Question about Samsung SyncMaster 720N Monitor
Samsung 720n power light blinks, no picture.
I have a Samsung Syncmaster 720n. At boot the green power light just blinks. There is no picture. Any ideas?
    Scholar:
  • 36 Answers
Hi
I am a technician-informatic. I have repaired about 60 Lcd Samsung monitors with this problem - not optimal resolution mode and dark screen problem. So i decided to made manual how to repair lcd samsung monitors.The repair process is very easy and simple 10-30min. does not need a lot of experience in electronics and expensive instruments.
if you are interested check it.
Samsung monitor repair manual guide 710n,913v,510n more
or just enter number in search field: 220409788372
thank you
Posted on May 15, 2009
  • Nerijus Mazuolis May 15, 2009
    hi
    thank you
budmrtn
  • 11361 Answers
SOURCE: samsung syncmaster 920nw comes on and then goes off
The problem can be bad power suuply due to bad caps, bad inverter circuits, bad lamps. Look for bad caps first then report back what you see inside so we can guide you further, see example of failed SAMSUNG monitors due to bad caps here: http://s807.photobucket.com/home/budm/allalbums
Posted on Jan 30, 2010
SOURCE: Syncmaster paower button blinking and no display
Ultimately I had to return the monitor to Best Buy where I Originaly purchased it. Luckily I had purchased it between Thanksgiving and Christmas when the the store had a 1 yr exchange policy. They had to send it back to " have a card replaced" ( They're words). Took about 3wks to get it back no charge. Seems to work fine for now but who knows how long this will last. Will probably be my lasy Samsung
Posted on Dec 16, 2007
SOURCE: syncmaster 720n
OK, I've figured it out! There's something wrong with the control chip, so if you don't have it under warranty, here's what you can do:
1. Turn off the monitor
2. Unscrew the face of the monitor
3. Remove the bottom part of the face from the backside, so you can see the chip
(the control chip is located on the face of the monitor, under the buttons)
4. You will see a small white connector about 5mm wide, UNPLUGG it
5. Put the small cable that you've unconnected under the front, so you can close the monitor back
6. Close the monitor and plug it back in
That's it. You won't be able to change your settings (they autoadjust anyway), but you won't have to throw the monitor away!
Peace.
Posted on Dec 01, 2009
SOURCE: Samsung SyncMaster 720N ...
Peace.
Mark_Webber
  • 472 Answers
SOURCE: A green hue from my samsung syncmaster 720n
Check the video cable connection at both ends. If it is secure, then move the cable in circles at both ends.
If the cable breaks a single wire, it will still be close enough to make contact under this test.
The red is almost always the one that will break first and cause the green and blue signals to be the only ones to be active resulting in a blue/green tint.
If you have another cable just try that instead.
Posted on Apr 29, 2008
Computer screen hangs then i restart it but suddenly green light just blink and no picture on screen appear/blank and it keeps on "tot-tot-tot" ....
This sounds like either the capacitors are failing in the unit, or if you can hold a flashlight to see a very faint shadow of whatever is supposed to be on the screen then it needs a new backlight.
Jul 11, 2011 | Samsung SyncMaster 720N Monitor
How do I install a samsung syncmaster 720n monitor without a disk
Hi, if you click on the below link -
it will take you to Samsungs site where you can download both the usermanual and the driver you will need to install. To get to the drivers, wait for the page to finish loading, then underneath the word Download on the downloads tab there are two options, Manuals and Driver. Click on the word Driver and below will appear the driver - just click on the EXE picture under the word File to download and install.
Thanks, if this solution helps please rate :)
Feb 19, 2011 | Computers & Internet
I was playing my game today and suddenly the monitor died. the computer works fine but the monitor wont even take the picture(wont even work without being connected to computer, like it has no...
You need to check the power supply and see if the output voltage is correct, it should be written on the power supply board by the out put connector, if it is correct then it is possible that the inverter is bad.. I suspect a bad power supply.
Oct 15, 2010 | Samsung SyncMaster 720N Monitor
Have samsung syncmaster 720n monitor. adjustment menu blinks on/off. how to stop?
Trying the hold down power button for count of ten (did count of twenty just to make sure) didn't work. Menu came back up. Will try unplugging control chip next (this fix doesn't make sense to me ) will see if monitor will work without chip>
Aug 13, 2010 | Samsung SyncMaster 720N Monitor
My montiour makes auto adjust and shows it's menu & it also change brightness without I touching it's buttons (need help)
open case remove little plug from back of switches kepp it out close case ....fixed but no power light or buttons picture is fine ; )
Aug 06, 2010 | Samsung Syncmaster 17" 720N Monitor
Screen shows computer brightness indicator which does not go away
unplug open case remove little white plug from rear of switches leave it out then put case back on job done no power light or buttons but picture is fine ; )
Mar 10, 2010 | Samsung Syncmaster 17" 720N Monitor
Resolution and refresh rate
1280x1024 native and will go to 75hz x 81khz
I'd probably look more at what your video card supports.
Jan 08, 2010 | Samsung Syncmaster 17" 720N Monitor
Syncmaster 720n
Peace.
Sep 01, 2009 | Samsung SyncMaster 720N Monitor
Picture size problem
click start,control panel,display,settings and set your screen resolution to what you need
May 23, 2009 | Samsung Syncmaster 17" 720N Monitor
Samsung SyncMaster 720N Monitor Logo
2,262 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
phoenix chi
phoenix chi
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
