Question about Sony Cyber-shot DSC-W70 Digital Camera
NO FLASH. SCREEN DISPLAYS "recording" at each exposure
NO FLASH. SCREEN DISPLAYS "RECORDING" AFTER EACH EXPOSURE. 4 ARROW SELECTOR DOES NOT ACCESS FLASH ON-OFF. I may have mis-set something but can't determine what is wrong.
  • Sony Master
  • 13,433 Answers
It seems like the camera is on camcorder/video mode and its recording video.
Posted on Apr 20, 2009
  • Ekse Apr 20, 2009
    if you can't get it off from the setting, open up the setup screen, then setup 1 - and select Initialize to reset all settings to defaults.
Sharp ar 203e maintenance indicator reset solotion
It is SIM 20-1 for maintenance counter reset.
Press
[Clear] key -> Exposure mode selector key -> [Clear] key -> Exposure mode selector key
to enter to maintenance mode.
Add with UP arrow 20, press Start button, add with UP arrow 1 and press Start button. 000 will flash, exit with pressing Clear key 3 times.
It will only reset the counter, I recomend also replacing the parts (drum, develop, blade,..) and clean it.
Mar 21, 2013 | Office Equipment & Supplies
Flash is turned off. How to turn it back on
Set the record/review selector to one of the record modes and the exposure mode dial to the desired function.
By repeatedly pressing the flash mode button you can set the various function types. They scroll through in an endless loop.
The corresponding symbols appear in the data field and the monitor.
The above is from the "Taking photographs with the built-in flash unit" section of the manual (page 131 in my copy). If you need a manual, you can download one here.
Oct 06, 2011 | Leica Digilux 1 Digital Camera
How do I change the time on my CopyStar CS-1820
Setting the Time Zone
1 Access Time Zone.
If you are unsure how to use this route map refer to Accessing Menu Items on
page 3-3.
2 Press arrow keys to select the time zone that you are in.
3 Press Enter. The message display shows Completed and returns to the Date/
Timer Set. screen.
4 Press right Select. The message display returns to the basic screen.
NOTE: Periodically check the time that is shown in the message display and adjust
as necessary to match the current time.
1 Access Year/Time.
page 3-3.
2 To set the date, for each field press arrow keys as many times as necessary to
display the correct value then press arrow keys to move to the next field.
3 When the date is correct, press Enter. The time setting screen
(hour:minute:second) is displayed.
4 To set the time, for each field press arrow keys as many times as necessary to
5 Press Enter. The message display shows Completed and returns to the Date/
Timer Set. screen.
6 Press right Select. The message display returns to the basic screen.
Mar 17, 2011 | Copystar CS-1820 Copier
Flash card error appears on the screen and stops the camera from shooting
Solution 1 • Unlock focus area selector. • Auto-area AF selected for Custom Setting 2 (AFarea mode): choose another mode. • Press shutter-release button halfway to turn monitor o?¬? or activate exposure meter • Memory card is full, locked, or not inserted. • Flash is charging. • Camera is not in focus. • CPU lens with aperture ring attached without locking aperture at highest f/-number. • Non-CPU lens is attached: rotate camera mode dial to M. • Mode dial rotated to S after shutter speed of bulb selected in mode M: choose new shutter speed • P, S, A, and M modes: lower ?¬? ash. • Digital Vari-Program modes: turn ?¬? ash o?¬? Turn long exposure noise reduction o?¬? Turn long exposure noise reduction o?¬? Press multi selector up or down or rotate sub-command dial to choose photo information displayed Select All for Playback folder. Note that Current will automatically be selected when next photo is taken • Select On for Rotate tall. • Photo was taken with O?¬? selected for Auto image rotation. • Camera orientation was changed while shutter-release button was pressed in continuous shooting mode. • Camera was pointed up or down when photo was taken Use Nikon-approved card. • Card may be damaged. Contact retailer or Nikonauthorized service representative. • Delete unwanted ?¬ les or insert new memory card
Jan 28, 2011 | Olympus EVOLT E-410 Digital Camera
Lamp lights without command no longer open in the minidv box black screen does not play, not record one more thing to do?
Jan 26, 2011 | Samsung SC-D103 Mini DV Digital Camcorder
Blown out highlights keep blinking on lcd screen what do i need to do to correct this from happening.
While displaying an image on the screen, press the up or down arrows on the rocker switch (instead of the left or right arrow to change the displayed image). You'll page through the histogram and one or two others before the image alone is displayed.
Blown highlights indicate over exposure. You'll need to reduce aperture size / increase shutter speed to prevent this. You may have the light meter set to meter an unexpected location in the frame or have set the camera to over expose by 1, 2 or even 3 exposure values. Check you manual to review these settings if you can't find them by scrolling through the menus on your own.
Sep 08, 2010 | Nikon D60 Digital Camera
I have a Sharp AL 1631 it won't print. It shows an H-4 in the menu screen
Press "Clear" then "Exposure Mode" then "Clear" then "Exposure Mode" quickly like within 4 seconds. The exposure mode key is the far left key.
If you do this correctly the display will go blank.
Key in 14 as if making 14 copies
Press the print button.
Short version: C, far left, C, far left, 14, print
The machine should reset and run fine. This is a common "false" code on these machines.
If it comes back after a couple of tries the you have a thermal fuse or heater lamp failure.
Nov 18, 2009 | Sharp AL 1631 Copier
THE PHONE FLASHES BUT DOES NOT RING? We had a power cut the other day and since the phones have not rung, just flash? Anyone know why? We have 3 lines coming into the building. The lines have all been...
Programming is done on M7310, M7324 and T7316 sets.
To set up ringing you need to enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS.
The 4 top line/feature keys are now used for programming2.gif.
At the terminals&sets prompt, press the show key (top right arrow).
The display should now ask for an extension number. Enter extension number you wish to program ringing on.
Press the show key (top right arrow)
The display should sat LINE ACCESS
Press the show key (top right arrow) .
The display should say LINE ASSIGNMENT.
The display ask for a line number. press list
The display should say line 001: appear only
press the Chng key till it says appear & ring
press next key (lower right arrow)The display should say line 002: appear only
repeat procedure for remailing active lines
If your system uses the older programming template,
then Enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
the display says A. Configuration
the display will say1. trunk/line data
Press the next key (bottom right arrow) .
the display will say 2.line access
the display will say line assignment
Press the next key 2 times(bottom right arrow) .
The display should say ringing.
Press the show key (top right arrow).
the lines should be listed as appear only change to appear and ring
press Rls when finished
Oct 23, 2009 | NorStar M7208 Corded Phone
How do i get brighter pictures
There are only two options for adjusting the brightness of pictures in this camera, exposure and flash setting.
1. Flash Options: The flash is off by default. To turn it on you must press the button with the crooked down-arrow label between the DISP and MENU buttons, and the flash status will display in the top right-hand corner of the display screen. OFF displays the crooked down-arrow and a circle with a line through it. Press the button once for AUTO, displays the crooked down arrow with an "A" next to it. Press the button once more to force the flash, displays the crooked arrow only in the top right-hand display. Regardless of mode, the display will blink rapidly while the flash is charging and remain solid when it is charged and ready for use. Keep pressing the crooked down-arrow button to scroll continuously through the three OFF/AUTO/ON options.
2. Exposure setting: Press MENU, then the left arrow on the top right-hand four-way button on the camera until the COLOR menu is selected. Scroll down to EXPOSURE and press the MENU button again. You will see EV on the display. Use the up and down arrows to increase or decrease the exposure setting. 0.0 is default, you can go up to +1.5 or down to -1.5. Press MENU to exit when you're done. +1.5 would be the maximum brightness setting.
Oct 13, 2008 | VuPoint DC-M306AT-VP Digital Camera
Hi How can i change the region on my Phillips portable DVD pet824. i live in sydney Australia we use region 4 thank samis
Multi-Region:
Switch player On and Open tray door
Press Setup on the remote control
Move menu selector down to Preferences and press Right arrow
Press 2, 1, 2, 2, 2 and 5
Press Left Arrow
Press Down Arrow
Press 0 when the screen displays region code
Press Setup to exit
Jul 13, 2008 | Philips Televison & Video
Sony Cyber-shot DSC-W70 Digital Camera Logo
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
