Question about Everex IMPACT GC2500 PC Desktop
Reset password I can't remember my login password. I want to do a hard reset or get back to factory settings. How ca I do this for my everex impact desktop?
  • 371 Answers
Use the original disks you used to install your operating system to reinstall the OS and reset your password, but you will lose all unsaved non-backed up data.
Posted on Apr 20, 2009
I forgot my username and password
Every router I have ever seen allows you to reset the configuration to factory default - but not allow you to retrieve a forgotten password and maintain your settings at the same time. This is often referred to a "factory" or "hard" reset.
When you initiate a factory / hard reset, typically by pressing & holding a button on the router - or behind an opening in the router case - all the changes you've made to it will be returned to the factory default. Wifi becomes "open" with no password (on most devices), the login username / password also go back to default settings (common ones are: admin / admin, admin / password, <blank> / admin, <blank / password, etc.). Consult your router's set up guide or online documentation to learn what the factory / hard reset procedure and the default settings.
Once you gain access to the setup pages of the router, configure it as best as you can remember, and lock it down with good security settings. At minimum - this should include changing the router's username / password, the WiFi's SSID and do not broadcast it, add WPA or WPA2 encryption and secure it with a security key (use a mix of numbers, letters, symbols etc.).
I suggest recording the settings on paper and then tape it to the bottom of the router. There it will remain out of sight - but ready when you need it.
Oct 17, 2014 | Computers & Internet
Tip
How do I reset LinkSys Router Default Password?
When you forget your Linksys router password, you will need to reset it back to the factory defaults. You can restore the router configuration to back to the factory by following the steps outlined below:
1. Hold in the reset button of the router for 30 seconds. 2. Unplug your power cord for 30 seconds 3. Plug back your power cord4. Wait for a few seconds then release the reset button.
NOTE:¨ When holding in the reset button, make sure that you do not release it until you are sure that it has been compressed for at least 30 seconds or more.
¨ This procedure resets the router back to all its factory default settings thus apart from affecting your username and password, it will also affect your configuration and IP addressing.
Once this is complete, you can now login and reconfigure your password. To do this:
1. Connect a PC to one of the Linksys router Ethernet ports
2. Open your web browser and go to the URL http://192.168.1.1. This will take you to a web page with a popup box which asks you to enter a username and password to login required to login to your router
3. On older LinkSys routers, the username is set to blank and the password is set to "admin" (without the quotes). On newer Linksys routers, both the default username and the default password are set to "admin".
4. Click on login. You have logged in to the Administrator account and are now able to access and change a number of configuration options for your router.
5. Click on management tab then change your administrator password to any password that you like. Remember to choose a strong password that others cannot guess but that will be easy enough for you to remember.
6. You can also choose to reconfigure other aspects of you Linksys router at this point.
on Nov 25, 2010 | Computers & Internet
For got password would like to reset username
Can not log in right using my username and
Oct 16, 2014 | Computers & Internet
How to do a factory reset on my Everex impact GC3500
You'll need to reinstall windows, look for an install disk that may have come with your computer, or look for a message when your computer starts up that says something like "Press x to show startup options", and select recovery.
Feb 01, 2014 | FIC REFURBISHED EVEREX IMPACT GC3500...
Can't remember my password on everex laptop
you can download a piece of software called ophcrack and burn it to a cd, then put the cd in when the computer turns on and it should be able to crack the password for you.
Jul 11, 2012 | Everex StepNote Computers & Internet
I cant remember my password
press the reset button the back panel of your router for 5 secs while keeping it powered ON.
The router would set back to factory settings and password wiped off
Apr 10, 2010 | Belkin (F6D3230-4) Router (F6D32304)
Reset password on model 615
The router login or wireless network password.
Login in using your browser and go to the wireless settings and set-up a wireless password/key. Remember the key because each device will now need it to connect. You can also turn OFF Broadcast SSID and your network name will not be shown on anyone's device. You must remember the network name when using this method.
The router password you will have to try The final solution is a factory reset of your router. You can do a factory reset by logging into the router using you browser. Go to the settings and perform a factory reset
If you forgot the router password, you ill have to do a factory reset by locating a small hold on the back of the router and insert the tip of of paper clip for about 10 seconds while the power is on. The router will be reset to out of box status and then you can set-up form scratch.
Oct 11, 2009 | D-Link Computers & Internet
Would like to take the everex impact ga3400 back to
Use your recovery cd\dvd to re-install your operating system.
Sep 11, 2009 | Computers & Internet
I am trying to set up my wireless system, however I no longer have the software, I am using my wireless router on another computer that was exactly the same as the one I had installed it on. I cannot...
You have to reset it to the original factory settings. Refer your owner's manual on how to reset. Usually there is a small pinhole switch which you need to keep pressed for about 5 seconds.
You will lose all settings and will have to configure your router again.
May 06, 2008 | Computers & Internet
Everex IMPACT GC2500  PC Desktop Logo
101 people viewed this question
Top Everex Computers & Internet Experts
Jerry Umali
Martin Murray
Are you an Everex Computer and Internet Expert? Answer questions, earn points and help others
