Question about GE JKS05 Electric Single Oven
Stove smokes when i turn the oven on
Well my mom forgot a plastic cap inside while the oven aws on, we did not realize until it had completely melted,we tried to use the self cleaning feature but the smoke was worst,we have not been able to bake anythig because smoke starts comming out like if its on fire and the oddor of burned plastic is just horrible, i dont know what to do, can some one tell me what can i do so that i can star baking again.
  • Miriam David Perez
    Miriam David Perez Apr 20, 2009
    we removed as much as we could but it left a stain and it smokes every time we turn the oven on.how can we clean it or get rid of the oddor and smoke.
    Problem Solver:
  • 7 Answers
Use baking soda and vinegar to neutralize the odor and wipe all surfaces inside the unit to remove residue and smoke
Posted on Dec 18, 2014
    Problem Solver:
  • 6 Answers
On the oven's smooth surface you should use a razor blade and scrap off the plastic (when cooled).. if the plastic melted on the burner, you may need to replace that particular element from a local appliance part store. easy to do.
Posted on Apr 20, 2009
Did a cleaning on the stove. in middle of cleaning the stove started to smoke so they hit the off button. Now the stove wont open. How do we get the stove oven door to open?
All you have to do it wait and it will unlock itself. It just gets very hot so the stoves are made to seal themselves until cool!
Aug 17, 2011 | Ovens
Oven was heating and we got HEAVY smoke....
Nothing in the elements, thermostat thermocouples are gas filled, sensors have wiring inside, nothing in the liner or insulation. You said this was a stove, and some stoves have a vent that goes up through one of the burners on the top. If you had oil splatter or drip into this it can get into your oven. We do know that some blower fans on convection ovens have a sealed oil bearing, but there would be very little oil coming out of this (drops) and you will notice your fan getting noisier or running slower in the near future. Good Luck, Appliance Specialists
Jan 25, 2010 | Ovens
Oven smokes and smells like burning plastic
This happened with my oven, happened twice to the same (newer) oven actually. The smell and smoke occurred both with the oven and with the use of burners on stove top. Turned out it was the main line cord which had a split. The first repair they replaced the thermol block and all the bolts holding it into place (for a total of 9 parts) the second time (about a year later) the repairman replaced the line cord and said that it probably should have been done along with the first repair. The smell coming from the oven before the repair was a toxic burning wire or burnt plastic smell. There was also smoke if the oven was left on long enough. The repairman said that the amount of heat to "cook" the connection on the line was at a fairly dangerous level. It was recommended to me by the fire inspector (who was in my unit for annual condo inspections) that it was unsafe and to have it repaired immediately. Hope this helps. Best of luck.
Oct 20, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
My mom has a Magic Chef oven, model 5892VRV. It
You have 2 choices.
Replace the electronic control(clock).
Or, replace the range.(stove).
Sep 04, 2009 | Magic Chef Ovens
Smoke is comming out of the stove when the oven is on
the oven exhaust vents through to the stove. otherwise, the heat will build up pressure and blow the door off. ok, that was drastic. but if there is smoke to the stove, there is smoke in your oven. check to see in anything is burning.
Aug 27, 2009 | GE Profile JTP18 Electric Single Oven
My oven made a buzzing sound,and and smoke came out form the oven. Now it wont heat up, but the top stove still works...Any ideas? Thanks
fryed switch or fryed burner
if smoke came from inside stove likely the burner is fryed
try setting oven to broil and see if it heats up
if it does replace lower burner
Jul 31, 2009 | Ovens
Smoking Oven
soundsas if you have a dirty stove, Id reccommend running through en extended cleaning cycle, it will SMOKE, that s geting rid of any food/grease trapped inside the flue and cabinet of unit
Jan 31, 2009 | Amana Ovens
Oven not working
I had the same problem. At the back of the stove is a plastic cover with thermal overload written on it.
Switch off your power.Remove the cover, pull out the two luggs and connect the two luggs straight to each other. Make sure the oven knobbs are in the off position. turn on the power. If your oven clock etc. comes on the thermal overload is faulty and needs to be replaced. It is fixed to the stove by a screw from the inside of the oven, so open the door and remove screw to remove thermal overload at the back of oven. Take sample to electrical shop and replace. DO NOT USE OVEN WITHOUT THERMAL OVERLOAD.
Dec 27, 2008 | Ovens
Old Amana - no manual; can't operate self clean feature
Can you locate the model number on the oven? Also any particular name of the stove? The manufactured year. These should all be available on a stainless steel or aluminum attached plate , probably on the back of the stove or inside the door.
I wouldn't try using the self cleaning feature until we get some advice. it could lock up on you and not UNLOCK. Normally self cleaning takes place at 600 or more degrees .
I'm sure others still have the same stove., I will see what I can find for you.
Aug 21, 2008 | Amana AEW4530DDS Electric Single Oven
GE JKS05 Electric Single Oven Logo
340 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
