Question about Epson PictureMate 500 InkJet Photo Printer
Fatal code: 0x2
I can't print a picture, the screen keeps telling me to see the manual for fatal code: 0x2 but i don't have my manual.
  • westfields23 Apr 27, 2009
    Th eprinter shows fatal error code 0x2 on start up. Have tried the usual unplugging, rebooting, take out cartridge (shake) and return.
2 Suggested Answers
SOURCE: I have the picture mate personal photo lab and the error code 0x2 comes up when I turn it on and I am not able to do anything else
I had the same error and I could find no information on what it was or how to fix it so I decided to go trial and error. What I found is that this relates to the print head not being able to completely pass from the left to right side during startup. I had a plastic carriage on the one side that was stuck in a position that stop the carriage from make the complete run from side to side. When I forced the plastic carriage down and it clicked into place the error stopped and the printer started up normally with no codes. If anything is causing the print head to not travel completely from left to right during startup, this will probable cause the code. It will be hard to see if the print head is being obstructed if you don't remove the sides. I hope this helps.
Posted on Sep 25, 2009
Advent roma 1000 will not start up.
Hard disk drive has failed. Replace it.
Mar 03, 2017 | Advent Computers & Internet
Error code 0x00000002
STOP 0x2 DEVICE_QUEUE_NOT_BUSY error code has a value that is 0x00000002. This is a fatal error typically known as STOP message or Blue Screen of Death (BSOD).
This error generally occurs in Windows XP but may also occur in latest version of Windows such as Windows Vista or windows 7. The computer may stop responding without warning. Moreover, your computer may give error messages like STOP 0x00000002 error or related errors and if blue screen appeared then you may have to restart the system in the mean time of your work due to which unsaved work will be lost.
Cause of Error:
  • You may be using corrupted profile in your system which raised this problem
  • The device driver of your system is not updated
  • Malfunction of hardware usually is the cause of error such as STOP 0x2 DEVICE_QUEUE_NOT_BUSY or similar error
  • Registry database of your system may have corrupted or modified erroneously by invalid application
  • You have installed new hardware unsystematic or installed unknown application
  • Spyware has infected the PC
  • Antivirus software is not working
  • The operating system or application might have run out of usable memory.
This is one of the serious problem in computer if it is not resolved instantly then it might create some more unexpected error. STOP 0x00000002 error and its related error will disturb you all the time and you may have to bear loss of data. When blue screen of death appear on your monitor screen then you need to restart directly whether you have saved your work or not. Therefore, you are suggested to fix STOP 0x00000002 error as earliest possible.
How to Fix:
To fix STOP 0x00000002 error you need to follow the following methods.
  • If this error occurs in your pc then you will have to restart the PC and then press F8 key before appearing Windows. You will see a black screen with white text giving many options. Select the option "Last Known Good Configuration" and press Enter. If you have configured the computer improperly then it may fix the error.
  • If you have installed any hardware in your system then the chances is more that the device driver is not updated and thus errors of type STOP are given at the time of operation. You must download latest drivers.
  • If your system does not become stable then you need to try scanning of registry with this tool. Since, registry keeps all configurations of your system if it gets impaired then you must download registry repairing softwareand repair it .
Mostly, spyware has been the reason of various errors in computer system. Spyware damages files in the computer system and if once damaged then it is no longer used and it also corrupt registry database. The file which is infected by virus may be a program file, system file etc. If STOP 0x00000002 error occur in spite of antivirus then download anti spyware to scan your computer.
Hope this information will help.
Your response is very much appreciated. Thank you for using Fixya...
Sep 28, 2011 | Microsoft Computers & Internet
My main computer has stopped working. it is displaying a fatal error blue screen with code numbers at the bottom these seems to be problems with the registary stop: 0x00000024 (0x00190203,0x807ae0b0,...
BSOD - blue screen of death....sorry mate but its seems that a fatal error on your operating system occured....most probably a sure way to fix this is to re-install windows, and lose everything on the hard drive...
Feb 15, 2010 | Computers & Internet
Zenith 32" TV picture is larger than the TV screen size.
Adjust the Aspect ratio. The manual will tell you how.
Feb 02, 2010 | Zenith A32B84R 32" TV
My black ink will not print. Do I have to have
The larger of the two black cartridges is used for text only printing.
The saller cartridge is used for black in graphic images or pictures.
This saves you color ink . It allows you to put the black ink on the image without making the color inks blend the black ink.
Don
Jan 31, 2010 | Canon PIXMA MP780 All-In-One InkJet...
May 17, 2009 | Epson PictureMate Photo Printer
Toshiba power saver keeps on saying that it has encountered a fatal error 0x2 even after i have reinstalled the common modules and power saver HELP I have an M500 portege
try the original laptop recovery cd for the power saver utility of ur specific model...this works best..
many people downloading TPS from the website have had no luck it seems
Apr 14, 2008 | Toshiba Computers & Internet
Line down center of screen rest of screen black
no not fatal, but sick. this problem you are having sounds like you have a vertical sweep problem.. It could be the vertical output IC, the sweep power supply or a capacitor or two is bad. If you have printed circuit board soldering experience, you can try and fix this yourself, but if you do not, play it safe and call in a pro to assist you in this repair as it should not cost more then 100 bucks to repair. Good Luck
Apr 29, 2007 | Thomson 24WK25U 24" TV
Konica Magicolor 5430 DL Fatal Error Code: 0300H
0300H: Polygon Motor malfunction
try restart if not helping then there can be problem with ph unit or PWB-A board
Sep 11, 2006 | Konica Minolta magicolor 5430 DL Laser...
Epson PictureMate 500 InkJet Photo Printer Logo
593 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
