Question about Goodman CLQ36AR49 Air Conditioner
Can you bypass piggyback system if you want to just use heatpump. John
    Guru:
  • 588 Answers
I'm assuuming you are talking about your furnace or 2nd. stage heat, when you say piggyback system. Yes you can go to your thermostat or furnace and disconnect just the 2nd. stage heat wire(see furnace wiring diagram), this will not allow the heat to come on in the furnace but it will still allow the indoor blower to run and the heat pump.
Posted on Apr 20, 2009
What fault is low eveperation in heatpump thanks john
It means your saturation temp on your cooling is getting close to freezing. Check your filter. This is usually caused by a reduction of air flow
Aug 05, 2016 | Heating & Cooling
Has anyone heard that t-stat on 4045 is supposed to installed reverse of norm?
User Manual - Braeburn Systems
www.braeburnonline.com/sites/braeburn/files/.../1010_manual.pdf
cooling system control board to test the thermostat installation. This could ...configures the thermostat for normal (NORM NON-HP) heating and cooling systems.
Heat Pump Thermostat - HeatPump-Reviews.com
www.heatpump-reviews.com/heat-pump-thermostat.html
Search Results
    [PDF]User Manual - Braeburn Systems
    This thermostat should only be used as described in this manual. ... configures thethermostat for normal (NORM NON-HP) heating and cooling systems.
Jan 17, 2016 | Toys
WIREIN HEAT PUMP FOR COOLING ONLY
You must wire Orange from heatpump low voltage wire to gether with your yellow s and you must have a common wire usealy common comeing out of heatpump should be black color than what ever color wire you have connected to common at t-stat and airhandler connect that to black wire at heatpump. To make sure blablack I s common follow wire up to board and it will be connected to C terminal now you will have ac all time. If you want heat remve Orange wire from reds at heatpump and you will get heat only.note when doing your wireing make sure high voltage is off to heatpump and airhandler hope this helps
Feb 27, 2015 | Carrier 52CQ-312-4 Comfort Series Heat...
Bypass RIO/PTO on john deer 1025R jractor
RIO/ PTO switches can not be bypassed. These switches are part of the safety circuits. Trying to bypass switches might cause other electrical problems, which that is NOT what you want.
Oct 15, 2014 | John Deere 420,1020,2010,2020,2510,2520...
I have a good heatpump with goodman air handler. the air handler has a sequencer and a blower relay. the blower relay quit working and i replaced it with a supco 90340 relay. the problem now is in the...
Your green wire from the tstat and the low voltage common should land on the relay coil. Your high voltage for the blower lands on normally open. Sounds like you are using your red (constant 24v) to energize your relay. Therefore your relay is constantly energized and your blower runs constantly. Let me know!!
Jul 01, 2017 | Honeywell Programmable Thermostat Heater
Will not pump until I move or shake float
Depending on the make and model you can replace the float, bypass it with a piggyback cord assembly or replace the pump. If you care to post the brand and model I could try and answer if parts are available or recommend a piggyback unit.
Dec 16, 2009 | Plumbing
Heatpump defrost board
REPLACE THE BOARD IS BAD ALSO CHECK FOR 24 VOLTS FROM COMMON AND RED TO MAKE SURE THE BOARD HAS 24 VOLTS.
Jul 01, 2009 | Icm 302c 302 Heat Pump Defrost Timer...
Trying to replace piggyback switch in headlight
there is NO piggyback switch inside the headlamp.
Mar 10, 2009 | Hyundai Motor 2003 Elantra
Thermostat show AUX HEAT
A heatpump has two sources of heat. One is when the heatpump is operating in normal heat mode, and the other is typically electric heat strips.
The strips come on when the unit is going into defrost, when the unit is not able to keep up with the demand for heat (really cold temps) and when the unit is not working properly.
Whne the strips are on, the T-stat displays "aux-heat" to indicate the strips are in operation.
If the strips are working properly you should have warmer air than with the HP alone. Try switchin it from "heat" to "emergency heat" and see what it will do.
When the HP is not able to keep up with the demand for heat then the heat strips come on, but they typically come on only when the room temp has gotten well below the thermostat setting.
In that situation it would be normal to see indoor temps at 63 degrees when the T-stat is set on 70.
But when you set it to E-heat it bypasses the heatpump operation and goes directly to the heat strips. If they are working properly it should maintain an accurate temp in the home.
Jan 23, 2009 | GE Zoneline AZ55H09D Air Conditioner
Goodman CLQ36AR49 Air Conditioner Logo
171 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
