SOURCE: Get network error ce-00 on the sharp mx-3501n when
CE-00 means ther is a bad destination entered or the copier is not seeing the server check the IP address
SOURCE: Sharp AR-BC260 shows the network error CE-02
You need the Sharpdesk Software CD and you will have to install it in order for the scanning function to work.
SOURCE: mx-2300n network error ce-00 when trying to scan
Using Internet Browser access to the Printer/scanner, accessing Network settings, I noticed that the "Connection Test", (below the SMTP Settings), would not go through when SMTP Authentification was set to "ON". Turning it "OFF" allowed the connection test to succeed, but did not change the error code.
However, adding a secondary SMTP Server, allowed it to go through, (leaving SMTP Authentication set to "ON").
Good Luck
