Question about Tools & Hardware - Others
Framing nailer intermittently doesn't shoot the nail.
Porter Cable FC350 Clipped Head Framing Nailer. Gun fires everytime I pull the trigger but it often does not fire the nail. I have cleaned and lubricated but no help. Any ideas?
    President:
  • 1,996 Answers
Make sure to blow out the magazine where the nails load, make sure the spring tension on the nail clip is working properly, make sure you're not holding the clip somehow with your off hand so the clip can't feed correctly.
Posted on Apr 20, 2009
Can you use 30 degree nails in a Porter Cable FC350 34 degree nailer?
Yes, you can use 30 degree clipped head nails in the Porter-Cable FC350 framing nailer. The FC350A and FC350B nailers are newer models that specify the 30-34 degree clipped head nails. Make sure that the nails are between 2' - 3 1/2" in length. The manuals for each of the later models do not explicitly list the 30 degree nails. Their specifications page do list the 30 degree nails. See http://www.portercable.com/Products/ProductDetail.aspx?ProductID=11542 and https://www.homedepot.com/p/Porter-Cable-3-1-2-in-30-Degree-to-34-Degree-Clipped-Head-Framing-Nailer-FC350B/203555581 . The manual for the FC350 is available here: https://www.manualslib.com/manual/132288/Porter-Cable-Fc350.html . It is the same as the manual for the FC350B, https://www.homedepot.com/catalog/pdfimages/7e/7e0d0f88-a9e7-4411-ad0f-7fc5c1c1fbaa.pdf .
I hope this helps.
Mar 21, 2018 | Porter Cable Air Tools & Compressors
How do I release the trigger lock on a brand new porter cable nail gun
Are you depressing the nose of the nail gun against the material to be nailed first? Without doing this, the trigger will not "unlock". You can read a pretty in-depth review of this nail gun at OnlineToolReviews com Porter Cable FR350A Full Round Head Framing... which might also help.
Jul 16, 2014 | Porter Cable FR350A Factory Reconditioned...
Can My FC 350 A used 28 degree nails
The manual for your gun specifies 34-degree nails from 2 to 3 1/2 inches long. 28-degree, wire collated nails are a Stanley-Bostitch thing and they only work in their nail guns, they will not work in your nail gun. You need 34-degree, paper-tape collated nails. I know Senco framing nails will work in your gun and I think Duo-fast makes 34-drgree nails but check that before buying them.
Mar 03, 2013 | Porter Cable Factory-Reconditioned...
Nail gun will not shoot a nail
Check the safety trip make sure it is pushing back far enough. If it doesn't then it won't do anything. When it was fine just moments earlier.
Feb 05, 2013 | Dewalt D51822 Clipped Head 2Inch to...
How do i load nails in my porter cable clipped head framing nailer...
Pull lever back on top of clip, slip sleeve of nails into slot, then release lever to push nails forward as you use nails.Make sure you are you the right gage of nail.
Jun 18, 2011 | Porter Cable FactoryReconditioned DA250BR...
Porter Cable FR350 Round Head Framing Nailer not firing
check and make sure your compressor is at the right psi. 120psi. is there any nails stuck in it. there may also be a problem with the seals.
Mar 08, 2010 | Garden
My hitachi nr 90 gc nailer was always slow to fire a nail with about a second delay between pulling the trigger and firing the nail. now however the gun will only fire a nail once in about 20 attempts, and...
Trigger may be dirty, as an electrical switch the contacts can be intermittent. Also check to see if the safety plunger is set to correct depth and moving freely. Dirt can build up here......
Feb 14, 2010 | Hitachi NR90GC 3 1/2" Gas Powered Clipped...
Wiil a 22 degree Paorter Cable FR350A Round Head
No... it will fire 21-degree nails and perhaps 23-degree nails (but sont think they exist) and it is a full-head framing nailer so it is designed for firing round head nails. Using clipped nails will likely jam the nailer as these nails are stripped closer together with overlapping heads in the nail strip and the FR350A has a full round driver so you will run into issues with clipped nails. If you are having problems finding full round head nails, you can find them on Amazon to fit this nailer. Otherwise any good tool or trade tool store that sells nailers will likely have a suitable nail supply available for the FR350A.
Feb 09, 2010 | Porter Cable Air Tools & Compressors
I have a FC350A FRAMING NAILER, IT IS IN THE
check to make sure that there is not a nail jam , if the driver will not retract then the gun will not cycle . if no nail jam then replace the inner trigger
Feb 02, 2010 | Air Tools & Compressors
Tools & Hardware - Others Logo
257 people viewed this question
Top Tools & Hardware - Others Experts
john h
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
