Question about Frigidaire FRT15B3A Top Freezer Refrigerator
Refrigerator does not get cold and the freezer does not freeze.
This refrigerator was produced June of 2008. It has been working fine in my garage until this winter when the Freezer stopped getting cold enough to keep anything frozen. I shut it down for a day and then started it back up and it worked. But it did it again and now it no longer gets cold. It blows air but the air is not cold enough to allow normal opperation. I have set it on high and normal but the results the same - not cold enough...........
How does one determine if the refrigerant R134a has escaped? What should I check?
    Sergeant:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 322 Answers
It might indeed be the defrost control timer, like the above poster suggested. However, replacing the timer can be tricky if you are doing it yourself, so make sure to check the user manual for refrigerator parts beforehand:
Frigidaire refrigerator parts manual
Posted on Dec 07, 2014
  • 1,889 Answers
Look on the back of the box for a hole marked defrost control timer turn the timer with a screwdriver if it then gets cold replace the timer
Posted on May 03, 2009
Freezer not working when its cold in the garage.
Where do you keep the fridge? If you keep it outside then most likely the condensor coils in the freezer may be freezing over and the only way to fix that is to keep it above 40 degrees outside the fridge.
Jan 18, 2017 | Refrigerators
How do I keep my refrig/freezer from defrosting in the winter when store in the garage.
There is only one source of cold in many refrigerators. If yours is a top freezer, then most likely it is in the freezer.
But the thermostat that you set temperature with is in the refrigerator, not the freezer.
In the cold garages, what can happen is that the refrigerator stays cold enough that it does not call for cold. So the freezer does not get enough cold.
The freezer control works by diverting cold air into the freezer WHEN THE RERIGERATOR HAS TURNED ON THE COOLING. If it is not turned on, oh well.
The best you can do for this is to put both on max cold. Then the refrigerator will call for more cold at a lower temperature, and the freezer will get it more often and will divert more when it is cooling.
This can result in the refrigerator freezing things too. You can try raising the refrigerator setting JUST A LITTLE and see if both work, but keep freezer on max cool.
This works for my situation, but ambient temperature fluctuations in the garage make this dicey. We don't put things like lettuce in the refrigerator in the garage in the winter because freezing damages them.
Good Luck
Feb 05, 2015 | Refrigerators
Hi there our LG GN-315FW refrigerator has stopped working. It is still producing some cold at freezer and chilled area. But no cold at refrigerator area for food & vegies. Freeze is just cold but not...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 25, 2011 | LG LRBN20510WW Bottom Freezer Refrigerator
Top freezer quit freezing. Refrigerator works.
Good day,
Yes, the cold weather is the cause.
Your machine is cycled off and on by the thermostat located in the fresh food compartment. When the fresh food compartment is satisfied, it will shut off the entire machine.
Any temperature below 55 degrees will reduce running time until the freezer will not function, or at best poorly.
Engineers designed domestic refrigerators to balance properly between 70 and 95 degrees. It should be in your user manual.
Thank you for using FixYa
Jan 12, 2010 | Frigidaire 20.6 cu. ft. Top Freezer...
Refrigerator/freezer in garage not freezing
Most refrigerator Manufactures have tested these machines in hot and cold weather and weather will effect operation and electricity consuption.
As far as cold weather goes It would run much better in cold weather than hot. As far as it being in the garage : It will wear on it faster. The humidity is not good on them and they get more dirt through the system and will need its normal mantenance more often. not to mention bugs and rodents like to find a warm place to hid with fee dinking water and a refrigerator provides that for them.
Jan 09, 2010 | Whirlpool ED5HHEXT Side by Side...
Freezer not getting cold enough.
That is normal since the cold control is on the refrigerator side and is satisfied. It needs to be in a heated environment and not in an unheated garage.
Jan 02, 2010 | Frigidaire FRT21P5A Top Freezer...
The freezer is cold, but has stopped freezing,
This may be as simple as just turning the temperature dial for the freezer to a colder setting. Do that and wait a few hours and your problem may be solved.
Feb 06, 2009 | Frigidaire FRT21H8 Top Freezer...
Freezer Not Freezing
sounds like youll need to order and install one of these, its too cold in your garage to operate normally, this is a simple solution that should correct your issue
http://www.frigidaire.com/tip/US%202008%20Service%20Flashes%20and%20News/Refrigeration/2008/Service%20Flash%20RF083FRIG%20Garage%20Kit%20for%20Top%20Mounts.pdf
Jan 21, 2009 | Frigidaire FRT15B3A Top Freezer...
Freezxer dosn't work
Is the fan inside the freezer working? If the fan isn't working the freezer will never get ice cold.
Nov 23, 2008 | Frigidaire 12 cu. ft. / 340 liter Upright...
Frigidaire FRT15B3A Top Freezer Refrigerator Logo
1,111 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
