Question about Kenmore Oasis HE 27082 Top Load Washer
Continous cycles My washing machine as soon as i try to go to one of the cycles it will just cycle thorugh the soil levels and not stop. I went on all night last night until i got up this morning. If i unplug it for about a week it will be good for maybe a day or two and then back to the same thing. Can anyone help me with this.
  • LiboAK Feb 23, 2009
    That me too.
    What should i do.
  • 290 Answers
Replace the user interface board. It is the board mounted to the inside of the console.
Posted on Oct 05, 2007
  • Dave
    Dave Oct 15, 2013
    I replaced that it did not work. still cylels on its own!
SOURCE:
Wash cycle are running to long
FIXED Maytag Neptune, Timer Problem - ApplianceBlog
www.applianceblog.com/.../23387-Maytag-Neptune-Timer-Problem
Mar 4, 2011 - 8 posts - ‎3 authors
My countdown timer is stuck at the 33-minute level in the "wash cycle", and repeatedlyruns for a 30-40 seconds, then stops, then runs, then ... Maytag Neptune TL Washing Machine stops in spin cycle ...
Jul 25, 2013
Maytag Neptune Washer Won't Spin/drain
Jul 4, 2013
Neptune TL Washer FAV6800AWW - DC and UC ...
Jul 3, 2007
MAYTAG NEPTUNE WASHER CONTROL PANEL ...
Jun 29, 2005
More results from www.applianceblog.com
Troubleshooting a Too-Long Wash Cycle - whirlpool washingmachine ...
ask.metafilter.com/233920/Troubleshooting-a-TooLong-Wash-Cycle
Jan 25, 2013 - We have a Whirlpool Duet washing machine (about 2 years old). Thecycle is taking WAY too long to complete. The load that's running now ...
Maytag Neptune washer repair: motor/motor control circuit ...
? 12:10
https://www.youtube.com/watch?v=ITTbDh8CFEU
Dec 11, 2013 - Uploaded by daytonaturbofreak
Maytag Neptune washer motor/motor control circuit board ... my board just fried - is your washer still working? wondering how longthe conversion fix will last. ... Other times it will run a completecycle without any malfunctions.
Jan 11, 2016 | Maytag Neptune MAH5500B Front Load Washer
How do I repair a Cabrio washing machine
Press the cancel button all indicator lights/LED should be off
Select any button except Power, Start,Pause/Cancel
e.g. select buttohttp://www.fixya.com/answer/answerpageslideview.aspx?thid=25219265&ctg=130n "Soil Level"
Press "Soil Level" button and hold for 3 seconds
Release "Soil Level" button wait for 3 seconds
Press "Soil Level" button and hold until "88" lights up on the display and all indicator lights turn on
Watch the display flash any error codes will be displayed. e.g. "81" , "F", etc
Take a note of the numbers and letters displayed, press the "Soil Button" and the next set of codes will be shown. Press the soil button a few times noting down all the codes until "88" is displayed.
If the "Soil Button" doesn't work try another button using the same procedure above exluding any of the buttons mentioned above.
Please post the error codes you have noted.
Oct 13, 2014 | Washing Machines
We have a kenmore model # 11027082601 it stays in the wash cycle, cause the soil level and the time keeps rolling between heavy to light. and does not finish cycle. when you cancel wash then use the...
Try resetting the board first by unplugging for a few hours. It's like rebooting your computer. This will load fresh code into the board. If it persists, it's a board issue.
Oct 15, 2013 | Kenmore Washing Machines
Calypso washer is unable to get through cycles without start/stopping every 30-45sec. I have run the diagnostic test pushing (Soak then Soil Level, Soak then Soil Level) it counts down from 99-0 going...
after and hour off will it make it through the cycle? if so the motor could be over heating and shutting down. if not look and see if the pump turns freely and if there is an idler pully make sure it turns freely. check between tubs outer and inner for any sock or piece of clothing that could have went over the tub on a large lode and causing a resistance.check for a pinched off drain hose which will not allow it to drain. it has to drain to spin. or it will over heat pump. could be something caught in pump. try not to get wet,. done that alot when i had my business.
May 26, 2012 | Whirlpool Calypso GVW9959K Top Load Washer
There is black residue left on the clothes after the spins cycle! It looks like soil? I have unscrewed the long thing in the middle and washed it clean but still the clothes aren't coming out 2 clean....
Hi just read your posting.Now select hot fill, high water level,and put 2 pkts of bicarb of soda in the empty tub.Start the cycle and let it fill and then let the machine wash for 5 to 10 mins.Do not let the water drain out.After 5 to 10 mins stop the cycle and let the water and bicarb soak over night.In the morning restart machine and this should clean the bowl.Please reply on how you got on or for further help.Looking forward to your reply.
Jun 19, 2011 | Washing Machines
How can I reduce the time needed for a wash ? It takes 2 hours is there any way to make it less ?
Most machines have a soil level selection (light / normal / heavy) and if you select light soil level the wash time is reduced. Also, some machines have a " Quick Cycle " which cuts a lot of time off, which should only be used with lightly soiled clothing. Additionally, make sure you have adequate water pressure, and that the inlet screens are clear so that the cycle is not delayed essesivly due to slow water fill. Regardless of all these, the higher spin speeds of a front loading machine (those have the longest wash times, due to the low water use and the tumbling wash action used vs an agitator in a top load machine) will result in reduced dryer run time, thus helping to reduce the overall time a load takes to wash and dry. (although still longer than most top loading sets) Generally, the energy savings and larger load sizes will outweigh the extra time the machines take.
Sep 16, 2009 | Washing Machines
Soil level light cycles by itself.
unplug the machine. take the computer broad out of the control switches. Clean the resadue off both sides of the broad, with a small amount of hydrogen peroxide and a q-tip. Dry it off !!!!! put back to getheir and turn it on. that should fix it!
Apr 05, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Water level buttons keep cycle through continuously and the estimated time changes with the soil level.
hi thanks for the question. the actions of this washer that you are describing is normal these washers are a real pain in the you know what but it is normal welcome to the way they are building them to-day
Sep 19, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Starts to fill and then stops, and the cycle continues on.
Jmars, under the consol there is two pressure switches. One controls the fill and the other is back-up incase the other fails. It sounds like your water pressure switch is tripping too soon. Try putting the washer into a self test mode by pressing in this order soak--soil level---soak--soil level. The machine should enter a test mode. Let it run it's test and see if you come up with any error codes. The pressure switch is the one on the left under the consol. It will be marked OPR, the part number is 8054766. The consol will lift up by using a putty knife under each end, pushin on the clips and lifting up. The back panel of the consol is removable. Catriver..post back
Apr 14, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Trouble starting Cycles
Jonsey, sounds like you have a keypad issue here. Do this test: press the following keys in this order soak-cycle signal-soak-cycle signal. If done right the display should show dt. Now press start, all the led's will light up. Now test them by pressing each one, you should hear a beep for each one. If some of them are not responding, check the P-11 and P-12 harness on the control board. You can also put this machine in the automatic test mode by pressing the keypads in this order; soak-soil level-soak-soil level. The display will start counting down from 99 to 0 testing different aspects of the machine. Any errors will be shown in the display. Catriver..post back.
Nov 13, 2006 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore Oasis HE 27082 Top Load Washer Logo
fordexpert
Kristen Denison
Kristen Denison
Level 1 Expert
Gordon Richard...
