Question about Kenmore Refrigerators
Kenmore coldspot model 57077791, freezer and refrigerator not cold. does this model have a freon check valve? don't see one. either out of freon or the compressor is broken. compressor feels hot to the touch.
  • 3 Answers
SOURCE: refrigerator condensation
I have a Kenmore Coldspot Model 70262990. When I get wet shelves (water, not just condensation), I was able to trace my source to the cold air vent from the freezer. In my case, the water melts from the evaporator and collects in the rear lower section of the freezer. It is "supposed" to go down the drain tube. However I had the drain hole freeze over. Then additional water from the defrost cycle would accumulate in the freezer floor (under the plastic floor) and eventually find its way down the cold air vent between the freezer and refrigerator section. You'll need to unplug the unit, take the plastic floor out of the freezer, remove the evaporator panel to access the defrost drain, melt the frozen water (hair drier works nice), and remove all the water (towel/sponge & bucket). Make sure the drain is not frozen and not blocked. Then put it back together and plug it in.
Does anyone know how to stop the drain tube from freezing over?
Good luck.
Posted on Apr 26, 2008
  • 172 Answers
SOURCE: Kenmore Coldspot w/Ice Maker Not Making Ice
hi LOP7,
In most cases you can easily solve this problem.
step one would be to make sure your freezer is getting cold enough. If you have icecream in your freezer is it frozen solid or is it soft. Most icemakers cycle around 0 degrees and if your freezer is not getting to 0 then it will not cycle and it will not make ice.
Step two would be to make sure you icemake is cycling. To do this simply lift the little shut off arm on your icemaker and wait about an hour then go back to the icemaker and drop the arm down. The icemaker should start going through a cycle. You should notice the arm slowly begin to raise and the ice dispencer fingers will begin to turn. Then you will hear it call for water. You may hear a humm.
If the freezer is cold enough and the icemaker is cycling that only leaves the inlet valve. replace the valve and enjoy the ice.
If the freezer is cold enought and the icemaker does not cycle, then you have a bad icemaker. Simply replace the icemaker and viola.
Third if the freezer is not cold enought 0 defrees. Then you may have a defrost problem. In this case post more info and I will be happy to help. Good luck mca0824@aol.com
Posted on Apr 30, 2008
SOURCE: Kenmore Coldspot Side by Side Model 51559101
I also have the same refrigerator model 106.56566400 and periodically when the power goes off in the house the refrigerator & freezer will stop cooling. Try pushing the on/off button located inside the refrigerator to the left of the digital temperature controls. Hold the button down, this turns the unit off, then press it again to turn it back on. This basically resets the refrigerator, and most of the time works to get the refrigerator cooling again. Try this first before calling a repair man.
Posted on May 14, 2008
  • 6 Answers
SOURCE: water line broken for Kenmore refrigerator near compressor
Cut off a piece of line and go to a good hardware store, they can show you how to fix it. Need a coupling, and a nut and ferrel. House water line goes on one end of coupling, nut and ferrel on the broken water line on fridge. A good hardware store will be able to show you how to fix.
Posted on Aug 07, 2008
rpbuice
  • 161 Answers
SOURCE: kenmore refrigerator compressor clicking
Relay on the compressor bad.
Try unpluging for 30 - 45 min until the compressor has cooled down then plug it back in. If it doesn't start replace the relay. Most service techs carry a universal relay and wiil put the relay on, if it starts, your good to go, if not, then the compressor is bad.
Posted on Dec 17, 2008
I have a side by side kenmore coldspot model 52259100. The Refrigerator is not cold but the freeze is cold. Help!
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 28, 2010 | Kenmore Refrigerators
Kenmore coldspot model 106-54592400. The refrigerator is not getting cold enough, has been hovering around 45 to 50. The freezer is working.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
heatman101
Nov 10, 2010 | Kenmore 50522 / 50524 Side by Side...
Kenmore Coldspot model 106 - Snowing in freezer!
its not defrosting. check heater operations. bimetal near heater. check defrost timer
Feb 08, 2010 | Refrigerators
Need a service/repair manual for a Kenmore refrigerator.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Is the evaporator fan in the freezer running. It blows cold air into the fridge side through a damper in the wall between the freezer and fridge. Make sure the damper is open.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Part 4 on this diagram is your timer http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=1069608210&productCategoryId=0160000&brandId=0582&modelName=REFRIGERATOR&diagramPageId=00003&componentDescription=COMPARTMENT%20SEPARATOR%20AND%20CONTROL&documentId=00050440&backToLink=Return%20to%20subcomponent%20list
Aug 13, 2009 | Refrigerators
Freezer cold fridge 52 degrees
We have a Kenmore Coldspot Model # 106.8770687 and the freezer is cold and keeping things frozen, but seems to be frosting over and the refrigerator is warm at 40 to 50 degrees ... any help regarding what to check is helpful! Or a schematic / manual
Jun 14, 2009 | Kenmore Refrigerators
Kenmore Coldspot is on but not cold after power blackout
The reset is called a klickson it is inside that black cover on the side of the compressor.
sometimes they do fail.
Dec 28, 2008 | Refrigerators
REFRIGERATOR OR FREEZER IS NOT COLD OR WILL NOT FREEZE
Check freezer... for Frost build up and if Fan is blowing, Check condenser... To make sure clean, and the fan is blowing by compressor, Check Recirclating Vents in refrigerator... to make sure theres no blockage, CONTROLS ...should be in the middle setting,
Sep 11, 2007 | Kenmore 22.0 cu. ft. Side-By-Side...
Refrigerators Logo
213 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
jackdo2
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
