Refil a lexmark #37 color cartridge
Need to refil a lexmark #37 cartridge - where do the three colors go and how can you over ride the chip. Thanks in advance
    Novelist:
  • 177 Answers
Just place tape (2) on the bottom the outside points
ONLY THE ONE OUTSIDE..... BOTH SIDES
Then....
Drill right hole in top, place tape back over refill hole ...........
There You Have it..........!!!
Posted on Apr 20, 2009
Instructions for refilling cartridges on a Lexmark Prevail Pro705 printer
Please note that Lexmark does not recommend the use of refilled, re-manufactured or clone cartridges. You might not get the print quality you expect from the ink that is specially formulated by Lexmark.
Feb 19, 2012 | Lexmark Prevail Pro705 Wireless All-In-One...
HOW DO I REPLACE THE INK .I BOUGHT THE INK BUT FOR GOT HOW TO PUT IT IN
In order to replace the ink..please follow the following steps
#1
Spread out a piece of newspaper where you plan to work. Remove the supplies from the refill kit. The Lexmark 44 will have one bottle of black ink, one thumb drill and one syringe. The Lexmark 43 will have one bottle each cyan, magenta and yellow, three syringes and one thumb drill.
#2
Remove the label from the ink cartridge. The black refill hole is at the top of the ink cartridge. Use a toothpick to check the color of each fill hole on the color ink cartridge. Generally, the magenta is at the top of the cartridge, the yellow is at the left center and the cyan is at the right center.
#3
Use the thumb drill to open up the fill hole to fit the syringe needle. Place the tip of the thumb drill on the fill hole and twist until the hole opens up larger. Do this for each color hole on the color ink cartridge.
#4
Fill each syringe with 7 ml of color ink (one for each color) and 15 ml of black ink. Insert the syringe needle into the bottle of ink and pull the plunger upwards.
#5
Place the tip of the syringe needle into the fill hole. Slowly press down on the plunger. If the ink seeps out while filling, stop filling the cartridge and wipe up the ink with a paper towel. Some cartridges may not need the full amount of ink. Repeat this step for each of the colored ink fill holes.
#6
Replace the ink cartridge in the carriage of the printer. Run one to three test pages to cycle the ink and check the printing. Use any document with color on it for the Lexmark 43 and any document with black text for the Lexmark 44.
Thanks
Oct 06, 2010 | Lexmark X9575 InkJet Printer
I refilled Lexmark ink cartridges 36 black and 37 colored and my lexmark printer 4650 series keeps saying empty cartridges and won't let me print. Can you Help?
36 and 37 can be refilled, but they won't work. They are "return program cartridges" as Lexmark calls them. That actually means that they CAN NOT be refilled. You need to buy 36A or 36XLA and 37A or 37XLA. Those are refillable.
Here is link to Lexmark's site, with a compatibility list.
http://lexmark-cartridges.com/cfv2/printer.php?lang=uk&partner=&productName=Lexmark+X3650
Hope that helps!
Mar 18, 2010 | Office Equipment & Supplies
I have a Lexmark X4650 I refilled the cartridge and now I cannot get the printer to recognize the cartridge it prints black only and tells me Color is low . any suggestions on how to bypass this prob get...
I own a Cartridge World ink refilling store and I can't refill the Lexmark 36 and 37 cartridges. Your printer deactivates the electronics on this cartridge when the ink levels get low. Your printer needs a black and a color cartridge with functioning electronics to print. I NEVER recommend Lexmark printers. They are poorly made, don't accept refills easily, and have the most expensive ink across manufacturers and it is designed to clog your cartridge unless you use it quickly. If you keep this machine you are stuck buying Lexmark brand ink (the return program cartridges are a little cheaper though).
Dec 24, 2009 | Lexmark X4650 InkJet Printer
I have a Lexmark x5470 & I get an error unsupported cartridge
Ink cartriges have chips in them, if the printer does so many prints without getting the "I've had a new Original Cart fitted" it will stop untill,you give it one, regardless if there ink or not
Im afraid it doesn't care that you only need to use the colour cartridge, it is designed to cost you money and make money for lexmark not refillers.
Welcome to our modern world, manufactures make the ink hard to recycle by incorperation of expensive chips that makes refillers, unable to make a easy dollar, because if that want to make cartridges that work they must also fit the expensive chip.
All empty cartridges have a little ink left in them because getting air in ink lines is not a thing we want.
Nov 07, 2009 | Lexmark X4270 All-In-One InkJet Printer
Ink Cartrdige Won't Print
it is because the cartridges are non refillable..... they have a memory chip in them and can not be refilled except by lexmark thru their recycle center
Mar 22, 2009 | Lexmark X5650 All-in-One InkJet Printer
Reset Lexmark 36 Black cartridge?
I managed to get it working, just damage the connection point (where the chip is). I used a knife to break part of the connection and now I can fill the cartridges myself for a fraction of the price :)
Mar 05, 2009 | Lexmark X4650 InkJet Printer
Lexmark x1270 not printing in color
Is the cartridge a Lexmark cartridge or a refilled cartridge?
Remove the cartridge from the printer, take a damp paper towell and wipe the cartridge in one direction on the bottom. Is Ink coming out? If yes then put the cartridge back in the printer and try to print again. If the answer is no and the cartridge is brand new you need to return it to you point of sale and get a new one as its a bad cartridge.
If the cartridge is a refilled cartridge that is probably the problem. Lexmark printers do not support refilled cartridges.
Thanks
Catherine
Sep 08, 2008 | Lexmark X1270 All-In-One InkJet Printer
"color cartridge replacement required"
This is common problem with lexmark cartridges they detect refilled cartridge you need to clean the copper contacts of the cartridge and then insert it if it still shows " color cartridge replacement required" message then you need to buy original color cartridge.........
Jul 15, 2008 | Lexmark X5470 All-In-One InkJet Printer
Ink low error
Hi there the ink cartridges are designed to be used once. Most of these new ink cartridges have a set chip on it once you have installed a new cartridge it registers that a new one has been installed and resets the ink counter for that cartridge. When you refill the cartridge it doesn't reset the chip.
I don't know how to reset the chip but the best suggestion I can offer is to purchase a compatible cartridge that has been reset.
Thanks J
Jan 12, 2008 | Lexmark X83 All-In-One InkJet Printer
109 people viewed this question
k24674
jasbo
jasbo
