Question about Motorola Mobility Moto Q
Unknown callers wont ring
When I receive calls from pivate numbers, blocked numbers the phone won't ring only showing "Unknown Call".  I need Urgent HELP.
Maybe check on the ringer type for restricted numbers- you can change ringers by all calls, restricted calls, and caller id numbers. your incoming restricted numbers is probably set at none or silent
Posted on May 29, 2009
Block unknown callers from Iphone 5s phone.
You can't because they are 'unknown'. You can only block known numbers.
Apr 12, 2017 | Cell Phones
Too stop unknown numbers calling free
Unknown callers should have a number that appears with no name - these can be blocked post call or in the Settings/Phone/Blocked Callers section. Unknown calls with no number can only be blocked from the carrier side - you would have to contact your provider.
Feb 28, 2015 | Apple iPhone Smartphone
How do i block incoming phone call from a uniden cordless phone
  1. Block an Incoming Call
    • 1 Wait until your phone rings and displays the caller ID information 2 Press the "Block" button on your handset.3 Press "Menu/Select" or "Block" to confirm your decision.Block in Standby Mode
    • Press the "MENU" button on your phone's handset.
    • 2 Press the down arrow button to select "Call Blocking." Choose "Create New," "Private Number" (block private calls) or "Unknown Number" (block unknown numbers) from the list.
    • 3 Enter the 10-digit phone number, if creating a new entry. Otherwise, press the "Menu/Select" button to confirm your choice
Oct 14, 2011 | Uniden Cordless Phone
On Samsung jet s8000 Incoming calls display unknown caller message, but call log shows ID
Check your Sim in another phone to confirm , if there is no CLIP then the service provider has barred you and must get in touch. Also is possible that the phone has hung up because there are errors in the software. So to reset remove the battery and the memory card from the phone. Using your PC , scan the memory card for any corrupt files or media files with virus- it is possible when they are downloaded from unsafe sites. If so remove or format the card. Now replace the card and battery and switch on the phone. If the phone hangs up then it is confirmed that the software is corrupt and will need a reinstallation. Seeking help from the authorized service /support centre is most ideal. Take estimate and decide.
Apr 26, 2011 | Samsung Jet S8000 Cell Phone
No manual and am receiving unwanted calls at night just became threatening how do i block them
Using Call Block
If you subscribe to Caller ID, you can save phone numbers to the call block list. When a call comes in, the phone compares the received phone number to the numbers on the call block list. If the phone number is on the list, the phone replaces the caller's name with Call Blocked and disconnects the call. (The caller hears a reject tone.)
The call block list holds 20 entries, and all stations share the same list. You can add entries through the Call Blocking menu, by selecting Add Call Block in the CID menu, or by blocking incoming calls. (Only one station can edit the call block list at a time.)
Blocking incoming calls
  1. When the phone rings, wait until the display shows the Caller ID information (usually after the second ring).
  2. If you want to block the call and add this number to the call block list, press Block.
  3. When the phone asks you to confirm, press Menu/select or Block. Blocking an incoming call from an "Unknown" or "Private" number is the same as selecting Unknown Number or Private Number from the Call Blocking menu.
Call Blocking menu options
  1. With the phone in standby, open the menu and select Call Blocking.
  2. Choose one of these options:
  • Create New(Handset only) - Add an entry to your call block list. The phone will prompt you to enter a name & phone number.
  • Private Number(Handset only) - Block all calls from numbers reported by CID as "Private." (This does not count as one of the 20 entries.)
  • Unknown Number(Handset only) - Block all calls from numbers reported by CID as "Unknown". (This does not count as one of the 20 entries.)
Call block entry options
  1. With the phone in standby, open the call block list and find the entry you want.
  2. Press Menu/select to open the individual entry menu. Choose one of these options:
  • Edit(Handset only) - Edit this entry. The phone will prompt you to edit the name & phone number.
  • Delete - Erase this entry from the list & allow calls from this number.
Mar 20, 2011 | Uniden DECT21883 Trio Cordless Phone
In samsung corby sometimes am getting call from unknown number. There is no contact in the name of unknown.Still i am receiving as 'Unknown'
Always happens. If there is no saved contact number there will show the number with 'Unknown' name. If you want to save the number with any name, then you might do that and after that if that number calls, it'll show the saved number.
Sometimes there are some incoming call that indicates only 'Unknown' with no number at all or '0000000000' that means callers have chose to hide ID or that is a VOIP call. Many operator permits to hide ID but not all.
Nov 08, 2010 | Samsung Cell Phones
UNIDEN TRU8888-CALLER ID DOES NOT WORK
Hi
Thanks for using FixYa. I think you have stored more than 100 Caller ID messages and hence the caller ID is not showing on Uniden Tru8888. In the following cases the caller ID will not be shown-
If you answer a call before the Caller ID message is received (for example, before the second ring), the Caller ID message will not appear.
When the call is received via a telephone company that does not offer Caller ID service, the caller’s phone number and name does not appear. (This includes some international calls.)
When the call is via a private branch exchange (PBX), the caller's phone number and name may not appear.
You may receive any one of the following messages:
When a private name is received; Private Name
When a private number is received; Private Number
When a unknown name is received; Unknown Name
When a unknown number is received; Unknown Number
When invalid data is received; Incomplete Data
The Caller ID list stores information for incoming calls - even unanswered calls. You can store up to 100 Caller ID messages and phonebook entries (including Speed Dials) for each handset and the base. You can view the Caller ID list through the handset or base during a call or when the phone is in standby mode.
Memory locations for Caller ID messages and Phonebook entries (including Speed Dials) are common, you can store up to all 100 entries for each handset and the base. Caller ID messages are not stored when you have 100 phonebook entries. When you have stored a total of 100 phonebook entries and Caller ID messages, the oldest Caller ID message is overwritten.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 16, 2009 | Uniden Cordless Phone
V3a caller id unknown caller id need help figuring out how to change this as they do show up when calling
take backup of ALL the data of ur cell phone and then do a MASTER RESET.
it shud solve the problem.
i hav done it twice.
May 27, 2009 | Motorola Mobility RAZR V3
Some calls are coming through as "unknown number" on my LG U990, despite the callers having ID sent selected on their phone.
Some network providers are having trouble with caller id. You need to be sure that friends or callers are not putting code for unknown caller. Automatically You receiving as unknown calls.
Check Your phone on setting caller id click on show.
Jul 23, 2008 | Cell Phones
My phone when someone calls wont show the name just "unknown call"
check your phonebook ,, it may have double entry...is it all who calls you display unknown calls?
Dec 16, 2006 | Motorola Mobility RAZR V3
Open Questions:
boot_c_03.08.00r_mpap Paul Sager from FixYa has posted a solution for this problem previousley (as below). I have tried the Motorola and Verizon sites (tried the store as well) and the software is not available to flash the phone. Do you know of a site that would still have it available? Or can this question be sent to Paul to further comment on it? All I want to do is recover the phone numbers, notes and calandar from the phone via Activesync or Windows. Paul Sager 2335 Solutions July 14, 2010 I can help you with your Motorola Moto Q. What has happened is that the firmware of your phone has become corrupted. When this happens your phone will no longer finish its boot sequence. This is a very common situation with many phones: in fact, much of what I do here at Fixya is explain how people can fix their MP3 players, GPS and phones by reflashing the firmware. The good news is that if you take your phone into your carrier's store, they can reflash it for you right there (if they have a competent tech handy.) If you are comfortable with computers etc, you can also do it yourself. Your computer will communicate with and fix your phone, even though it doesn't seem to recognize it right now - I've seen this many many times. My only warning for you is that if you are going to flash your phone yourself, you need to get the correct firmware from motorola's site for your carrier. I just downloaded the Verizon firmware as an example - Motorola's website has about ten different carrier firmwares for their MotoQ phone. I hope that helps.
Oct 09, 2012 | Motorola Mobility Moto Q
See all Motorola Mobility Moto Q Questions
Motorola Mobility Moto Q Logo
211 people viewed this question
Top Motorola Mobility Computers & Internet Experts
David Payne
David Payne
 Paul Flint
Paul Flint
Level 1 Expert
Unlockingcom
Are you a Motorola Mobility Computer and Internet Expert? Answer questions, earn points and help others
