Question about Garden
I have a 25cc leaf blower that won't start. I'm
I have a 25cc leaf blower that won't start. I'm not sure what the compression should be but it is slightly less than 80 lbs. I checked a working 31cc string trimmer and it is about 147 lbs so I think the leaf blowers compression is a problem. What do you think?
Albert
  • 246 Answers
SOURCE: homelite ut o8107 blower 25cc will only idle
Hello:
Have you Removed the Muffler and Checked the Exhaust Port and Muffler for Carbin Restriction?
Remove the Muffler and Start the Unit. If the Operates Correctly, then the Spark Arrestor Screen is Clogged and the Muffler/Screen Requires Replacing.
Make Sure the Exhaust Port is Not Restricted Also.
Hope this Helps.
Good Luck
Respectfully
John
Posted on May 10, 2009
bulldogchief
  • 388 Answers
SOURCE: I have a Ryobi 31cc string trimmer / blower /
Ok, well, go to this link: http://www.ryobitools.com/catalog/outdoor_products/trimmers
and look for the one that looks most like yours. That's about the best I can do for ya Mikey. Hope it helps.
Posted on Sep 10, 2009
Testimonial: "I have sent the question to Ryobi as suggested, thanks. I will update this group when/if they respond. mike"
mickey813
  • 472 Answers
SOURCE: Poulan wild thing leaf blower won`t start. Has
SOUNDS LIKE YOU SHULD GET YOU A NEW ONE ITS CHEPER TO GET A NEW ONE
Posted on Sep 30, 2009
  • 110 Answers
SOURCE: I have an old Craftsman leaf blower and it won't
most likley a fuel problem, start by replacing the fuel lines, fuel filter and diaphragm and gasket set in the carb. Non use is the worst thing for any 2 chcle small engine. The modern gasoline that contains ethanol, spoils in about 3 weeks and damages these parts.
Posted on Oct 31, 2009
  • 198 Answers
SOURCE: i have a 25cc sear gas powered leaf blower that
take the plug out and clean it with solvent and check the gap
Posted on May 10, 2010
Whats the proper compression on a craftsman 200mph leaf blower?
Most 2 cycle engines need at least 90(ish) psi to at least run. Most need more to run correctly.
Oct 20, 2014 | Craftsman 25cc 200 mph / 430 cfm Gas...
What is the compression on a poulan leaf blower?
60 to 70 psi it will start fine. I fix Poulan blowers every day for a living
they are very easy to fix. A common problem is stuck piston ring.
Jul 10, 2014 | Poulan Pro 25CC 2Cycle Gas Blower
I have a Craftsman 794774 leaf blower/vac w/25cc engine that won't start.
Many of these small blowers have an alloy key moulded into the flywheel, if this has sheared it will knock the ignition timing out, and will never run.
Feb 23, 2013 | Garden
Just replaced carborator and now it won't start. any suggestions?
you might have primer bulb lines on backwards or the gasket between carb and motor is upsine down
Aug 25, 2012 | Craftsman 2 Cycle 25cc Handheld Leaf...
Blower won't start
do you have spark?is the gas 30 days or newer ?
Jul 05, 2012 | Craftsman 25cc 2-Cycle Gas Blower/Vac
My poulan pro leafblower won't start, feels like there's no compression
Check that the spark plug is snug. If that is not it, then you should check the tightness of the head bolts. Sometimes they loosen. After that it could be a blown head gasket or a stuck valve.
Aug 11, 2011 | Poulan Pro 25CC 2Cycle Gas Blower
Engine won't start
make sure you have fresh gas and your spark plug has spark when you pull it over, you may have to clean old fuel and varnish from carb for it to run, also make sure you have at least 60psi compression
Apr 18, 2011 | Poulan 25CC Gas BlowerVac
I have a Sears 358.794964 25cc Leaf Blower.. Need to know the compression needed for combustion.. I have 75# and won't start.. Checked everything else....
Hello, with the two cycle motor you need a minumum of 100 psi to force the fuel up the transfer ports. Sorry.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
Jan 28, 2011 | Poulan 25CC Gas BlowerVac
Homelite ut o8107 blower 25cc will only idle
Hello:
Hope this Helps.
Good Luck
Respectfully
John
May 09, 2009 | Homelite 'Yard Broom' Leaf Blower
Garden Logo
210 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
