold pad (certain models) or the No Heat dry pad (certain models) for # seconds to Lock or UnLock the controls
SOURCE: will not run unknown light on
PRESS AND HOLD THE KEY WITH THE LOCK UNTIL THE LOCK LIGHT GOES OUT.
SOURCE: dishwasher, flashing lights, frigidaire
The steam has gotten into the keypad display and fried it. Call Fridgidaire and let them know you've seen numerous people on the internet with the same problem and that you need part# 154554401 It worked for me.
SOURCE: Dishwasher won't start
your motoer may by stuck jest open bottom ant tern it it will work ok
SOURCE: Frigidare fdb1500lfco wont start. Heat dry light
Press and hold the heat dry button and it will turn off, so dishwasher is usable again.
Hello Ray E. Weaver - Sounds like the Child Lock option may have been selected. This is a safety feature that allows you to lock and unlock the controls to keep children from interfering with the wash cycle etc. Press and hold the AIR DRY pad button for 3 seconds while the door is latched. This should unlock the control pad for you, light goes out and the unit will display the last cycle ran. However, if it does not, try resetting the unit by unplugging it for flipping the household circuit breaker off. Wait approximately ten minutes and turn the unit back on. However, if it proves to be ineffective I recommend contacting a professional to assist further. The dishwasher may possibly have faulty door lock switch.
