Ihave a HARMAN/KARDON AVR 3550 Audio/Video Receiver. Just yesterday while having it on digital sat reception and just as i was changing the channel a screaching and dying sound occured and immediatly sat reception ended and the AVR 3550 lost showing the Main Information Display onlybut I can't play anything else. I closed everything down but checked my LCD TV SCREEN for local channels and other sat digital reception everything was fine. So now what should I do?
  • ogloony Apr 22, 2009
    no i don't think that my solution is new firm ware because the sound it gave was to loud indicating somthing blew out inside , i need an expert to guide me thru a series of check list or otherwise to identify the problem specially if he had incountered this problem before?
  • 19,396 Answers
The unit is probably faulty, and in that case it must be fixed by a technician or an experienced DIYer.
To start unplug all video and audio cables , unplug power cord from AVR-3550, wait ten minutes and restart with only TV connected on a cable different from the one used when the problem occurred. This can solve minor problems, and will tell you if the problem is a shorted video cable
That won't probably fix the problem.
In that case the receiver must be taken apart, disassembled and tested.
Testing does normally start from power supply.
Power supply is working, as you have power, but an incorrect voltage will trigger diagnostic mode, and the receiver will stay on but not operate.
First test on PSU is by checking for bulged or leaking capacitors , burnt spots, or broken solder joints. You do this kind of test just observing the board.
If you do not find anything in there , you inspect the rest of the boards.
Also check if some component is shorting the chassis, and inspect the input board connecting to TV, and the amp final board with power amp transistors or ICs.
If you do not find anything at a glance, then you will need to perform a series of test using a multimeter.
You test PSU volts out. Ensure PSU is not shorting to ground with chassis.
You test signal (input/output) board few components, and read voltages on flat ribbon connector to input output, check for contacts same as PSU.
You test the set of Transistors on amp final, the ones protected by dissipation plates and connected to output. If you heard a bang, a transistor in there, or the resistor at the base of the transistor had blown. If one of those resistor had blown, then also test the associated transistor.
Test all connectors to control panel.
After that test the main board, to do that you may need full schematics from complete service manual.
I scanned an exploded view , and provided link to download service manual for $7 , the complete manual is not available for free download.
I uploaded schematics here
You can buy service manual for your unit here.
Please do not forget to leave us feedback afterward.
Many thanks.
Posted on Apr 22, 2009
    Scholar:
  • 132 Answers
It may need a firmware upgrade. The website is down right now for maintenance unfortunately but check with them to see if you have the latest firmware for the device. Hopefully that's all you need.
Posted on Apr 20, 2009
How do to connect tv from AVR
audio out from tv to audio in on the avr
Apr 19, 2015 | Harmon Kardon Harman Kardon AVR 235...
Harman kardon 2650 auxiliary ports 2,3,4doesn't work
if you are talking about the hdmi ports, 3 are ins and one is out, but I use the hdmi from player direct to tv, and use coax or optical connection to my receiver for the audio
Mar 23, 2013 | Harmon Kardon Harman Kardon AVR 2650 7.1...
Can you hoop up an external equalizer to the Harman Kardon AVR 30?
Any traditional old-school analog stereo processor can be used only with analog stereo sources.
If this receiver had any digital sources, you would eventually discover that activation of a Tape Loop disables digital sources. Just the same you CAN still use DSP on processed 2-channel audio.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/s/Harman-Kardon-AVR-30-Receivers-review-manual/id/386bh140/t/1-2/
It's should clearly marked on the back of the EQ where everything goes.
The Line IN and Line Out would go to any available Tape Loop on the receiver. Something that has Out's and In's. Obviously, Out's on one device go to In's on the next.
Apr 29, 2011 | Harman Kardon AVR 30 Receiver
PROBLEM WITH DOLBY DIGITAL ON HARMAN KARDON AV225
Well it it might not. What exact model TV?
Your high-fidelity equipment should get TV-related audio from the same place the TV gets it - Cable, DVD, BD or Sat. A digital feed each of them will carry TRUE Dolby Digital audio. There is little sense in diluting TV-related audio through a TV and it's marginal audio electronics that are usually limited to analog stereo.
May 20, 2010 | Harman Kardon AVR 225 Receiver
I have a Harman/Kardon AVR 325. Left speaker not working with TV
How is TV audio (from the cable box) getting into the Receiver? If digitally, you wouldn't be missing any one channel on a connection malfunction, you'd lose them all. If analog, swap the channels around to isolate the problem (and reconsider using digital).
Feb 11, 2010 | Onkyo HTR500 Receiver
Can I conect harman Kardon avr 230 to apple tv
Yes, although it (AVR) does not support HDMI only component video.
Connect the audio to the receiver and the video directly to the TV if you have inadequate video inputs, or want to take advantage of the HDMI.
Dec 08, 2009 | Harman Kardon AVR 230 Receiver
Have digital feed connected (white, red, yellow) to DVD connections 6 & 13. Get picture but no sound. Sound is OK on VID1 input from satelite. Any ideas?
so you have the yellow out from dvd player to yellow in on the receiver (composite video) and the red and white out from dvd player to red and white in on the receiver (right and left audio channel) . you can also plug in the orange rca (digital coaxial audio) go to your menu on the Haman Kardon receiver and make sure you select the right audio input. mine is a Harman Kardon AVR146 push th osd (on screen display) on the remote. go ti the input setup and select the appropriate audio input
Dec 05, 2009 | Harman Kardon AVR 320 Receiver
Harman kardon avr-147
Hi Javis. This is perfectly normal ! This mode change is done because the receiver auto detects the digital audio signal and sets the receiver's DSP to decode the signal correctly. You can go into the OSD menu to bypass the auto detection of it, but it's not recommended at all ! You're getting the best audio quality by doing so. Thanks ! cheebster.
May 07, 2007 | Harman Kardon AVR 240 Receiver
128 people viewed this question
 Grubhead
Grubhead
