Keyboard removal how to remove keyboard on a acer 310 i know to remove 2 screws on back but how do you remove the 3 lock pins at top of keyboard between keys?
Just go to this site and download the pdf file. this has all of the dis assembly information.
www.elhvb.com/mobokive/edwin/laptops/Acer/TM310SG.PDF
or
http://netfree1.blogspot.com/2008/05/acer-travelmate-310-notebook-service.html
Posted on Apr 20, 2009
How to take off keyboard laptop acer 5670 ?
Hi there !
It is easy remove the laptop keyboard for acer and here's how to remove the keyboard.
Use philip screw driver and pointed knife to remove the lock buttons located in both left side and right side, and top side of the keyboard. You have to start removing the lock from the top side and then in left and right side. Each lock button you unlock, you have to flip it not to return the lock. Gentle flip it up not to damage the ribbon connection at the back of the keyboard. Once you see the ribbon connector, release the lock and remove the ribbon connector. That it and it is finish. Do what ever you. If defective, replace it and if it dirty, clean it gentle.
I hope it helps you and Good Luck.
Jan 07, 2011 | Acer 9J.N5982.C5D - Aspire 5670 Series...
I am looking at the mother board of an Acer aspire one notebook computer. I need to view a diagram of the cmos battery to remove it to resolve a password problem.
the CMOS battery is usually located/accessed by removing the keyboard.
Acer don't seem to want to share that kind on data so here's some stuff which may help, but its for an ASPIRE 3000:-
Before you begin, back up your data and remove the battery. CMOS Bios will be lost but will reset on restart.
    Instructions
  1. Step 1 Open the laptop computer's screen and lay it back as far as it will go. Be careful not to stress the screen and cause any damage, but press it hard if needed.
  2. Step 2 Press a flathead screwdriver under the front of the plastic bar lining the back of the laptop's keyboard. Pry the bar up slightly and hold it with one hand.
  3. Step 3 Pry up the other side of the bar with the flathead screwdriver and fully pull out the bar. Keep its ribbon cord connected and set the bar on the laptop's screen.
  4. Step 4 Remove the two Phillips screws securing the computer's keyboard. Then, slide the keyboard up and out to remove it. Again, do not remove its ribbon cord, and set the keyboard over the laptop's touch pad.
  5. Step 5 Remove the four screws securing the cover plate over the motherboard and remove it as well.
  6. Step 6 Locate the CMOS battery at the bottom right corner of the motherboard.
  7. Step 7 Remove the battery by prying it up gently with the flathead screwdriver. Then, replace the battery with a new one of the exact same specifications.
  8. Step 8 Replace all the parts in the laptop in the reverse order that you removed them. -Battery Replacement
This didn't quite do the job, the Aspire was a bit of a so and so. So here's how I changed it on a 3000:-
Acer Aspire 3000 CMOS battery replacement.
Before going any further, you need to know that Acer have done you no favours, this laptop is especially designed to raise revenue for Acer and other laptop technicians. This is a fiddly task and you could do with 3 hands.
1) The cmos battery is on the motherboard about half way down the left hand side, turn your laptop upside down and you should see a locking screw for the optical drive, its just inboard from that screw under the bottom cover plate.
2) The motherboard on the ACER Aspire 3000 is upside down, so it faces the bottom plate or table it sits on.
3) The battery is a 3v Maxell ML1220 or equivalent. About the size of your little finger nail.
Before dismantling your laptop, disconnect the power supply and remove the battery. Then read these instructions thoroughly, make sure you are happy with what you are going to do.
1) Ensure you've got plenty of work space, a plate/dish for the screws and I like to work on a newspaper so I can swivel it all around without scratching anything.
2) Close the laptop, remove the screws from the 3 hinge covers.Open laptop until flat, gently prise off the top backplate. It includes the hinge covers, buttons etc and continues down as far as the top of the keyboard.
Start at one end gently teasing/prising it upwards until it comes free, there are no connections.
3) Removed the 2 screws holding the keyboard down, lift the keyboard gently and place it upside down on the mouseplate, don't break the ribbon connector.
4) Remove the three remaining screws from under the keyboard, one of these is a second optical drive lock screw. Replace the keyboard in its bed, close the laptop and turn it over.
5) Remove all screws and covers from the bottom plate. Remove HDD and the Optical drive, but leave CPU, RAM and WIFI in place. There are 2 further screws one in the battery well and one in the HDD well,remove those also.
6) Very gently, from the side of the laptop where the DVD drive sits, prise the bottom plate away. It won't come away completely. There's a speaker connector at the front at the other end. Bear in mind you'll probably need the lid open as well.
7) Once you have the bottom plate prised far enought apart, you should be able to see the battery, on the motherboard about half way down just about where the back of the DVD Drive would sit. Its in a white plastic mounting, and should be able to flick it out with your finger nail or a screw driver. It may be a good idea to get a second pair of hands to hold the laptop while you replace the battery.
Remember the negative side of the battery sits in the mounting, Positive side upwards.
8) Re-assemble laptop, reverse order to dismantling.
9) Keep fingers crossed whey you re-boot.
Good Luck.
May 02, 2010 | Acer Aspire One PC Notebook
Keyboard broken on my Acer Aspire 5520
For the Acer Aspire 5520 I'm working on, (Acer Aspire 5520-5156, mode nol: ICW50)
Remove the three black screws under the battery, not the silver screws.
VERY carefuly pry off the power button cover. It will make 'snapping' sounds and if you where gentle nothing will be broken.
The keyboard has no screws holding it and can be slid toward the screen and very gently pryed out, taking care not to tear the ribbon cable, as mentioned before.
When the keyboard is out the cable can be released by gently pulling the cable lock on the header toward the cable, the thin (black in this case, it's usualy a different color than the white connector) plastic part of the connector I just use my fingernails, one index finger on each end slowly pulling till it releases.
Pull the cable out using the pull tab. You can just pull the flat cable out with the pull tab without releasing the calbe lock but you stil need to release the cable lock to properly put in the new cable, then push the cable lock back tight to the connector.
May 27, 2009 | Acer Aspire 5520-5908 Notebook
Acer Aspire 1640z keyboard removal
I don't have the diagram but i can give you direction.
1. remove the power cover first (where power button is), it might have 3 screw that hold, if there is 3 screw on the power cover, remove it first.
2. after your removed the power cover, you can see the screw that hold keyboard. remove that screw and you can remove the keyboard.
Jul 30, 2008 | Acer Aspire 1640Z Notebook
Removal of cooling fan
You need to disable your laptop.
follow this step:
Remove harddrive.
1. on the back of laptop, there are 2 doors. open it all. 1 of them is harddrive.
2. remove harddrive.
Remove wireless cable.
1. open 2nd door on the back, you can see rams and wireless card. unplug wireless cable from wireless card.
Remove chassis
1. Remove 2 screws on the hinge cover, so you can remove the power cover (power cover is cover that have power button).
2. after you removed power cover, removed keyboard.
3. remove 4 screws that hold lcd from chasiss. you can remove lcd now.
4. remove 3 screws under keyboard.
5. remove all screw on the back of your laptop.
6. remove upperchassis.
7. remove 2 screw that hold motherboard from lowerchasis.
8. take motherboard out from lowerchasiss.
9. now you can see the thermal fan.
Jun 19, 2008 | Acer Aspire 5050-3242 Notebook
Acer aspire 5610 keyboard replacement
1. you need to remove the power cover (if you see the power button, that what i mean).
2. after you remove that cover, you will see 2 screw that hold the keyboard. Remove both screws.
3. Remove keyboard and replace it with new keyboard.
May 07, 2008 | Acer Aspire 5610-4648 Notebook
How to replace keyboard
1. Remove 3 screw from top of laptop. this screw hold power cover (cover which have power button).
2. Remove power cover.
3. remove 2 scews that hold keyboard.
4. that's all, you can take keyboard out from laptop.
i hope this will help
Mar 18, 2008 | Acer Aspire 5002WLMi Notebook
Acer Aspire 3680. How do I get the back off ?
For AS 3680,
Removed screen.
1. Open the door on the back to remove the wireless antena cables.
2. Open the power cover (remove 2 scews on the power cover).
3. removed keyboard.
4, remove 4 scews (silver scews) that make screen attched the the laptop body.
5. that's all you can remove the lcd now.
For opening the body,
1. Removed all screw on the back, include 1 screw (small scew) under hard drive.
2. removed 3 screws under keyboard
3. removed 1 scew on top side (close to power port), this scews held uppercase and lower case.
4. removed lcd lid cable from board (close to power port)
5. now you can separate upperbody from lowerbody.
6. removed 2 scews from motherboard.
7. removed modem cable, speaker cable, mic cable from the back.
8. that's all, you can removed motherboard+power board.
i hope this help you, good luck
Mar 02, 2008 | Acer Aspire 3690-2196 Notebook
Broken connection on power jack
for Aspire 5100
follow this step.
from backside
1. remove battery
2. remove hard drive cover and hard drive
3. remove the thermal cover, remove wireless card and antena cable.
frontside.
1. remove the power button cover.
2. remove keyboard.
3. remove lcd cable, wireless antena.
4. remove the lcd screw (2 long screw and 2 short screw)
5. remove the lcd screw from the back side (2 short screw).
now the lcd is separated from laptop body.
from backside again,
1. remove fan, there are 2 screw that hold the fan
2. remove heatsink (4 very short screw)
3. remove all screws from backside, there is 1 screw hidden "under" heatsink. it's short scew (longer than heatsink screw).
from frontside, remove 2 screw on top part of the laptop body.
and than you can remove the uppercase now.
after you remove the uppercase, remove 2 screw that hold modem, and remove 1 screw (very short) on bottom part, it's close to touchpad button. remove power switch board and modem and then remove the speaker cable and mic cable.
that's all you can take out the motherboard.
note: just remember to use the correct screw when you put it back.
i hope this will help.
Feb 26, 2008 | Acer Aspire 5100 Notebook
Computers & Internet Logo
60 people viewed this question
David Payne
David Payne
