IN MY MONITOR HORIZONTAL OUTPUT TRANSISTOR(C5855) FOUND SHORT. I REPLACED IT BUT AFTER FEW MINUITS IT BECAME SHORT.AFTER CHECKING I FOUND A DIOD(MUR460L)SHORT.I WANT TO KNOW THE FUNTION OF THE DIOD AND THE EQUIVALENT DIOD FOR REPLACE (BECAUSE MUR460L IS NOT AVAILABLE IN OUR LOCAL MARKET).
Comments:
Sep 27, 2007
- IN TOSHIBA (230 CHANNELS)CIRCUIT AFTER ON ITS OK. BUT AFTER FEW SECOND ITS 110 VOLTS BECOME DECREAS SLOWLY TO ABOUT 90 VOLTS.WHEN I DISCONNECT THE VERTICAL SUPPLY ITS VOLLTAGE BECOME OK.EHT AND TDA7698 IC ARE ALSO OK.
-   please tell me equvelant ic fir c5855 for lg monitor -   Guest
Jun 04, 2008
-   my horizontal transistor blows after short minutes.
screen has bad focus. -   bhombagha
Feb 17, 2008
-   i have monitor here lg 500g the problem is green light still flashing.i checked the cpu it is ok. i diagnosed the monitor but i havent found any problem with the horizontal output of the transistor.what would be the next component that i am going to check to solve this problem?-   kemosave
Nov 22, 2007
-   my Horizontal transistor is Short "c5855" can i replace it with "c5929" ???-   prophetx
as your h/output got defective due to short circuit.proceed as follows. isolate h/output section fom power supply& check power supply output is ok as you know high output may give such problem. when it becomes ok, check hor.section 1 h/output 2 cap & diode connected in eht winding. 3 ptint short near eht. 4 at last eht tranf. 5 if it is ok re connect h/output supply. put on set.
your que AFTER CHECKING I FOUND A DIOD(MUR460L)SHORT.I WANT TO KNOW THE FUNTION OF THE DIOD AND THE EQUIVALENT DIOD FOR REPLACE (BECAUSE MUR460L IS NOT AVAILABLE IN OUR LOCAL MARKET). 1 Function of diode is to convert AC TO DC 2 you can use BF159 or BF157 as equivalent.
Lost all color except black. The windows have faded making it very hard to read script including the...
(More)
Lost all color except black. The windows have faded making it very hard to read script including the desktop and start menu bar...
My X2Gen monitor has the power light on (green) but the screen remains black, I checked all...
(More)
My X2Gen monitor has the power light on (green) but the screen remains black, I checked all connections, turned off the power to the monitor and the computer, rebooted, still the monitor will turn on but the screen remains black, wondering if there is a part I can get to repair?
i have zenith 19" TFT, purchased 8 months back, but it is now showing a shade towards right...
(More)
i have zenith 19" TFT, purchased 8 months back, but it is now showing a shade towards right side of window borders
