Question about HP iPAQ HX2415 Pocket PC
How do I set up my pocket pc to use wifi both at home and when I am traveling
I have an HP pocket PC model 2410 and I have wiifi for my desktop and laptop. How do I set up my pocket pc to use the wifi connection that I have.
  • davidsegal37 Apr 23, 2009
    sorry, but the suggestion was no help. i am sitting in frint om desktop with a wifi connection. my pocket pc has the wireless turned on an when i open IE and enter yahoo.com i get a message the the page i am looking fo cannot be found.. If i enter home.mobile.weather.com i get the sam message. Evidently i need a different url to connect ot Yahoo. Suggestions?
  • 148 Answers
You can simply follow the first 3 steps of this (http://iris.nyit.edu/oit/academic/FAQ/faq/2wireless/20026/20026.pdf) tutorial. After that, you should see your home wifi name in the list (as in the photo in the tutorial.). If it's not showing up, you can try to change your home wifi settings to accept both 802.11b standart and 802.11g standart. (Because your device only supports 802.11b standart). Steps of changing these settings of a wirless modem changes from manufacturer to manufacturer. I hope this helps.
Posted on Apr 20, 2009
  • Erinc INCI
    Erinc INCI Apr 24, 2009
    I'm sorry but instead of a new URL, you need to check if the connection exists in your PDA using my steps. In the connections list as I mentioned, your wifi should be said "connected" if your PDA is connected to your home wifi. And please first of all try the steps, or explain your problem in more detail in the first place..
How could I connect my home WiFi to my HP computer
wifi is not a proxy,go into your internet settings and change it to connect automatically,not proxy
May 30, 2015 | HP Computers & Internet
Print from nokia E63 through WIFI
Try connecting your printer directly to the wifi router/switch in a shared network configuration. Then go to your router settings, find the local ip address add this as the 'host'. Your settings should be as follows:
Driver : HP Mobile Printing
Bearer: Socket/HP Jetdirect
Access Piont: My Home Wifi (kaba)
Host : ip address of you printer
user : Blank ( tried my windows username,no use)
port : 9100
Printer Model: Officejet Printers
You will have to reconfigure your drivers on your pc as well. Mine installed as a wireless shared printer even though the printer is not wireless but I have it connected to my wifi switch for sharing and it worked fine.
Good luck
Damien_1977
Jan 07, 2010 | Polaroid PoGo Digital Photo Printer
Ipaq 1940 losing programmes during main battery changeover
  1. Plug the charger adapter into the charging port on the bottom of the HP iPAQ Pocket PC.
    Figure : Charging the battery
  2. When the power indicator on the top of the HP iPAQ Pocket PC turns solid amber, the unit is fully charged and can be disconnected from the AC adapter (approximate time to fully charge a unit is four hours).
NOTE: The amber charge light blinks while the battery is recharging and turns solid (nonblinking) when the battery is fully charged.In the event of a low backup battery warning, charge the unit immediately before removing the main battery to avoid data loss. To view the amount of charge left in the backup battery, tap Start, Settings, the System tab, and Power.
Charging with the universal desktop cradle and AC adapter Use the universal desktop cradle to charge the HP iPAQ Pocket PC, or synchronize the HP iPAQ Pocket PC with a computer.
Follow these steps to charge the HP iPAQ Pocket PC using the universal desktop cradle:
  1. Plug the AC adapter into an electrical outlet and connect the other end of the AC adapter to the AC connector on the universal desktop cradle.
  2. Connect the serial or USB cradle cable into the appropriate port on the desktop PC.Figure : Connecting with the cradle
  3. Slide the bottom of the HP iPAQ Pocket PC into the cradle and push firmly to seat it.
CAUTION: To avoid damaging the HP iPAQ Pocket PC or the cradle, make sure the pins are aligned before pushing the HP Pocket PC into the cradle.
    Figure : Charging with the universal desktop cradle
  1. AC adapter into electrical outlet
  2. AC adapter into universal desktop cradle
  3. HP iPAQ Pocket PC into cradle
NOTE: The amber charge light blinks while the battery is recharging and turns solid (nonblinking) when the battery is fully charged.There are stabilizers located in the universal desktop cradle that assist in aligning the unit when there is no expansion pack attached. When placing the HP iPAQ Pocket PC with an expansion pack attached into the universal desktop cradle, the stabilizers will be pushed down by the expansion pack. To release the stabilizers for use without an expansion pack, press the button on the back of the cradle.
Charging with the optional USB Autosync cable Charge the HP iPAQ Pocket PC using the optional USB Autosync cable by connecting the Autosync cable to the HP Pocket PC and the personal computer. The HP Pocket PC will be charged using power from the personal computer.
For more information on charging the HP Pocket PC using the optional USB autosync cable, from the Today screen, tap Start, Settings, the Systemtab, Power, the USB Charging tab, Settings, and Help.
Charging a low battery The HP iPAQ Pocket PC will not turn on if the battery has a low charge (less than 3.2 Volts). Fully charge the battery prior to using the HP Pocket PC.
If the charge on the battery goes below the 3.2 Volts as a result of not being connected to the universal desktop cradle or the AC adapter, no damage will occur to the battery. However, the HP iPAQ Pocket PC charge indicator light will not flash until the battery reaches the minimum charge of 3.2 Volts and a normal reset is performed.
Follow these steps to charge and reset the HP iPAQ Pocket PC:
  1. Connect the HP iPAQ Pocket PC to an A/C power supply.
  2. Charge the battery to the minimum level of 3.2 Volts (this will take 5 to 30 minutes depending on the current charge level).
  3. Perform a normal reset by using the stylus to lightly press the Reset button on the bottom of the HP iPAQ Pocket PC.
  4. Turn on the HP iPAQ Pocket PC.
Keep the HP iPAQ Pocket PC connected to the universal desktop cradle or AC adapter when it is not in use.
Aug 25, 2017 | HP iPAQ H1945 Pocket PC
Replacing a broken screen on a HP ipaq 2410
video on yube to open ipaq same kind of procedure
Mar 17, 2009 | HP iPAQ HX2490 Pocket PC
Wireless problem
when you install fresh copy system doesnt recognise wifi by default ..goto http://hp.com type in your pc model ...navigate to drivers and download your wifi driver ....once downloaded install driver ...once driver installed system will detect and prepare wifi..
done.
Dec 26, 2008 | Acer TravelMate 2300 Notebook
Wi-Fi SD card
Hey, id be happy to help :), the reason why your SD wifi card is not getting read by your pocket pc is because. The wifi card you have is probably have was made for a regular computer and is not compatible with your pocket pc. Id recommend for you to find a SD wifi card that is compatible with your pocket pc. And return the one you have now, thanks and I hope this helps!
Aug 29, 2008 | HP iPAQ H2210 Pocket PC
Laptop (HP) has wireless setting... but I want to go on the road with it and use the internet while traveling in my motor home or auto. How do I do this. What equipment do I need? It is connection to my...
There is a couple of different ways to do this. 1- you can use the built in wireless in the computer at places that have free wifi ie... McDonald's, Wendy's, BurgerKing, Coffee shops, Malls, hotels, etc... most of these have free wifi. The plus side is it's free, the downside is you are restricted to finding a place with wifi. 2- you can go through your cell phone provider and purchase an air time PC card. With this card you can go on line anywhere anytime as long as you have a signal, same as your cell. I know that just about every hotel/motel out there has free wifi now, and my folks like to travel alot in their motor home, and they told me that they see more and more camp grounds with wifi.
Jul 16, 2008 | HP Pavilion dv6000z Notebook
Can't get dynamic ip address
What about your desktop pc? Have you checked the services on it to make sure it is not broadcasting DHCP? Also, think about switching over to Stealth Mode (Non-broadcast SSID) instead of MAC filtering. MAC filtering can be cummbersome and if it is just you, then do away with it.
Sep 19, 2005 | HP iPAQ RX3115 Pocket PC
Hx2410 & Windows 2003 with Acrobat reader for PPC
download the latest version from Adobe (just www.adobe.com) Here is the link to the download page: http://www.adobe.com/products/acrobat/readstep2_mobile.html#pocketPC You will need to select the "Pocket PC Version 2" (not the Pocket PC 2002). The Pocket PC Version 2 is both for the Pocket PC 2002 and Windows Mobile 2003. Enjoy!
Sep 07, 2005 | HP iPAQ hx2410 Pocket PC
HP iPAQ HX2415 Pocket PC Logo
878 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
