Question about Simmons Mattress Crib 'n More
Converting Simmons Crib 'n' More to a full size bed
Our instructions say that we need Simmons Item # 000560 - side bed rails. Is there a place on-line that I can order these?
  • 3 more comments
  • Anonymous Dec 22, 2007
    I too am looking for these rails. These rails change it from Crib/Daybed/Toddler bed to Full size bed.
  • tlb321 Dec 31, 2007
    I have the same problem!
  • Anonymous Mar 17, 2008
    The cribe I have looks like the one below.I also got it about 7 years ago.I Orderd the the hardware to convert back to crib with sliding front..... but got the wrong setup.Thay say thay say thay dont make them any more so.....? how can I get the right parts?
  • papadave2 May 11, 2008
    The only problem I have is where can I find these rails?
    Thanks, David Colombaro
  • Anonymous Jul 10, 2008
You can call Simmons Customer support at 1-800-218-2741 and order the rails - they are $79.99 which includes shipping. I just did so yesterday. I had the same problem. I purchased this crib 5 years ago and now need the bed rails to convert to a full bed. You cal also email them at [email protected]. Shipping takes about 2-3 weeks.
Posted on Jan 16, 2008
    New Friend:
I went through the trouble of typing all kinds of words hoping someone was going to help me and bam a charge came up uh duh i spent my money buying the bed and moved and cant find the directions. im trying to turn my sons bed into a toddler bed i bought him a new bed set with ELMO on it I wanted it up before in the morning but not happing huh? i just need to know how!!!
Posted on Apr 26, 2008
Which collection is it? I have the meridian crib and it came with the wooden flat piece needed to convert from crib to daybed(toddler bed)
Posted on Dec 08, 2007
SOURCE:
Hi, i have crib model 248189 from simmons little folks and i need to get the side rails to convert into a full bed, how can i find them?
I have a simmons model 248189 04-183 crib in oak I would like to have a toddler side rail to convert it to a toddler bed. where can I get the piece and how much is it.
Mar 13, 2011 | Simmons Mattress Matino - Natural Maple...
We have a Morigeau-Lepine convertable crib-day bed-full size bed, but we are missing the instructions to convert it to the full-size. It's model number is DA722-BC & the model is somewhere between...
I can't offer the exact answer, but hopefully my suggestions will be helpful...
Converting the crib to a full-size bed should actually be a fairly simple process of detaching the 4 sides that make the crib, and replacing the 2 short sides with the full-size bed rails that were sold separately in a conversion kit. The 2 long sides of the crib become the headboard and footboard of the full-size bed.
Unfortunately, it's only a simple process if you already have the full-size conversion kit bed rails. And since Morigeau-Lepine went out of business, they aren't making any more conversion kits. If you don't have the full-size bed rails, then this could be quite difficult.
It's possible that some stores that used to sell Morigeau-Lepine cribs might still have a conversion kit hidden somewhere in the back of their stock room or warehouse. You could try calling around to a few of your local stores to ask if they would check for you. It's a long shot, but it doesn't hurt to ask.
If you have the rails, or are lucky enough to find them, then it should be as simple as locating the screws that hold the crib sides together, removing them (most likely with an appropriatly sized hex-key,) and putting the screws back through the headboard and footboard into the bed rails. (I'm really just assuming that it works the same as the Babi Italia conversion.) If no screws are visible, or if removing them doesn't detach the crib sides, then they are probably also held together with locking bed rail fasteners. To release the fasteners, remove any visible screws, then push upwards on the short side rail while pushing down on the long side rail. You might have to tap the rail up with a rubber mallot to get it moving.
If you don't have the full-size bed rails, and you can't find them anywhere, your only option may be to build them yourself, or find a woodworker to build them for you. Search online for "Bed Rail Fasteners" and you'll see several options for hardware, but they might require modifying the headboard and footboard as well. Full-size matresses are 75 inches long, so you'll want the length of your rails to accomodate (ours are 77 inches long.)
I hope I've been helpful. Good luck!
Jan 19, 2011 | Baby Gear
Delta soho 5 in 1 crib where can I get the conversion kit for the toddler bed and where can I get the rails for the full size bed
You can find Delta soho 5 in 1 crib conversion kit on amazon. Click here Amazon com Delta rails and take a look. I hope this was helpful. cheers
Jun 29, 2010 | Delta Soho Crib
Bed rails to convert crib to full size. Simmons metal bed rails #000560. Where to get them?
You can also purchase them from Plumstruck which is what I did. They shipped faster and were exactly the ones that I was looking for. The listing says "Saratoga" but they also fit a bunch of other Simmons Cribs. (Santiago, Callisto, Valencia, Raleigh, Sausalito) just to name a few.
http://www.plumstruck.com/Simmons-Saratoga-Metal-Full-Rails/dp/B009L2B5UM
Sep 30, 2009 | Simmons Mattress Crib 'n More
Converting Delta Martinique 5-in1 Crib to single bed
I have the same crib and it can be transformed into a toddler bed by removing the front rail and it can be transformed into a full size bed using a full size bed frame and the front and back rails of the crib.
May 30, 2009 | Delta Martinique 5-in-1 Crib
Bed rails to convert to full size bed
We purchased our bed rails through Babies R Us. Be patient, they need to find the right part # through their catalog and this took a couple of days to find, but they finally did find it and we got our rails a couple of weeks later.
Jan 18, 2009 | Simmons Mattress Crib 'n More
Conversion instructions from crib to full size bed
check this website. www.babysdream.com/Service/AssembIns/pdf/Convertible%20Generation%20Next%20Crib%20Instruction I needed the instruction to convert my daughters bed and was looking for some help and notice your question.
Good Luck
Dec 27, 2008 | Babys Dream Generation Next Crib
No instructions on converting a Ragazzi crib into a toddler bed
This site has instructions for some Ragazzi cribs.
http://www.babyfurnitureplus.net/instructions/index.html
Nov 17, 2008 | Baby Gear
Parts Source
Full-Size Wood Bed Rails
Model: 180080
Dec 15, 2007 | Simmons Mattress Crib 'n More
Simmons Mattress Crib 'n More Logo
5,372 people viewed this question
Top Simmons Mattress Baby Gear Experts
Dorel UK
Dorel UK
Marvin
Marvin
john h
Are you a Simmons Mattress Baby Gear Expert? Answer questions, earn points and help others
