Question about Casio Serial RS-232 Cable (CELL-300)
Problem with serial connection with AMD motherboard
Have an old Casio SF r 20 organizer that was working fine with XP Home until I had a quad core AMD motherboard installed recently. When I try to transfer data I receive th emessage "An error has occured during initialization of the serial port". I don't have a separate serial card plugged in to a slot. The serial cable is plugged straight in to the motherboard. I have tried a USB- serial adapter without success. Any suggestions.
  • camerongroup Apr 21, 2009
    Thanks, Steve. Found that the software wanted COM 9.
  • camerongroup Apr 22, 2009
    Thank you very much for your help, Steve.
    Novelist:
  • 210 Answers
Software that accesses serial ports usually allow you to specify WHICH port you want to connect via.
Your new board should have COM1 and possibly COM2... but perhaps your old setup was running from COM3?
Connect the Casio to COM1, and check the software you are using... set that to "look" at COM1 also. That should work!
Posted on Apr 20, 2009
  • Steve Rand
    Steve Rand Apr 22, 2009
    No full points? =-[
    Ah well.. glad you got it sorted!
Can i make a dual core run like a quad core, or add cores with out changing mother board?
You may be able to install a quad core processor on your motherboard, will need the model to check.
You can't make new cores out of nothing though.
Oct 22, 2012 | HP Compaq SR5702F PC Desktop
How to connect sound from onboard soundcard on a AMD Phenom 9750 Quad-Core Processor Motherboard to tv
You will need a cable like this one:
http://www.ebay.co.uk/itm/5M-Metre-3-5mm-Stereo-Audio-Jack-2x-Twin-Male-RCA-Phono-Plugs-Gold-Cable-Lead-/280749715818?pt=UK_Computing_CablesConnectors_RL&hash=item415dfcb16a
One end connects to your PC and the other to the audio input connections on your TV.
Feb 18, 2012 | AMD Phenom X4 9750 Quad Core Processor...
On my sf 5300B I cannot reset the calendar to the current year. If I manually set it to 2010 it reverts to 1995. Help !
Did you go to home/world and press function, then press 1 for home time set, set the time and DATE and then press the set key?? That's what i did and it worked....good luck
May 21, 2010 | Casio Boss Business Organizer
Motherboard GA-MA790FX-DQ6 no monitor
your power supply is too weak to power your video card.
Mar 07, 2009 | Gigabyte GA-MA790FX-DQ6 AMD Phenom Socket...
I installed a AMD Phenom(tm) 9950 Quad-Core Processor which runs at a speed of 2.6 ghz but windows xp pro is only reading it at 1.3 ghz. I also have 4 gigs of ram but windows xp is only reading 2.75. The...
There seems to be some sort of incompatibility issue between your motherboard and the Phenom, or maybe some option is not enabled in the motherboard bios that windows is only sensing half of the GHz, like if the processor is only running 2 cores instead of 4.
About the memory diference, that same problem is because the 64bit difference. Unless you have a 64bit XP you won't see the full 4GB. Windows XP is limited to 3 or 3.5GB of ram it can use, you are showing 2.75 maybe because some video board is integrated in your motherboard and it may be borrowing an extra 0.25GB from the 3GB that are usable under windows XP 32bit OS.
Please comment what motherboard you have, since the cpu alone can't be blamed nor configured.
Jan 03, 2009 | AMD Phenom X4 9750 Quad Core Processor...
Motherboard compatability
The AMD quad core processor will work on motherboards which have the appropriate socket set/size for that particular processor also ensure that your ram is compatible with your processor frequency otherwise you could experience problems.
Jun 06, 2008 | ASUS Computers & Internet
Casio FA-128
how to upgrade Casio FA-128.
Dec 17, 2007 | Casio Boss Business Organizer
Casio Serial RS-232 Cable (CELL-300) Logo
213 people viewed this question
Top Casio Computers & Internet Experts
k24674
Piyal Perera
Piyal Perera
Are you a Casio Computer and Internet Expert? Answer questions, earn points and help others
