Question about Kenmore Washing Machines
No warm or hot water
The machine will only fill and wash with cold water. If the setting is on warm/cold or warm/warm..it will still run only with cold water. If hot/warm is selected, the machine won't even fill.
    Scholar:
  • 126 Answers
The easiest possibility is no hot water coming from supply,I have seen the valve turned off,input hose normaly has a filter where it attatches to the machine and they can get clogged.If neither of these solves problem just try hot valve to confirm water supply does work and if so more than likely the valve that hoses are connected to likely source of problem.
Posted on Apr 20, 2009
5 Suggested Answers
  • 641 Answers
SOURCE: mav6000awq water fill problem
Check first the filters on the cold inlet water line (both sides). Then, if problem still exist - check that the cold inlet water valve works(it is an electromagnet valve, located at the pipe's entrance to the machine)). If it doesn't work, test that it get power. In case it get power and doesn't work - You can easily open the valve and clean it (from scale or other dirt). Be aware you should disconnect the power cable from machine before doing it !!!! Check as well for valve's coil resistance. In case you have no resistance measurement - you should replace it for a new one. Good luck
Posted on Sep 04, 2007
jsrock516
  • 5911 Answers
SOURCE: no hot water from my washer
The problem is your HOT water solenoid on the water inlet valve. On some washers this is also known as the mixing valve. Since the washer uses hot water for both the hot and warm settings, its logical to assume you have a solenoid that isn't operating. The following link gives you the necessary steps to replace the inlet valve (if necessary):
http://www.fixya.com/support/r600647-replacing_water_inlet_valve_kenmore
The first thing you can try is to determine if the valve may be clogged. If you live in an area that has hard water, or if you use well water, sediment can build up in the filter screens of the valve. You can access by turning off the water supply and removing the hose from the back of the washer. The sediment screens are located in the valve fitting. Sometimes the hoses have restrictor screens in the ends that can also clog or obstruct water. Try cleaning with some distilled vinegar and cotton swabs to dissolve any deposits.
Another source of the problem, could be the electrical connection to the solenoid. With the exterior washer case removed, you can access the electrical connections to the valve and remove them. Clean the contacts if corroded.
If all these preliminary steps do not solve your problem, replace the valve. A replacement can be purchased on line at searspartsdirect.com, appliancepartspros.com, pcappliancerepair.com, or repairclinic.com. Just type in your model number for your search criteria. All these sites offer great service with competitive pricing, so shop around for the best price.
If you have questions along the way, let me know. I hope this helps you.
Posted on Jun 12, 2009
erpaalai
  • 999 Answers
SOURCE: The washing machine won't start if
Check the cold water solenoid. If a meter is not available you can swap the hot and cold wires and see if the symptom changes to hot water when cold is selected. If so the mixing valve needs replaced. If no then further testing of the wire harness and timer circuit are needed.
Eric
Posted on Apr 13, 2010
smartr10U
  • 1305 Answers
SOURCE: Fills cold and warm but not hot
This is a common problem with hot water lines to washing machines. The hose connecting the washing machine to the hot water supply has a small screen in the inlet of the hose. These are used to keep grit, etc from getting into the washing machine and causing bigger problems.
Here's what to do:
Pull the washing machine away from the wall a little so you can access the shut-off's. Turn off the hot and the cold water valves.
Take the hot water hose off the valve and check the screen in the rubber washer of the inlet hose. Replacement screen/washers are available at local hardware stores for a couple bucks.
You can clean the old ones, just be careful not to damage the rubber washer because that's what keeps your hose from leaking when you reinstall it on your faucet.
While you're at it, clean the cold water screen as well.
REcheck your fill on a hot cycle... you've most likely solved your issue!
Posted on May 09, 2010
Hot water fills for very short time on "Warm" setting - wash cycle is too cold
check either ur water temperature switch or and ur water inlet valve with a multi meter for continuity OHMS
Oct 16, 2014 | Amana NTW4650YQ 3.4 cu. ft. Top Load...
EW1200 is rinsing in hot water how do we change that
Hot wash, hot rinse is for 'whites'. Cold wash, cold rinse is for 'colors'. Warm wash, cold or warm rinse is for 'permanent press'. Check your settings to see if you have these options. Double check the hoses, put the machine on cold fill and feel the hoses.
Has someone worked on the machine and possibly put the wires on the solenoids wrong? Easy mistake to make.
Mar 10, 2012 | Electrolux EW1200i Front Load Washer /...
Maytag Performa wont fill hot water
The water fill valve - The water fill valve is a mechanical and electrical part, the coils on the valve need electricity to mechanically open the valve to allow the water to flow into the washer....myth....the washer pumps water into itself...no, it does not. The fill valve opens and the house water pressure pushes the water into the washing machine.
No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can test a fill valve live for 120 volts, power to a fill valve coil and no fill = a bad fill valve. You can also test the coils for continuity, no continuity = a bad fill valve. Some Maytag washers have a fuse in the fill valve circuit, if this fuse let go the washer will not fill. Fill valves can also from time to time stick open and not stop filling. If you have to shut off the fill valves to stop the water from filling in the washer, you have a bad fill valve and you will have to replace it.
Nov 27, 2009 | Maytag Performa PAV2200
Washing Machine Rinse and Spin lights are on
its the problem of drum getting blocked by any clothes getting tucked up.also try to move the drum manually with the machine off.if it makes any noise its the faulty motor.or drum has lost its alignment.it needs to be reseated properly in that case. -------------- The water fill valve - The water fill valve is a mechanical and electrical part, the coils on the valve need electricity to mechanically open the valve to allow the water to flow into the washer....myth....the washer pumps water into itself...no, it does not. The fill valve opens and the house water pressure pushes the water into the washing machine.
Jul 23, 2009 | Tricity Bendix AW1400W Front Load Washer
My whirlpool front load washing machine accept hot water and no cold water entering on the machine.
Apr 01, 2009 | Whirlpool GHW9400 Front Load Washer
Washer will not fill up with hot or warm settings, only cold.
kenmore washer hot or cold fills ok but will not fill with warm but only cold water
Mar 15, 2009 | Kenmore Washing Machines
I have the washer on cold water, but it runs warm, stops, trickles, then comes out warm again, stops, trickles, then warm again ect.On the rinse cycle it will only trickle out.
Mar 03, 2009 | Washing Machines
Cold water not running.
check the cold water selenoid on the water valve
May 05, 2008 | Washing Machines
Washing Machines Logo
157 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
