Question about Konica Minolta bizhub 350 All-In-One Laser Printer
Unable to print in colour using GIMP
I use the GIMP. I send colour JPGs to the printer and I always get grayscale images out
  • 1 more comment
  • vcl_455 Apr 20, 2009
    sorry, its a C350. word and every other application works.
    inkscape as well as gimp both fail to print in colour
    I feel perhaps the issue has something to do with EPS postscript, I think perhaps if there was a troubleshooting procedure this might help.
    I have done some further investigation. it will print if I include a gimp picture into a word document. It will also print using the Irfanview program. it will not print in colour using Inkscape. I found a Gimp-print list showing what printers are supported-there is NO reference to the bizhub C350/C360, in fact no mention of Konica-Minolta whatsoever!
    Problem Solver:
  • 4 Answers
If i am correct the bizhub 350 is for black and white only and not colored, unless you use a bizhub c350
Posted on Apr 20, 2009
My epson printer is printing the black from all the other colors, and ignoring the black ink cartridge
If you are printing "graphic" images ie photos, pdf's, fancy type-faces, lines or grayscale - your print is defined as colour and will be printed using colour shaded with black.
Apr 29, 2016 | Epson Artisan 810 AllInOne InkJet Printer
Selecting Grayscale and then Default isn't working. The printer reverts to auto colour after the first Grayscale print operation. How do I make Grayscale operate automatically each time please?
Setting default on the printer copier can be over written by the software. each document/letter/spread sheet etc has print properties associated with it. when you tell it to print without going to the properties area it will print like the last time you printed and override any settings on the actual hardware. Software always has the ability to override the hardware in any brand.If you live in Southeast Florida Advanced business computers is a great source for help. Computer network repair, printer copier maintenance repairs, copier printer leasing and supplies.
Apr 08, 2016 | Office Equipment & Supplies
Black ink prints perfect on the test document, but on any other document prints very light purple. Heads are clean?
Please try to print your document with the option 'grayscale' and see if the black is better. If it is ok with this setting, the light purple colour is caused by a software translation of colour. You need to change the colour settings in you printerdriver, or when you send a document to your printer, change the settings of your software application. (Word/Indesign/Photoshop or whatever you are using)
Aug 05, 2011 | Epson Stylus Photo RX680 Printer
Picture is colour but I want to print it black and white.
Download the _free_ "Graphic Image Manipulation Program" from http://www.GIMP.org
and use it, as if it were the very-expensive Adobe Photoshop, to convert colour to grey-scale.
Apr 10, 2010 | Epson Stylus CX3200 All-In-One InkJet...
HOW TO PRINT ONLY BLACK ON PIXMA IP6600D ?
you can always get this setting done in your printing preference once your printer is correctly installed. In the printer preference, check the tab that talks about colour, there you will find an option that says " print in grayscale" or "use black catridge only" check this option and your printer will print only in black whenever u want.
Oct 23, 2009 | Canon PIXMA MP160 All-In-One InkJet...
HP Photosmart c4480, prints black where gray shades exist
try cleaning the printhead your printer seem to have an image quality issue
Sep 23, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
Sharp AR-M237 Grayscale Copier Problem
Yes.There should be settings to enhance that in your print driver properties page.
Easiest way to access that is to open a document and click "file' then 'print and that will bring up your printer options.
Look around the print driver for ways to enhance your prints.
Most drivers have several options in graphics areas to make adjustments.
You can access printers from the controle panel and also right click the printer and select properties to access it.
There definatly are ways to adjust that.
Hope this helps you some.
Dec 19, 2007 | Sharp AR-M237 Copier
Can I go to grayscale all the time?
Usually 'black' or greyscale uses all colours to get a true black in many printers. Check you particular printer manual and soft ware to see if it allows for black/grey only. You could experiment [I don't know this particular printer] by putting black carts in all slots [If it is a chipped cart you may have to consider swapping the chips on the carts if removable. Some specialist ink firms[Lycos] do supply monochrome sets for certain printers - check them out. Also take a look at www.fixyourownprinter.com
May 16, 2007 | Canon BubbleJet i560 InkJet Printer
Colour problem with printer
After you scan it, do you immediately print it in an image format or do you use word? If you use word i might have a tip that might help.
Before printing, click File>print>click on "Properties" and check that the grayscale printing box isn't marked, if it is unmark it and it'll print in colour.
Also anything is that, when you're scanning. After previewing your scanned piece, double check the mode, either magazine (which is in colour), Black and white or outline (i think)
That's all i have for now.
Sep 09, 2006 | Canon PIXMA MP130 All-In-One InkJet...
Konica Minolta bizhub 350 All-In-One Laser Printer Logo
172 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
