Question about GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW
GE Ice Maker that leaks water down the freezer wall
I have a GE Z15B42DYB side by side ref with an icemaker that makes ice ok then appears to either over-fill or over-flow. Water runs down the side of the freezer wall and also into the ice cube collection container. Eventually the bottom of the collection container is a block of ice. I have checked to make certain the the fill tube is connected correctly. It is not a large amount of water at any one time. The ice cubes are correctly formed so it does not appear that the tray is unlevel. Any thoughts. Thanks, Chris
  • englertm Apr 27, 2009
    Same Exact Problem with mine. Very disappointed with GE and Sears. Only problem is that I am unsure which part to by or what is the root cause of the problem. It is almost like the ice make is stuck in dethaw and causes the ice in the catch basin to melt. S/N F414304 Model PSH25NGSA
  • Anonymous Apr 28, 2009
    I have the same problem. The tube down the back wall of the frig is frozen and overflowing. You neeed to remove the back wall and use a blow dryer. I am looking for a page that shows how to do this and found this problem page here.
  • GE Master
  • 4,655 Answers
Ice makers have limit switches, thermal temp sensors, heating element and if anything gits out of order with these parts they will begin to do strange things like that. Now if you would like to remove it and have a look at the internal parts you may find the problem. They are a little easy to loose parts so be careful if that's your choice. A series of about six different cycles happen when they fill until the time it empties and begins again. They may cost less if you don't see what wrong to purchase a new ice maker. If you would like more help feel free to ask, Thanks, Sea Breeze
Posted on Apr 21, 2009
GE profile performance fridge, model TPS24BPCE BS..... water dispenser not working. Ice ok. Water coming into it from main line, but doesn't appear to be getting into filter (replaced filter). Any...
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
The icemaker is 110v
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
If you still have trouble GO HERE:
hhttp://www.applianceaid.com/procedures.htm
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
Sep 15, 2011 | GE Profile PSF26NGW Side by Side...
I have a ge refridgerator side by side model gsh25kgmd bb. I bought it in 2002. The issue is, the ice maker. It has stoped working. I notices there was a lot ice build up in the back below the ice...
NOTE: This
First I would check the fan in the freezer. Listen to see if it is running
.I'm including my article on Refrigerator Repair for your help and convenience.;
Leo Ponder
imufo2
Aug 08, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
We recently moved our GE Profile refridgerator to the basement washroom. The plumber recently hooked up the water line for the water / ice dispenser with one issue: the water works but the icemaker is NOT...
NOTE: This
Leo Ponder
imufo2
Aug 03, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Water is leaking down the side and back of the freezer from the ice maker. I have the GE CAN9 ice maker. Were is the ice maker water valve located ?
Bottom right in back of ref.<br /> Its what the water line from the wall attaches to.<br /> <br /> <br /> If this was helpful please rate me.<br />IMUFO2<br />Leo Ponder Appliance-Tyler,Texas<br /><a href="mailto:imufo2@sbcglobal.net">imufo2@sbcglobal.net</a> <br />
Aug 30, 2010 | GE Profile PSW26P Stainless Steel Side by...
Ice Maker leaks water inside the freezer
I see you said you looked and the water valve is off but the only that I know of this happening is a defective water control valve. Like a dripping faucet that when off slowly drips until the ice forms and then one the ice maker dumps ice and tries to refill the water goes in every direction. Unplug water valve to confirm what I am saying, Tell me if it continues to leak. Sea Breeze
Apr 19, 2010 | GE 21.7 Cu. Ft. Top-Mount Refrigerator...
Leaking water in icemaker. water from icemaker leaks into freezer and freezes on freezer wall
If you are sure that it's coming from the ice maker I believe that you possibly have a leaking water control valve on the side for the ice maker on the rear of refrigerator near floor there is a dual water valve control. Many times when this happens the water will freeze in the fill tube that fills the ice maker in the rear of freezer. You can defrost the frozen water in the fill tube with a hair dryer but that will not stop the problem from coming back. When that happens water tends to at times go everywhere but the ice maker. You can test the water control valve several ways. By unplugging the side to the ice maker and if water continues to flow slowly to the ice maker then the dual water control valve will need replaced, Sea Breeze
Sep 10, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker leaking down in freezer along left side. I shut off the water and turned the icemaker to stop. How do I fix the leak?
Look for any tilt in the icemaker towards left, if so loosen both the screws, balance the icemaker.Then tighten the left hand screw first followed by right hand side
p.s the screws will be holding the ice maker with back wall, once you remove the ice bucket it will be visible
Aug 03, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water coming from ice maker freezing down back wall of freezer
check for levelness of the ice maker also make sure that the fill tube is inserted all the way into the unit
Apr 25, 2009 | GE GSS20IEP Side by Side Refrigerator
Ice maker water leaking
Is the fill tube in the cup? also is the ice maker the correct ice maker for the unit.
Mar 25, 2009 | Frigidaire FRS3R5EMB Side by Side...
Ice maker feeding too much water and overflows
I have the GE Profile TFX24PR that exhibited the same symptoms. I had water leaking, making ice in the bottom of the ice bin, as well as under the ice bin. I also discovered ice down the back wall of the freezer.
A technician replaced the ice maker, which did not solve the problem. He put the original back and replaced the valve on the back. That too did not solve the problem. I took matters into my own hands.
I discovered that the ice maker water fill tube that comes in through the back of the freezer wall was leaking. Water would run down the outside of the tube. Some of the water would go into the ice maker, some would go into the ice bin and some of the water would also run down the wall of the fan housing where it passes through a hole in the fan housing. The big problem was the water running down the wall of the fan housing. From there it ran onto the cooling coils, where it would freeze, causing the freezer to go into extended defrost. My freezer and fridge would warm up and I had some food spoil.
If this looks like it may be your problem, you may want to enlist some help for this; it is tedious, time consuming and requires working in the confined spaces of the freezer.
After disassembling the fan housing I was able to access the fill tube. It just pushes in and is prone to wear, especially after fourteen years. I just reversed the ends of the tube and pushed it back in for a snug fit. You may want to consider using a sealer. Everything is working fine now; lots of ice in the bin, and no stray ice or water.
Nov 21, 2008 | GE Profile PSW26P Stainless Steel Side by...
Refrigerators Logo
207 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
