Question about Jensen (654658) CD Player
Jeson Cd Player
I am trying to install a cd player in my car,but I don't know the Anti Theft Code for it.Can you please help me? The Model Number is Cd5050 And the Serial Number is GS41213430 Thank Yo for your time.
  • 752 Answers
You will have to obtain the code from the person that entered it. That's why it's there.
Posted on Sep 22, 2007
When i try cd it keeps writing error.and reject every cd plates i insert.it was playing normal 2days ago.pls what do i do when error notice appear.the car is honda 2003 model coupe.thanx
Unfortunately 90% of the time when you get error codes from the CD player/changer it means that there is a mechanical failure in the CD player/changer unit itself and it usually requires CD player/changer rebuild or replacement...
First make sure you have entered the correct anti-theft code. If battery power has been disconnected recently than the stereo display will read CODE if the incorrect anti-theft code is entered the display will read ERR1 thru ERR3. If this is the case you'll have to get the correct anti-theft code. Note; If you enter the incorrect code three times the stereo locks up. Disconnect the battery for more than 30 seconds and then retry.
FYI;Never use adhesive labels or protective disc covers on recordable CD's. Recordable CD's are actually thicker than pre-recorded CD's. Automotive players and changers use rollers to draw the disc into the unit. The added thickness of an adhesive label or protective disc cover may cause the disc to jam. Also CD players and changers are exposed to high temperatures inside the vehicle. High temp will cause the labels adhesive to soften which may cause the labels edges to curl or cause it to bubble. Either one may cause the disc to jam. If the player can not be disassembled and have the discs removed successfully than it will have to be replaced. -hope this helps.
Oct 18, 2010 | 2003 Honda Accord
1998 Honda Accord EX stereo/CD player has Code E on the screen... What is the cause of this and what can I do to fix it?
FYI;Never use adhesive labels or protective disc covers on recordable CD's. Recordable CD's are actually thicker than pre-recorded CD's. Automotive players and changers use rollers to draw the disc into the unit. The added thickness of an adhesive label or protective disc cover may cause the disc to jam. Also CD players and changers are exposed to high temperatures inside the vehicle. High temp will cause the labels adhesive to soften which may cause the labels edges to curl or cause it to bubble. Either one may cause the disc to jam and cause the player to display error codes E-01 thru E-07. If the player can not be disassembled and have the discs removed successfully than it will have to be replaced. -hope this helps.
Oct 18, 2010 | 1998 Honda Accord
I forgot the anti theft code to my CD player in my car and i dont know how to reset it?
pull the radio out and take the serial number ro the dealership
Feb 27, 2010 | 2000 Honda Accord
1988 bmw 325si manufacture radio is missing but wiring cluster is intact apparently. Do i have to have a stock radio replacement or can i install a cd player deck without causing problems???
Generally you any after market radio can be installed into any car. You might have to cut the original wiring connector but basically all you need to hook up a basic radio/cd player is a positive and a ground wire. That's what powers the radio/cd player. Next all you need to do is hook up the speaker wires the unit. One other option is to check out ebay for a used radio/cd player. You will do better getting a radio that does not have an anti-theft feature. If it has an anti-theft feature you will have to enter a code to make it work.
Feb 11, 2010 | 1988 BMW 3 Series
Car won't statr after cd player was installed
dont know for sure try unhooking battery for 15-30 min
Jul 13, 2009 | Vehicle Parts & Accessories
Need to know how to install new radio in a 2001 mitsubishi eclipse
call 1888mitsu2001 and hit option #4, then hit * (star), give them the last 8 digits of your vin and they will provide the code for FREE.
DO NOT PAY FOR THE CODE ONLINE OR GO TO A DEALER (they will also charge).
May 09, 2009 | 2001 Mitsubishi Eclipse
2002 Lincoln LS electrical systems down- won't start
Removed CD player for jammed CD. Reinstalled but car ignition and most electrical sytems won't operate although fuses appear OK. Don't know if it is related to the anti-theft system.When ignition is turned on, both tach and speedometer needles peg out and return to zero but no type of ignition
Apr 05, 2009 | 2002 Lincoln LS
Daewoo Car CD Player Code
try codes 6620,0191,6012,4797,or 1305 i will try to find some more but i need the seiral number to know for sure they have diff ones for each unit
Dec 10, 2008 | 2001 Daewoo Lanos
Jensen (654658) CD Player Logo
66 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
