Question about Western Digital Caviar SE16 (WD5000AAKS) 500 GB SATA Hard Drive
WD 500g hard drive computer cant read it
WD 500g hard drive... worked great for 1 year and now none of my computers can read it or recognize it Running Gatewau gm5664 w/ 2 of these puppies. one has OEM Vista installed, the other is drive D. (e is behind the partion on the 1st hd) . no warning, no noise, no notice, the system shuts down and would not restart except for the vista disk in repair/install mode. System can not 'see' the hd. all atempts to repair failed. Sys restore was not even an option. had to load vista on 2nd hd. once installed, vista could not see original problem hd. Called gateway "sorry charlie, you're three weeks over warranty. Went to WD warranty page. "Sorry charlie - hd installed by other vendor. check with them." I now understand the hostillities with vendors. They get the old fashion way. they earn it!
Meanwhile, back at my desk, I need to know if there is a fix or work around for this bad dog.
  • Neil Hamilton Apr 20, 2009
    thanks for the response. all that you have suggested has been tried except for the RMA since, according WD Warranty page, this s/n HD does not quality for return. I am looking for upper echelon of recovery for my files. If I can get them back, then WD can have this one an lose all of my business.
    I there a replacement PCB out there that can be swapped out. Symptoms seem to point to PCB falilure since it can not be detected by bios.
  • 19,396 Answers
No physical damage to hard drive is detected by disk. When hard drives are faulty (not logical problems, but hardware faults) the HD will simply disappear from bios.
WD with broken head or faulty motor sometimes beep, but not always.
The only way to know if the problem is Hard disk digital controller board (the board on lower side of hard disk) is by testing the board or replacing it.
The digital controller board for the hard disk is not sold separately, as the hard disk is not considered serviceable (repairable at component or part level) by manufacturers.
Being this hard drive still on the market, the easiest way is buying a new hard drive with same specs for about $80. This may not solve the problem in case it is not a faulty digital board, but the cost will be much below a full data recovery, which cost is over $1000.
If the data inside are important you may need a full data recovery after hardware damage. This must be done on a special environment obtained with a device called Clean Room and cost is expensive.
See pages below:
Hard Drive Recovery Group | Clean Room Data Recovery
Recovering data from hard disk drives with motor failure
Hard Drive Recovery, Hard Disk Recovery, Clean Room
Retrieve Data with help from Hard Disk Recovery Services
Posted on Apr 20, 2009
  • 854 Answers
Hello pacificus.
1. In one of your desktop pc, try to connect the WD 500g HDD (using IDE/SATA cable + power) .
2. try to go to your BIOS setup ( restart your pc , then during restart, press and hold F1 key. The main menu of BIOS setup utility opens)
3. Check if the WD 500g is being detected by the PC motherboard.
- if its detected, then you have no choice but to reformat it using WD disk utility ( got to WD website).
- if its not detected, then you have to RMA (return merchandise authorization) from the store where you bought it. I think WD gives 3 year warranty for their hard drive ( not sure but try to inquire).
For data that are stored in the Hard drive...well..you may want do som file recovery if the Hard drive can still be detected by BIOS of the motherboard of your pc.
Hope this helps...
I have a 500g Western digital my passport. I have owned it for almost a year now. It fell off my dress just now and is not working properly. My computer recognizes it's existence and tells me the device is...
Something mechanically has gone wrong with the disk-drive inside the enclosure.
Search online for a professional "data recovery service".
They can disassemble the enclosure, disassemble the disk-drive, and fix it just long-enough to copy your files (onto another disk or onto blank DVD-writable media). Not "inexpensive".
Then, you can use WD's "Customer Loyalty Program", i.e., prove that you previously purchased a WD product, and you'll get a discount on buying another WD product, if you purchase through their web-site (and pay for shipping).
Oct 11, 2010 | Western Digital Passport WDXML800UE...
My husband has the 500G WD external hard drive which has worked perfectly until yesterday. Now when he plugs it in, the computer doesn't recognize that anything has been plugged into the USB and it's not...
Try it on another computer to see if it is working. Sometimes the USB cable can fail, too, so if you have another USB cable that fits, try it.
If it still does not work, perhaps the drive has failed.
Aug 31, 2010 | Western Digital My Book Essential 500GB...
WD Passport Drive running SLOWWWWW on time machine
USB s slow and when you have huge files it tends to bog it down. it is better to have a firewire transfer. another reason could be your computer is doing to much. leave the computer at one task. walk away and let it work. otherwise you will be using memory.
Oct 01, 2009 | Western Digital WD Passport 250GB Portable...
My computer recognizes the WD but i cant view my files
Sounds like to me you already did the troubleshooting. If you cannot get the drive to function properly on another computer and it has the same symptoms, then logic would say that it is your drive. Note to also use a different cable to make sure it isn't the cable. I would try it on at least two more computers to make sure, hopefully with at least XP and Vista.
Jun 25, 2009 | Western Digital 250GB MyBook External USB...
Prolem with starting my WD500 (model wd5000h1u-00)
Okay this is a internal SATA drive so what you can do is take it out of its failing case and put it into your computer or buy a new enclosure for it. I have a Mybook TB drive and my works great with no problems. But you can take this to WD western digital as its warrentied foe 3 full years!!
May 25, 2009 | Western Digital My Book Home Edition 500...
My computer won't recognize my wd my book 500g hard drive. I think it overheated and now is making noise (internal relay switching) It sounds like it's trying to turn on and off but it is on!! What can I...
There can be 3 possible problems since you hear the clicking sound. 1 is that the drive is not receiving enough power from the power supply and it is attempting to turn on. 2nd is the controller board is damaged and 3rd is the drive itself is damaged. From my experience with WD external drives. the 3rd is my best guess. One thing you can try is to buy an external chassis for the hard drive and take the hard drive out of the My Book and put it in the chassis to see if it works. Get one from a place with a good returning policy would also be good as well
May 06, 2009 | Western Digital My Book Essential Edition...
Nothing on my Computer
Your disk has not been initialized to work with the Windows NTFS file system.
Go to Start, right click on My computer, and select Manage. Then in the right hand pane of the window that opens, double click Storage, then Disk Management. You should see your drive in here as logical drive 1, likely. It will be the one that is not initialized. from this window you can initialize and format the disk.
Once this is done, Windows should be able to see it.
I hope this helps, please rate!
Mar 18, 2009 | Western Digital External USB 2.0 80 GB...
Computer says my 500g HD is only 170g.
hi mate, i fixed it this way
right click on my computer > manage > disk management > (box bottom right you should see the rest of the drive space unalocated) click the unalocated drive box > create partition > the rest is history.
hope this helps mate.
Nov 18, 2008 | Seagate Barracuda 7200.10 500 GB SATA Hard...
i suspect ,if there was no bad sounds on the drive when it was wrking ,that it must be the circut board on back of drive . i ,m in the same boat myself & i,m trying to track down same type of c/board.i do not think this is mechanical bit, electrictal
soretoe
Jul 17, 2008 | Western Digital Caviar SE16 (WD5000AAKS)...
External hard drive not recognized
I recenctly bought a my book 500 gig drive and it is usb.
the firsttime I plugged the usb cable in it worksed. I had only a 40 gig ide harddrive and so I ordered an internal 500 wd hard drive to replace it. The internal 500 gig is a sata drive. first I cloned the 40 to the sata 500 and then copied the external 500 to the internal. I mover the cables to then make the internal 500 sata my boot drive. The computer would no longer show the external e\when i used the windows explorer. the device manager said it was there and working with no problem but windows did not see it.
After several experiments with diferent configurations I have concluded my motherboard wasauto configuring the external and internal 500 drives as drive 0. Since the usb was detected first and was notthe boot drive then windows assigned the internal drive as drive 0 and since the usb drive was drive 0 also it would not work. windows ignored it. my solution was to return the ide as the boot drive and plug the sata into a slave port. with that configuration both drive are seen and work normally. It took me several days to find this arrangement. so since my sata ports are auto configure and the external has a sata connection i will install an esata port adapter and try to hook it up as a slave sata drive so i cab\n use my internal 500 sata drive as my boot drive.
sorry this was so long but it is my solution to what others may be facing.
May 12, 2008 | Western Digital My Book Essential Edition...
Western Digital Caviar  SE16 (WD5000AAKS) 500 GB SATA Hard Drive Logo
373 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
